Arduino: 1.8.19 (Windows 10), TD: 1.59-beta2, Board: "Teensy 4.0, Serial, 600 MHz, Faster, US English"
Compiling sketch...
"C:\\T_Drive\\arduino-1.8.19\\hardware\\teensy/../tools/precompile_helper" "C:\\T_Drive\\arduino-1.8.19\\hardware\\teensy\\avr/cores/teensy4" "C:\\Users\\Tim\\AppData\\Local\\Temp\\arduino_build_233238" "C:\\T_Drive\\arduino-1.8.19\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -x c++-header -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10819 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\T_Drive\\arduino-1.8.19\\hardware\\teensy\\avr/cores/teensy4" "C:\\Users\\Tim\\AppData\\Local\\Temp\\arduino_build_233238/pch/Arduino.h" -o "C:\\Users\\Tim\\AppData\\Local\\Temp\\arduino_build_233238/pch/Arduino.h.gch"
"C:\\T_Drive\\arduino-1.8.19\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10819 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Tim\\AppData\\Local\\Temp\\arduino_build_233238/pch" "-IC:\\T_Drive\\arduino-1.8.19\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Users\\Tim\\AppData\\Local\\Temp\\arduino_build_233238\\sketch\\CppMT19937.ino.cpp" -o "C:\\Users\\Tim\\AppData\\Local\\Temp\\arduino_build_233238\\sketch\\CppMT19937.ino.cpp.o"
In file included from C:\T_Drive\arduino-1.8.19\hardware\teensy\avr\cores\teensy4/WProgram.h:46,
from C:\Users\Tim\AppData\Local\Temp\arduino_build_233238\pch\Arduino.h:6:
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc: In member function 'void std::poisson_distribution<_IntType>::param_type::_M_initialize()':
C:\T_Drive\arduino-1.8.19\hardware\teensy\avr\cores\teensy4/wiring.h:174:18: error: expected unqualified-id before '(' token
174 | #define round(x) ((long) __builtin_round(x))
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc: In member function 'std::poisson_distribution<_IntType>::result_type std::poisson_distribution<_IntType>::operator()(_UniformRandomNumberGenerator&, const std::poisson_distribution<_IntType>::param_type&)':
C:\T_Drive\arduino-1.8.19\hardware\teensy\avr\cores\teensy4/wiring.h:164:16: error: expected unqualified-id before '(' token
164 | #define abs(x) ({ \
C:\T_Drive\arduino-1.8.19\hardware\teensy\avr\cores\teensy4/wiring.h:165:3: error: expected primary-expression before 'typeof'
165 | typeof(x) _x = (x); \
C:\T_Drive\arduino-1.8.19\hardware\teensy\avr\cores\teensy4/wiring.h:165:3: error: expected '}' before 'typeof'
C:\T_Drive\arduino-1.8.19\hardware\teensy\avr\cores\teensy4/wiring.h:164:17: note: to match this '{'
C:\T_Drive\arduino-1.8.19\hardware\teensy\avr\cores\teensy4/wiring.h:165:3: error: expected ')' before 'typeof'
C:\T_Drive\arduino-1.8.19\hardware\teensy\avr\cores\teensy4/wiring.h:164:16: note: to match this '('
C:\T_Drive\arduino-1.8.19\hardware\teensy\avr\cores\teensy4/wiring.h:166:4: error: '_x' was not declared in this scope; did you mean '__x'?
166 | (_x > 0) ? _x : -_x; \
C:\T_Drive\arduino-1.8.19\hardware\teensy\avr\cores\teensy4/wiring.h:167:2: error: expected primary-expression before ')' token
167 | })
In file included from c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\random:51,
from C:\T_Drive\tCode\RANDOM\CppMT19937\CppMT19937.ino:3:
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1346:38: error: '__y' was not declared in this scope; did you mean '__w'?
1346 | __x = std::floor(__y);
| __w
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1347:28: error: '__n' was not declared in this scope; did you mean '__w'?
1347 | __w = -__n * __n / 2;
| __w
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1351:22: error: expected 'while' before 'if'
1351 | else if (__u <= __c2)
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1351:22: error: expected '(' before 'if'
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1351:22: error: expected primary-expression before 'if'
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1351:21: error: expected ')' before 'if'
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1351:21: error: expected ';' before 'if'
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1351:26: error: '__u' was not declared in this scope; did you mean '_Mu'?
| _Mu
167 | })
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1355:37: error: '__y' was not declared in this scope; did you mean '__c'?
1355 | __x = std::ceil(__y);
| __c
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1356:21: error: '__w' was not declared in this scope; did you mean '__c'?
1356 | __w = __y * (2 - __y) * __param._M_1cx;
| __c
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1358:23: error: continue statement not within a loop
1358 | continue;
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1360:26: error: '__u' was not declared in this scope; did you mean '_Mu'?
1360 | else if (__u <= __c3)
| _Mu
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1360:33: error: '__c3' was not declared in this scope
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1363:19: error: '__x' was not declared in this scope
1363 | __x = -1;
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1364:33: error: '__c4' was not declared in this scope
1364 | else if (__u <= __c4)
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1365:19: error: '__x' was not declared in this scope
1365 | __x = 0;
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1366:33: error: '__c5' was not declared in this scope
1366 | else if (__u <= __c5)
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1368:21: error: '__x' was not declared in this scope
1368 | __x = 1;
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1370:21: error: '__w' was not declared in this scope
1370 | __w = __178;
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1370:27: error: '__178' was not declared in this scope
1370 | __w = __178;
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1376:46: error: '__2cx' was not declared in this scope
1376 | + __v * __2cx / __param._M_d;
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1377:21: error: '__x' was not declared in this scope; did you mean '__y'?
1377 | __x = std::ceil(__y);
| __y
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1378:21: error: '__w' was not declared in this scope; did you mean '__y'?
1378 | __w = -__param._M_d * __param._M_1cx * (1 + __y / 2);
| __y
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1381:17: error: '__reject' was not declared in this scope; did you mean '_reent'?
1381 | __reject = (__w - __e - __x * __param._M_lm_thr
| _reent
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1381:29: error: '__w' was not declared in this scope
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1381:35: error: '__e' was not declared in this scope
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1381:41: error: '__x' was not declared in this scope
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1382:66: error: '__m' was not declared in this scope; did you mean '__tm'?
1382 | > __param._M_lfm - std::lgamma(__x + __m + 1));
| __tm
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1384:42: error: '__thr' was not declared in this scope
1384 | __reject |= __x + __m >= __thr;
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc: At global scope:
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1386:17: error: expected unqualified-id before 'while'
1386 | } while (__reject);
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1388:13: error: expected unqualified-id before 'return'
1388 | return result_type(__x + __m + __naf);
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1390:9: error: expected unqualified-id before 'else'
1390 | else
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1405:7: error: expected declaration before '}' token
1405 | }
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1411:7: error: too many template-parameter-lists
1411 | poisson_distribution<_IntType>::
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1426:22: error: 'poisson_distribution' does not name a type
1426 | const poisson_distribution<_IntType>& __x)
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1426:42: error: expected ',' or '...' before '<' token
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc: In function 'std::basic_ostream<_CharT, _Traits>& operator<<(std::basic_ostream<_CharT, _Traits>&, int)':
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1428:35: error: expected nested-name-specifier before 'basic_ostream'
1428 | using __ios_base = typename basic_ostream<_CharT, _Traits>::ios_base;
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1430:7: error: expected primary-expression before 'const'
1430 | const typename __ios_base::fmtflags __flags = __os.flags();
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1434:18: error: '__ios_base' has not been declared
1434 | __os.flags(__ios_base::scientific | __ios_base::left);
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1434:43: error: '__ios_base' has not been declared
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1438:15: error: '__x' was not declared in this scope
1438 | __os << __x.mean() << __space << __x._M_nd;
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1440:18: error: '__flags' was not declared in this scope
1440 | __os.flags(__flags);
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1450:16: error: 'poisson_distribution' has not been declared
1450 | poisson_distribution<_IntType>& __x)
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1450:36: error: expected ',' or '...' before '<' token
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc: In function 'std::basic_istream<_CharT, _Traits>& operator>>(std::basic_istream<_CharT, _Traits>&, int)':
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1452:35: error: expected nested-name-specifier before 'poisson_distribution'
1452 | using param_type = typename poisson_distribution<_IntType>::param_type;
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1453:35: error: expected nested-name-specifier before 'basic_istream'
1453 | using __ios_base = typename basic_istream<_CharT, _Traits>::ios_base;
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1455:7: error: expected primary-expression before 'const'
1455 | const typename __ios_base::fmtflags __flags = __is.flags();
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1456:18: error: '__ios_base' has not been declared
1456 | __is.flags(__ios_base::skipws);
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1459:29: error: '__x' was not declared in this scope
1459 | if (__is >> __mean >> __x._M_nd)
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1462:18: error: '__flags' was not declared in this scope
1462 | __is.flags(__flags);
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1469:26: error: expected initializer before '<' token
1469 | binomial_distribution<_IntType>::param_type::
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1521:16: error: expected nested-name-specifier before 'binomial_distribution'
1521 | typename binomial_distribution<_IntType>::result_type
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1521:16: error: too many template-parameter-lists
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1556:16: error: expected nested-name-specifier before 'binomial_distribution'
1556 | typename binomial_distribution<_IntType>::result_type
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1556:16: error: too many template-parameter-lists
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1677:7: error: too many template-parameter-lists
1677 | binomial_distribution<_IntType>::
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1692:22: error: 'binomial_distribution' does not name a type
1692 | const binomial_distribution<_IntType>& __x)
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1692:43: error: expected ',' or '...' before '<' token
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1691:5: error: redefinition of 'template<class _IntType, class _CharT, class _Traits> std::basic_ostream<_CharT, _Traits>& operator<<(std::basic_ostream<_CharT, _Traits>&, int)'
1691 | operator<<(std::basic_ostream<_CharT, _Traits>& __os,
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1425:5: note: 'template<class _IntType, class _CharT, class _Traits> std::basic_ostream<_CharT, _Traits>& operator<<(std::basic_ostream<_CharT, _Traits>&, int)' previously declared here
1425 | operator<<(std::basic_ostream<_CharT, _Traits>& __os,
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1717:16: error: 'binomial_distribution' has not been declared
1717 | binomial_distribution<_IntType>& __x)
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1717:37: error: expected ',' or '...' before '<' token
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1716:5: error: redefinition of 'template<class _IntType, class _CharT, class _Traits> std::basic_istream<_CharT, _Traits>& operator>>(std::basic_istream<_CharT, _Traits>&, int)'
1716 | operator>>(std::basic_istream<_CharT, _Traits>& __is,
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1449:5: note: 'template<class _IntType, class _CharT, class _Traits> std::basic_istream<_CharT, _Traits>& operator>>(std::basic_istream<_CharT, _Traits>&, int)' previously declared here
1449 | operator>>(std::basic_istream<_CharT, _Traits>& __is,
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1754:22: error: 'exponential_distribution' does not name a type
1754 | const exponential_distribution<_RealType>& __x)
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1754:46: error: expected ',' or '...' before '<' token
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1753:5: error: redefinition of 'template<class _RealType, class _CharT, class _Traits> std::basic_ostream<_CharT, _Traits>& operator<<(std::basic_ostream<_CharT, _Traits>&, int)'
1753 | operator<<(std::basic_ostream<_CharT, _Traits>& __os,
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1776:16: error: 'exponential_distribution' has not been declared
1776 | exponential_distribution<_RealType>& __x)
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1776:40: error: expected ',' or '...' before '<' token
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1775:5: error: redefinition of 'template<class _RealType, class _CharT, class _Traits> std::basic_istream<_CharT, _Traits>& operator>>(std::basic_istream<_CharT, _Traits>&, int)'
1775 | operator>>(std::basic_istream<_CharT, _Traits>& __is,
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1802:16: error: expected nested-name-specifier before 'normal_distribution'
1802 | typename normal_distribution<_RealType>::result_type
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1802:16: error: too many template-parameter-lists
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1841:7: error: too many template-parameter-lists
1841 | normal_distribution<_RealType>::
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1920:22: error: 'normal_distribution' does not name a type
1920 | const normal_distribution<_RealType>& __x)
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1920:41: error: expected ',' or '...' before '<' token
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1919:5: error: redefinition of 'template<class _RealType, class _CharT, class _Traits> std::basic_ostream<_CharT, _Traits>& operator<<(std::basic_ostream<_CharT, _Traits>&, int)'
1919 | operator<<(std::basic_ostream<_CharT, _Traits>& __os,
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1946:16: error: 'normal_distribution' has not been declared
1946 | normal_distribution<_RealType>& __x)
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1946:35: error: expected ',' or '...' before '<' token
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1945:5: error: redefinition of 'template<class _RealType, class _CharT, class _Traits> std::basic_istream<_CharT, _Traits>& operator>>(std::basic_istream<_CharT, _Traits>&, int)'
1945 | operator>>(std::basic_istream<_CharT, _Traits>& __is,
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1974:7: error: too many template-parameter-lists
1974 | lognormal_distribution<_RealType>::
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1987:22: error: 'lognormal_distribution' does not name a type
1987 | const lognormal_distribution<_RealType>& __x)
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1987:44: error: expected ',' or '...' before '<' token
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:1986:5: error: redefinition of 'template<class _RealType, class _CharT, class _Traits> std::basic_ostream<_CharT, _Traits>& operator<<(std::basic_ostream<_CharT, _Traits>&, int)'
1986 | operator<<(std::basic_ostream<_CharT, _Traits>& __os,
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2011:16: error: 'lognormal_distribution' has not been declared
2011 | lognormal_distribution<_RealType>& __x)
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2011:38: error: expected ',' or '...' before '<' token
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2010:5: error: redefinition of 'template<class _RealType, class _CharT, class _Traits> std::basic_istream<_CharT, _Traits>& operator>>(std::basic_istream<_CharT, _Traits>&, int)'
2010 | operator>>(std::basic_istream<_CharT, _Traits>& __is,
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2059:22: error: 'chi_squared_distribution' does not name a type
2059 | const chi_squared_distribution<_RealType>& __x)
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2059:46: error: expected ',' or '...' before '<' token
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2058:5: error: redefinition of 'template<class _RealType, class _CharT, class _Traits> std::basic_ostream<_CharT, _Traits>& operator<<(std::basic_ostream<_CharT, _Traits>&, int)'
2058 | operator<<(std::basic_ostream<_CharT, _Traits>& __os,
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2082:16: error: 'chi_squared_distribution' has not been declared
2082 | chi_squared_distribution<_RealType>& __x)
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2082:40: error: expected ',' or '...' before '<' token
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2081:5: error: redefinition of 'template<class _RealType, class _CharT, class _Traits> std::basic_istream<_CharT, _Traits>& operator>>(std::basic_istream<_CharT, _Traits>&, int)'
2081 | operator>>(std::basic_istream<_CharT, _Traits>& __is,
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2102:16: error: expected nested-name-specifier before 'cauchy_distribution'
2102 | typename cauchy_distribution<_RealType>::result_type
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2102:16: error: too many template-parameter-lists
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2122:7: error: too many template-parameter-lists
2122 | cauchy_distribution<_RealType>::
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2145:22: error: 'cauchy_distribution' does not name a type
2145 | const cauchy_distribution<_RealType>& __x)
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2145:41: error: expected ',' or '...' before '<' token
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2144:5: error: redefinition of 'template<class _RealType, class _CharT, class _Traits> std::basic_ostream<_CharT, _Traits>& operator<<(std::basic_ostream<_CharT, _Traits>&, int)'
2144 | operator<<(std::basic_ostream<_CharT, _Traits>& __os,
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2168:16: error: 'cauchy_distribution' has not been declared
2168 | cauchy_distribution<_RealType>& __x)
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2168:35: error: expected ',' or '...' before '<' token
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2167:5: error: redefinition of 'template<class _RealType, class _CharT, class _Traits> std::basic_istream<_CharT, _Traits>& operator>>(std::basic_istream<_CharT, _Traits>&, int)'
2167 | operator>>(std::basic_istream<_CharT, _Traits>& __is,
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2220:22: error: 'fisher_f_distribution' does not name a type
2220 | const fisher_f_distribution<_RealType>& __x)
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2220:43: error: expected ',' or '...' before '<' token
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2219:5: error: redefinition of 'template<class _RealType, class _CharT, class _Traits> std::basic_ostream<_CharT, _Traits>& operator<<(std::basic_ostream<_CharT, _Traits>&, int)'
2219 | operator<<(std::basic_ostream<_CharT, _Traits>& __os,
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2244:16: error: 'fisher_f_distribution' has not been declared
2244 | fisher_f_distribution<_RealType>& __x)
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2244:37: error: expected ',' or '...' before '<' token
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2243:5: error: redefinition of 'template<class _RealType, class _CharT, class _Traits> std::basic_istream<_CharT, _Traits>& operator>>(std::basic_istream<_CharT, _Traits>&, int)'
2243 | operator>>(std::basic_istream<_CharT, _Traits>& __is,
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2294:22: error: 'student_t_distribution' does not name a type
2294 | const student_t_distribution<_RealType>& __x)
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2294:44: error: expected ',' or '...' before '<' token
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2293:5: error: redefinition of 'template<class _RealType, class _CharT, class _Traits> std::basic_ostream<_CharT, _Traits>& operator<<(std::basic_ostream<_CharT, _Traits>&, int)'
2293 | operator<<(std::basic_ostream<_CharT, _Traits>& __os,
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2317:16: error: 'student_t_distribution' has not been declared
2317 | student_t_distribution<_RealType>& __x)
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2317:38: error: expected ',' or '...' before '<' token
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2316:5: error: redefinition of 'template<class _RealType, class _CharT, class _Traits> std::basic_istream<_CharT, _Traits>& operator>>(std::basic_istream<_CharT, _Traits>&, int)'
2316 | operator>>(std::basic_istream<_CharT, _Traits>& __is,
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2337:23: error: expected initializer before '<' token
2337 | gamma_distribution<_RealType>::param_type::
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2353:16: error: expected nested-name-specifier before 'gamma_distribution'
2353 | typename gamma_distribution<_RealType>::result_type
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2353:16: error: too many template-parameter-lists
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2398:7: error: too many template-parameter-lists
2398 | gamma_distribution<_RealType>::
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2463:22: error: 'gamma_distribution' does not name a type
2463 | const gamma_distribution<_RealType>& __x)
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2463:40: error: expected ',' or '...' before '<' token
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2462:5: error: redefinition of 'template<class _RealType, class _CharT, class _Traits> std::basic_ostream<_CharT, _Traits>& operator<<(std::basic_ostream<_CharT, _Traits>&, int)'
2462 | operator<<(std::basic_ostream<_CharT, _Traits>& __os,
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2487:16: error: 'gamma_distribution' has not been declared
2487 | gamma_distribution<_RealType>& __x)
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2487:34: error: expected ',' or '...' before '<' token
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2486:5: error: redefinition of 'template<class _RealType, class _CharT, class _Traits> std::basic_istream<_CharT, _Traits>& operator>>(std::basic_istream<_CharT, _Traits>&, int)'
2486 | operator>>(std::basic_istream<_CharT, _Traits>& __is,
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2506:16: error: expected nested-name-specifier before 'weibull_distribution'
2506 | typename weibull_distribution<_RealType>::result_type
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2506:16: error: too many template-parameter-lists
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2521:7: error: too many template-parameter-lists
2521 | weibull_distribution<_RealType>::
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2539:22: error: 'weibull_distribution' does not name a type
2539 | const weibull_distribution<_RealType>& __x)
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2539:42: error: expected ',' or '...' before '<' token
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2538:5: error: redefinition of 'template<class _RealType, class _CharT, class _Traits> std::basic_ostream<_CharT, _Traits>& operator<<(std::basic_ostream<_CharT, _Traits>&, int)'
2538 | operator<<(std::basic_ostream<_CharT, _Traits>& __os,
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2562:16: error: 'weibull_distribution' has not been declared
2562 | weibull_distribution<_RealType>& __x)
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2562:36: error: expected ',' or '...' before '<' token
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2561:5: error: redefinition of 'template<class _RealType, class _CharT, class _Traits> std::basic_istream<_CharT, _Traits>& operator>>(std::basic_istream<_CharT, _Traits>&, int)'
2561 | operator>>(std::basic_istream<_CharT, _Traits>& __is,
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2581:16: error: expected nested-name-specifier before 'extreme_value_distribution'
2581 | typename extreme_value_distribution<_RealType>::result_type
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2581:16: error: too many template-parameter-lists
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2596:7: error: too many template-parameter-lists
2596 | extreme_value_distribution<_RealType>::
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2613:22: error: 'extreme_value_distribution' does not name a type
2613 | const extreme_value_distribution<_RealType>& __x)
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2613:48: error: expected ',' or '...' before '<' token
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2612:5: error: redefinition of 'template<class _RealType, class _CharT, class _Traits> std::basic_ostream<_CharT, _Traits>& operator<<(std::basic_ostream<_CharT, _Traits>&, int)'
2612 | operator<<(std::basic_ostream<_CharT, _Traits>& __os,
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2636:16: error: 'extreme_value_distribution' has not been declared
2636 | extreme_value_distribution<_RealType>& __x)
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2636:42: error: expected ',' or '...' before '<' token
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2635:5: error: redefinition of 'template<class _RealType, class _CharT, class _Traits> std::basic_istream<_CharT, _Traits>& operator>>(std::basic_istream<_CharT, _Traits>&, int)'
2635 | operator>>(std::basic_istream<_CharT, _Traits>& __is,
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2656:26: error: expected initializer before '<' token
2656 | discrete_distribution<_IntType>::param_type::
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2681:7: error: 'discrete_distribution' does not name a type
2681 | discrete_distribution<_IntType>::param_type::
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2697:16: error: expected nested-name-specifier before 'discrete_distribution'
2697 | typename discrete_distribution<_IntType>::result_type
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2697:16: error: too many template-parameter-lists
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2719:7: error: too many template-parameter-lists
2719 | discrete_distribution<_IntType>::
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2749:22: error: 'discrete_distribution' does not name a type
2749 | const discrete_distribution<_IntType>& __x)
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2749:43: error: expected ',' or '...' before '<' token
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2748:5: error: redefinition of 'template<class _IntType, class _CharT, class _Traits> std::basic_ostream<_CharT, _Traits>& operator<<(std::basic_ostream<_CharT, _Traits>&, int)'
2748 | operator<<(std::basic_ostream<_CharT, _Traits>& __os,
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2775:5: error: 'basic_istream' does not name a type
2775 | basic_istream<_CharT, _Traits>&
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2795:16: error: 'discrete_distribution' has not been declared
2795 | discrete_distribution<_IntType>& __x)
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2795:37: error: expected ',' or '...' before '<' token
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2794:5: error: redefinition of 'template<class _IntType, class _CharT, class _Traits> std::basic_istream<_CharT, _Traits>& operator>>(std::basic_istream<_CharT, _Traits>&, int)'
2794 | operator>>(std::basic_istream<_CharT, _Traits>& __is,
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2817:36: error: expected initializer before '<' token
2817 | piecewise_constant_distribution<_RealType>::param_type::
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2850:7: error: 'piecewise_constant_distribution' does not name a type
2850 | piecewise_constant_distribution<_RealType>::param_type::
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2875:7: error: 'piecewise_constant_distribution' does not name a type
2875 | piecewise_constant_distribution<_RealType>::param_type::
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2892:7: error: 'piecewise_constant_distribution' does not name a type
2892 | piecewise_constant_distribution<_RealType>::param_type::
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2912:16: error: expected nested-name-specifier before 'piecewise_constant_distribution'
2912 | typename piecewise_constant_distribution<_RealType>::result_type
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2912:16: error: too many template-parameter-lists
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2937:7: error: too many template-parameter-lists
2937 | piecewise_constant_distribution<_RealType>::
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2971:22: error: 'piecewise_constant_distribution' does not name a type
2971 | const piecewise_constant_distribution<_RealType>& __x)
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2971:53: error: expected ',' or '...' before '<' token
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:2970:5: error: redefinition of 'template<class _RealType, class _CharT, class _Traits> std::basic_ostream<_CharT, _Traits>& operator<<(std::basic_ostream<_CharT, _Traits>&, int)'
2970 | operator<<(std::basic_ostream<_CharT, _Traits>& __os,
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:3002:16: error: 'piecewise_constant_distribution' has not been declared
3002 | piecewise_constant_distribution<_RealType>& __x)
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:3002:47: error: expected ',' or '...' before '<' token
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:3001:5: error: redefinition of 'template<class _RealType, class _CharT, class _Traits> std::basic_istream<_CharT, _Traits>& operator>>(std::basic_istream<_CharT, _Traits>&, int)'
3001 | operator>>(std::basic_istream<_CharT, _Traits>& __is,
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:3031:34: error: expected initializer before '<' token
3031 | piecewise_linear_distribution<_RealType>::param_type::
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:3071:7: error: 'piecewise_linear_distribution' does not name a type
3071 | piecewise_linear_distribution<_RealType>::param_type::
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:3088:7: error: 'piecewise_linear_distribution' does not name a type
3088 | piecewise_linear_distribution<_RealType>::param_type::
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:3105:7: error: 'piecewise_linear_distribution' does not name a type
3105 | piecewise_linear_distribution<_RealType>::param_type::
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:3125:16: error: expected nested-name-specifier before 'piecewise_linear_distribution'
3125 | typename piecewise_linear_distribution<_RealType>::result_type
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:3125:16: error: too many template-parameter-lists
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:3163:7: error: too many template-parameter-lists
3163 | piecewise_linear_distribution<_RealType>::
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:3177:22: error: 'piecewise_linear_distribution' does not name a type
3177 | const piecewise_linear_distribution<_RealType>& __x)
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:3177:51: error: expected ',' or '...' before '<' token
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:3176:5: error: redefinition of 'template<class _RealType, class _CharT, class _Traits> std::basic_ostream<_CharT, _Traits>& operator<<(std::basic_ostream<_CharT, _Traits>&, int)'
3176 | operator<<(std::basic_ostream<_CharT, _Traits>& __os,
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:3208:16: error: 'piecewise_linear_distribution' has not been declared
3208 | piecewise_linear_distribution<_RealType>& __x)
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:3208:45: error: expected ',' or '...' before '<' token
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:3207:5: error: redefinition of 'template<class _RealType, class _CharT, class _Traits> std::basic_istream<_CharT, _Traits>& operator>>(std::basic_istream<_CharT, _Traits>&, int)'
3207 | operator>>(std::basic_istream<_CharT, _Traits>& __is,
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:3235:5: error: 'seed_seq' does not name a type
3235 | seed_seq::seed_seq(std::initializer_list<_IntType> __il)
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:3244:5: error: 'seed_seq' does not name a type
3244 | seed_seq::seed_seq(_InputIterator __begin, _InputIterator __end)
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:3256:5: error: 'seed_seq' has not been declared
3256 | seed_seq::generate(_RandomAccessIterator __begin,
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc: In function 'void generate(_RandomAccessIterator, _RandomAccessIterator)':
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:3259:24: error: expected nested-name-specifier before 'iterator_traits'
3259 | typedef typename iterator_traits<_RandomAccessIterator>::value_type
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:3259:39: error: expected initializer before '<' token
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:3268:26: error: '_M_v' was not declared in this scope
3268 | const size_t __s = _M_v.size();
c:\t_drive\arduino-1.8.19\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\bits\random.tcc:3383:1: error: expected declaration before '}' token
3383 | } // namespace
Error compiling for board Teensy 4.0.
