marcellom66
New member
I need to upload a file wav to Teensy 4.1 by ethernet and save it to SD memory but my program doesn't work, do you know a library that it's right for this function or if I write something wrong, thanks for your help.
This is my program:
#include <NativeEthernet.h>
#include <stdlib.h> // necessario per qsort
// Inizializza la connessione Ethernet e il server Web
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192, 168, 1, 177);
EthernetServer server(80);
Ethernet.begin(mac, ip);
server.begin();
if (!SD.begin(BUILTIN_SDCARD)) {
Serial.println("Errore durante l'inizializzazione della memoria SD.");
return;
EthernetClient client = server.available();
if (client) {
if (client.connected()) {
String request = "";
while (client.available()) {
char c = client.read();
request += c;
if (request.endsWith("\r\n\r\n")) {
if (request.indexOf("POST") >= 0) {
int nameStart = request.indexOf("filename=\"") + 10;
int nameEnd = request.indexOf("\"", nameStart);
String fileName = request.substring(nameStart, nameEnd);
int sizeStart = request.indexOf("Content-Length: ") + 16;
int sizeEnd = request.indexOf("\r\n", sizeStart);
int fileSize = request.substring(sizeStart, sizeEnd).toInt();
File file = SD.open(fileName.c_str(), O_RDWR | O_CREAT);
int bytesWritten = 0;
while (bytesWritten < fileSize) {
if (client.available()) {
file.write(c);
bytesWritten++;
file.close();
client.println("HTTP/1.1 200 OK");
client.println("Content-Type: text/html");
client.println();
client.println("<html>");
client.println("<head>");
client.println("<title>Upload File su Teensy 4.1</title>");
client.println("</head>");
client.println("<body>");
client.println("<h1>File caricato con successo!</h1>");
client.println("<p>Il file " + fileName + " è stato caricato correttamente sulla memoria SD di Teensy 4.1.</p>");
client.println("<p><a href=\"/\">Torna all'elenco dei file sulla memoria SD</a></p>");
client.println("</body>");
client.println("</html>");
delay(10);
client.stop();
else if (request.indexOf("GET") >= 0) {
handleGetRequest(client);
else {
handleBadRequest(client);
// funzione di comparazione per qsort
int compare(const void *a, const void *b) {
String *strA = (String *)a;
String *strB = (String *)b;
return strA->compareTo(*strB);
void handleGetRequest(EthernetClient client) {
File root = SD.open("/");
if (!root) {
Serial.println("Errore nell'apertura della root directory");
client.println("HTTP/1.1 500 Internal Server Error");
client.println();
client.println("<h1>Errore interno del server</h1>");
return;
String fileList[20];
int fileCount = 0;
while (File entry = root.openNextFile()) {
if (entry.isDirectory()) {
entry.close();
continue;
fileList[fileCount] = entry.name();
entry.close();
fileCount++;
if (fileCount >= 20) {
root.close();
qsort(fileList, fileCount, sizeof(String), compare);
client.println("Connection: close");
client.println();
client.println("<title>Directory listing</title>");
client.println("<style>");
client.println("table { border-collapse: collapse; width: 25%; }");
client.println("th, td { text-align: left; padding: 8px; }");
client.println("th { background-color: #777; color: white; border: 2px solid black; }");
client.println("tr:nth-child(even) { background-color: #f2f2f2; }");
client.println(".scrollbar { height: 200px; overflow-y: scroll; }");
client.println("</style>");
client.println("<h2>Directory listing</h2>");
client.println("<form action=\"/upload\" method=\"post\" enctype=\"multipart/form-data\">");
client.println("<input type=\"file\" name=\"fileToUpload\" style=\"font-size: 16px; padding: 8px;\">");
client.println("<input type=\"submit\" value=\"Scegli file\" style=\"font-size: 16px; padding: 8px;\">");
client.println("<input type=\"submit\" value=\"Carica\" style=\"font-size: 16px; padding: 8px;\">");
client.println("</form>");
client.println("<table>");
client.println("<tr><th>Nome</th><th>Dimensione</th></tr>");
for (int i = 0; i < fileCount; i++) {
String fileName = fileList;
File entry = SD.open(fileName.c_str());
if (!entry) {
Serial.println("Errore nell'apertura del file: " + fileName);
continue;
entry.close();
continue;
client.println("<tr>");
client.println("<td>" + fileName + "</td>");
client.println("<td>" + String(entry.size()) + " bytes</td>");
client.println("</tr>");
entry.close();
client.println("</table>");
// Gestisce le richieste non valide
void handleBadRequest(EthernetClient client) {
client.println("HTTP/1.1 400 Bad Request");
client.println();
client.println("<title>Richiesta non valida</title>");
client.println("<h1>Richiesta non valida</h1>");
client.println("<p>La richiesta inviata non è valida. Riprova.</p>");
delay(10);
client.stop();
This is my program:
server.begin();
return;
if (client) {
request += c;
file.write(c);
bytesWritten++;
file.close();
client.println();
delay(10);
client.stop();
else {
if (!root) {
client.println();
return;
int fileCount = 0;
entry.close();
continue;
entry.close();
fileCount++;
root.close();
client.println();
if (!entry) {
continue;
entry.close();
continue;
entry.close();
client.println();
delay(10);
client.stop();
