Results 1 to 15 of 15
Thread: Guitar Distortion Effect using waveshape and Teensy 4.0 with Audio Shield
    Member lsrichard's Avatar
    Mar 2020
    Costa Mesa, CA
    22
    First I would like to thank Kenny Peng for coding the waveshape example that I could build from.
    I wanted to experiment with the waveshape effect in Teensy Audio for use with electric guitar and organ.
    I found that is was best to test the math I would be using and visualize the shape curves first with the Processing 3 program.
    I started with the sin function making a curve shape that is essentially a triangle wave to sine wave converter.
    Then I applied the sin function on it self by putting the shape array thru the sin function again.
    I continued to do this again up to 8 times.
    The result is progressively sharper curves for waveshape.
Name:	Quad sin small.jpg
    With that done I converted the code to Arduino C for use with the Teensy 4.0 with Audio Shield.
    I also added a power supply, a one transistor impedance buffer to the Audio Shield input and true bypass wiring to the circuit of the pedal.
    This actually sounds pretty good for a guitar distortion effect.
    It will get progressively more noisy at the higher settings but is still a useful effect.
    It has the ability to be clean on most settings as long as you turn down the guitar volume enough and play very lightly or be a heavy lead distortion when you turn it up and play more heavily.
    It is also useful on keyboards to give that organ patch a bit of a grind sound.
    I will try different algorithms to apply different shapes in the future but this is enough for now.
    Code for Arduino:
    // Up to 8 x Sin function for guitar distortion effect
    // Thanks to Kenny Peng for making the waveshape example that I could build from
    #include <SerialFlash.h>
    AudioInputI2S            i2s1;           //xy=97,52
    AudioEffectWaveshaper    waveshape1;     //xy=271,33
    AudioEffectWaveshaper    waveshape2;     //xy=271,71
    AudioOutputI2S           i2s2;           //xy=436,51
    AudioConnection          patchCord1(i2s1, 0, waveshape1, 0);
    AudioConnection          patchCord2(i2s1, 1, waveshape2, 0);
    AudioConnection          patchCord3(waveshape1, 0, i2s2, 0);
    AudioConnection          patchCord4(waveshape2, 0, i2s2, 1);
    AudioControlSGTL5000     sgtl5000_1;     //xy=252,111
    float myWaveshape2[32769]; // array 1 // full sin function
    float fi; // adjusted float version of i int
    float ds16 = 8; // 1000 mutiplier of sin function result
    float d16; // result of sin function math after multiplier
    float dgain = 1; // amplitude of sin function result
    const float pi = 3.141592654; // pi
    float lg [32769]; // array 2 // re-applied sin function
    float fv; // fv for re-aplication of sin function
    float knob_A1;// re aplication control knob // 20KB used
    float avg_A1;// average of knob
    unsigned int n; // counter for averaging ect.
    byte smode; // re-application mode 0 to 7
    byte oldsmode; // old smode to check and do NewShape(); only one time after smode changes.
    // switch to an analog pot divided down to 0 thru 7 // Use A1 pin 15 analog input with 10kB or 25kB pot
    //const int switchPin2 = 2; // pin number switch 2
    //const int switchPin3 = 3; // pin number switch 3
    //const int switchPin4 = 4; // pin number switch 3
      //Serial.begin(115200); // only needed for serial monitor
      AudioMemory(12);
      analogReadResolution(12); // read will be 0 to 4095 if set to (12).
      //pinMode(switchPin2, INPUT_PULLUP); // switch 2
      //pinMode(switchPin3, INPUT_PULLUP); // switch 3
      //pinMode(switchPin4, INPUT_PULLUP); // switch 3
      //int reading0 = ! digitalRead(switchPin2);
      //int reading1 = ! digitalRead(switchPin3);
      //int reading2 = ! digitalRead(switchPin4);
      //smode = (reading2 * 4) + (reading1 * 2) + reading0;// three bit 01234567
      knob_A1 = (float)analogRead(A1);// Selector 0 thru 7 divide by 596
      smode = round ( knob_A1 / 596 );// must be rounded and 0 to 7
      NewShape();// this is all that is needed for first setup
      sgtl5000_1.enable();
      sgtl5000_1.lineInLevel(11); // Optimal for 480mV_p-p signal
      sgtl5000_1.lineOutLevel(25); // Under 25 causes soft clipping
      //Serial.print(smode);
    }// setup
      knob_A1 = (float)analogRead(A1); // Read 20KB pot
      avg_A1 = avg_A1 + knob_A1; // add for 32 loops
      if ((n & 31) == 31) { // use if ((n & 31) == 31) will average 32 times should be enough // act when (n & 31) == 31 ( 5 bits high )
          avg_A1 = avg_A1 / 32; //average of 32 knob readings
          smode = round ( avg_A1 / 596 ); // round and divide down to 0 to 7 for switch function
          avg_A1=0; //reset avg after use
      } // if (n&31) == 31
      //ReadSwitches();
      if (smode != oldsmode) NewShape(); // only act if "smode" changed // if conditional so it only do this subroutine one time after "smode" changes
      ++n; // n counter for avg
      n=n & 1023; // 10 bit roll over to 0
    } // MAIN LOOP
    void NewShape(void){
      oldsmode = smode; // this is for the if conditional so it only do this subroutine one time after "smode" changes
      for (int i=0; i<32769; i++) {
        fi = i + 16384; // float needed for math to be correct // 16384 is starting point at top of sine
        d16 = sin( pi * ( fi / 32768 )) * ( ds16 * 1000 ); // fi/32768 to give middle 1/2 cycle starting the peak of the sine.
        myWaveshape2[i] = round( d16 * dgain ); // round and gain
        myWaveshape2[i]= -(myWaveshape2[i]/8000); // needed math to divide back to -1.0 to 1.0
      } //for i
        fv=myWaveshape2[i]*16384; // set fv for re-aplication of sin function
        d16 = sin( pi * ( fv / 32768 )) * ( ds16 * 1000 );// sin function
        lg[i] = round( d16 * dgain ); // round and gain
        lg[i]= lg[i]/8000; // needed math to divide back to -1.0 to 1.0
      } // for
    //Serial.println(reading0);
    //Serial.println(reading1);
    //Serial.println(reading2);
    //Serial.println(smode);
      switch (smode){
        case 0 : // Full sin function
            lg[i]=(myWaveshape2[i]);// just transfer full sin fuction shape
          } // for
        case 1 : // Double sin function
          // nothing needed here // really do nothing for case 1 // uses lg[] defalt double sin function shape
        case 2 : // Triple sin function
          SinReAp();// 3rd re-aplication of sin function
        case 3 : // Quad sin function
          SinReAp();// 4th re-aplication of sin function
        case 4 : // 5x sin function
          SinReAp();// 5th re-aplication of sin function
        case 5 : // 6x sin function
          SinReAp();// 6th re-aplication of sin function
        case 6 : // 7x sin function
          SinReAp();// 7th re-aplication of sin function
        case 7 : // 8x sin function
          SinReAp();// 8th re-aplication of sin function
      }// switch
    waveshape1.shape(lg, 32769);// shape implementation L
    waveshape2.shape(lg, 32769);// shape implementation R
      //sgtl5000_1.enable(); // do not need to re-enable // this makes it cut out for a second if used
      //sgtl5000_1.lineInLevel(11); // Optimal for 480mV_p-p signal // no need to re-do
      //sgtl5000_1.lineOutLevel(25); // Under 25 causes soft clipping // no need to re-do
    } // NewShape
    void SinReAp(void){
        fv=lg[i]*16384; // set fv re-aplication of sin function as many times as needed
      } // for
    } // SinReAp
    //void ReadSwitches(void){
    //  int reading0 = ! digitalRead(switchPin2);
    //  int reading1 = ! digitalRead(switchPin3);
    //  int reading2 = ! digitalRead(switchPin4);
    //  smode = (reading2 * 4) + (reading1 * 2) + reading0;// three bit 01234567 // three separate bit binary to byte convert
    //} // ReadSwitches
    Attached Files Attached Files
    Mar 2020
    Costa Mesa, CA
    22
    I am adding the Processing 3 code to visualize the curves i used with waveshape.
    Do not compile this code in Adruino without converting it first.
    This Code is for Pocessing 3.
    // For Guitar Distortion using Teensy 4.0 with Audio Shield
    // Re-Applied sin function for WaveShape
    // NOTE: THIS IS A PROCESSING PROGRAM DO NOT SAVE OR COMPILE IN ARDUINO
    // TO CONVERT TO ARDUINO FROM PROCESSING PROGRAM:
     // change array syntax [32769] and no (float [] lg ;)
     // remove path and PShape commands
     // add library links and Audio connections
     // remove secondary array definition from setup
     // add Serial.begin(115200); and AudioMemory(12); to setup
     // remove all "size" commands.
     // remove all "path" commands.
     // remove "draw()" subroutine.
     // add waveshape1.shape(myWaveshape2, 32769); to end of setup
     // add waveshape2.shape(myWaveshape2, 32769); to end of setup
     // add sgtl5000_1.enable(); to end of setup
     // add sgtl5000_1.lineInLevel(15); to end of setup
     // add sgtl5000_1.lineOutLevel(25); to end of setup
     // add main loop
     * PathPShape
     * A simple path using PShape
    // A PShape object
    PShape path;
    float [] myWaveshape2 ; // array
    float fi;
    float ds16 = 8;
    float d16;
    float dgain = 1;
    float [] lg ; // array
    int smode = 7;
    float fv;
      size(640, 360, P2D);
      myWaveshape2 = new float[32769]; // further define array
      path = createShape();
      NewShape();
    } // setup
    void draw() {
      delay(2000);
      background(0,0,0); // background color
      path.setStroke(color(0,255,0));// red, green, blue // line color
      translate(50, 150); // location of shape
      shape(path);// draw shape
      textSize(24);
      fill(255, 191, 0);// amber text // text color
      switch (smode){
          case 0 :
            NewShape();
            text("Full sin function",110, -125);
          case 1 :
            NewShape();
            text("Double sin function",110, -125);
          case 2 :
            NewShape();
            text("Triple sin function",110, -125);
          case 3 :
            NewShape();
            text("Quad sin function",110, -125);
          case 4 :
            NewShape();
            text("x5 sin function",110, -125);
          case 5 :
            NewShape();
            text("x6 sin function",110, -125);
          case 6 :
            NewShape();
            text("x7 sin function",110, -125);
          case 7 :
            NewShape();
            text("x8 sin function",110, -125);
      }// switch
      textSize(18);
      text("First in array  0", 350, 50);
      text(lg[0], 350, 70);
      text("Last in array 32768",350, 110);
      text(lg[32768], 350, 130);
    }// draw
    void NewShape(){
      smode++;
      if (smode == 8){
      smode=0;
      }// smode==8
      lg = new float[32769];// further define array
      } //for i
      } // for
      switch (smode){
          path.beginShape();
          path.noFill();
          path.stroke(255); // brightness of line
          path.strokeWeight(1); // thickness of line
              path.vertex(i/100,lg[i]*100);// put array into shape named path
              //if (( i & 63 )== 63) {// print every 64th loop
               // print(lg[i]);
               // print(",");
               // if (( i & 511 )== 511)println();
              //}// i & 63
          } // for
          path.endShape();
          path.beginShape();
          path.noFill();
                //print(lg[i]);
                //print(",");
                //if (( i & 511 )== 511)println();
              //}// i & 63
           }// for
          path.endShape();
      }// switch
    //waveshape1.shape(lg, 32769);// shape implementation L
    //waveshape2.shape(lg, 32769);// shape implementation R
    } // NewShape
    void SinReAp(){
      path.beginShape();
      path.noFill();
        //print(lg[i]);
        //print(",");
      //}// i & 63
    } // for
      path.endShape();
    } // SinReAp
    Mar 2020
    Costa Mesa, CA
    22
    Impedance buffer
    This attachment is the impedance buffer I used.
    It is needed because the audio shield input impedance is 29K ohms and the guitar needs it to be higher than that.
    Jul 2020
    2,017
    But it only has about 100k input itself - the 2N3391A's gain is 250 worst case, so the 470 ohm load will be reflected back as low as 117k, in parallel with the bias circuit's 510k resistance gives about 100k. I presume you wanted 500k input impedance for the guitar? A simple opamp follower is good way to buffer a high impedance signal.
    Mar 2020
    Costa Mesa, CA
    22
    You got me curious about what input impedance I was actually getting so I measured it with my scope, generator and a 1 meg pot.
    At 1KHz I measured it at 439k ohms. That buffer circuit should be able to have 446k ohms input impedance but that is close enough for me.
    Jul 2020
    2,017
    Guess you are lucky with the actual gain of those transistors then - I'd have just gone with an opamp in non-inverting mode which has very high input impedance.
    Mar 2020
    Costa Mesa, CA
    22
    Rough demo
    This is a short and rough demo of the waveshape pedal.
    https://soundcloud.com/richard-linge...social_sharing
    Mar 2017
    Canada
    351
    @Isrichard Cool effect! I listened to the Soundcloud recording. I do hear a fair bit of click/clip noise when I listen through headphones. But, it's hard to say if the input to the ADC is clipping, or the digital audio processing is having little jumps that exceed Nyquist.
    For anyone reading this that may be interested, an easy preamp design is to use a TL072 JFET, with split 1M (to get 500K) or split 2M (to get 1M) input impedance. See the schematic on page 20 for a reference.
    https://d3s5r33r268y59.cloudfront.ne...ide_-_v2.2.pdf
    The same preamp design is used in the Teensy based Multiverse. Consider with guitar inputs, you might need a decent amount of gain (passive pickups) to get to the 1vpp for the typical codec, or you might need attenuation if you've got active pickups, or go through a 9V pedal first.
    Mar 2020
    Costa Mesa, CA
    22
    Latency measurement
    I used my scope and generator to do a latency measurement.
    Its latency measured at 6.38ms.
    https://forum.pjrc.com/attachment.ph...&thumb=1&stc=1
    Mar 2020
    Costa Mesa, CA
    22
    New more extensive rough video demo
    One of my repair customers requested to try out the waveshape pedal here at my shop.
    He liked it enough to video it with his phone.
    We ended up making a Youtube video of a more extensive rough demo of the pedal.
    https://youtu.be/acdpXPj55K4
    Aug 2015
    Scotland
    269
    Quote Originally Posted by lsrichard View Post
    6ms is a bit high if you are mixing in a dry signal elsewhere. If you want to reduce the latency cut the number of samples in an audio block down from the default 128.
    Edit .../cores/teensy4/AudioStream.h and change AUDIO_BLOCK_SAMPLES to 16, recompile and re-measure the latency
    cheers, Paul
    Mar 2020
    Costa Mesa, CA
    22
    Latency reduced to 1.3ms
    That works
    Reduced latency to 1.3ms
    Will this change the way the pedal behaves or the way the pedal sounds other than the latency ?
    After I compiled and uploaded it to the pedal I did changed AudioStream.h back to 128 samples for the sake of future projects.
    Aug 2015
    Scotland
    269
    @Isrichard - changing AUDIO_BLOCK_SAMPLES shouldn't change the way the pedal behaves or the sound of your effect at all (other than latency).
    By default the library processes sound in blocks of 128 samples (128 samples at 44.1kHZ = 2.9ms) reducing this just means that audio is processed in smaller chunks (16 samples = 0.3ms). It adds a bit of processing overhead but a teensy 4 has lots of capacity for processing. Most of the objects in the library work with reduced blocks and if they don't they normally fail very noticeably (the only one I've come across that doesn't work well with it is the USB Audio out, there may be others that fail that I haven't come across). Cheers, Paul
    Jul 2020
    2,017
    I think the FFT classes assume 128 blocks
    Aug 2015
    Scotland
    269
    AudioStream.h lists following as problematic with lower block sizes
    - AudioInputUSB, AudioOutputUSB, AudioPlaySdWav, AudioAnalyzeFFT256, AudioAnalyzeFFT1024
