Teensy 4.1 with Adafruit MAX98357A I2S board
I am working on a project that uses the Adafruit MAX98357A to play wav files but am not having good luck.
I believe this should be possible as I have a friend who uses "import" versions of the MAX98357A in his products.
The code I am using is :
AudioPlaySdWav playSdWav1; // xy=301,144
AudioOutputI2S2 i2s2_1;    // xy=478,131
AudioConnection patchCord1(playSdWav1, 0, i2s2_1, 0);
AudioConnection patchCord2(playSdWav1, 1, i2s2_1, 1);
// in setup for testing
playSdWav1.play("IGNO.WAV");
I'm using I2S2 as it will make routing a PCB later easier, but I have tried I2S1 as well.
I am sure this is a me issue, but I can't find it.
Tried so far:
  • Validated audio board is getting +5v.
  • Checked the connections multiple times, both on I2S 1 and 2.
  • Tried using a "String" synth note to eliminate the WAV is in the wrong format.
  • Checked the speaker isn't damaged, it measures 4R across the leads which is correct.
  • Checked the speaker is actually connected to the header as I am using ferules, again 4R.
  • Using 8.3 file names for WAVs.
Is there a missing control object I need for this board? It's just the max and a handful of caps and resistors, I don't think it would require one.
Is there a simple way to try work out if it's the teensy or the max? Maybe MQS and look at it with a scope?
Pictures of the setup, click for bigger
Vague setup pictures, the I2S2 is hooked up at pins 2-4 front left.
The other end at the breakout board. Post-it is there to stop the speaker shorting on a jumper for the power rails under it.
Can you show the connections to the breakout clearly - the second image doesn't have all the connections you claim to have.
Where is your call to AudioMemory? You've ignored the forum rule - its there for a very good reason.
It was a RTFM failure on my end. The mention of the missing AudioMemoryCall() made me start again.
I had indeed not included all of the audio setup. I was working from the Audio Design tool, not the tutorial sketches which was a mistake. Sorry for wasting anyone's time.
For anyone who lands here this is working code:
#include <avdweb_Switch.h>
#include <elapsedMillis.h>
#include "Config.h"
#include "Pins.h"
#include "F11D_Lights.hpp"
// https://www.pjrc.com/teensy/gui/
#define SDCARD_CS_PIN BUILTIN_SDCARD
#define SDCARD_MOSI_PIN 11 // not actually used
#define SDCARD_SCK_PIN 13  // not actually used
Switch trigger1(trigger1Pin);
Switch trigger2(trigger2Pin, INPUT_PULLUP, LOW, 50, 3000, 250, 10); // Defaults + 3 second long press
Switch trigger3(trigger3Pin);
F11D_Lights lights(neopixelCount, neopixelPin, ledFrontRedPin, ledFrontGreenPin, ledFrontBluePin, ledTorchPin);
    Serial.println("Starting");
    lights.begin();
    AudioMemory(10); // A starting point see MemoryAndCPuUsage.ino example to work out what is needed.
    // Initialise the SD card
    SPI.setMOSI(SDCARD_MOSI_PIN);
    SPI.setSCK(SDCARD_SCK_PIN);
    if (!(SD.begin(SDCARD_CS_PIN)))
        while (1)
    Serial.println("SD Access");
    buttonsLoop();
    if (trigger1.pushed())
        Serial.println("Button 1 Pressed");
        fire();
    if (trigger2.pushed())
        Serial.println("Button 2 Pressed");
        startDisco();
    if (trigger3.on())
        lights.torchOn();
        lights.torchOff();
    lights.loop();
void buttonsLoop()
    trigger1.poll();
    trigger2.poll();
    trigger3.poll();
void startDisco()
    playSdWav1.play("CANTINA.WAV");
    lights.startDiscoMode();
void fire()
    playSdWav1.play("FOBLAST.WAV");
    lights.startBlast();
