Update: So glad I posted this because obviously now I fixed it. I upped the audio memory from 10 to 12, which just introduced static noise when I was using a 3.6, but I guess the 4.1 has more memory? Anyways, it's all working now.
Hey everyone,
I'm building a super simple music mixer that has 1 button, 4 slide potentiometers, and 5 .wav files. When the button is pressed, all the .wav files will start playing. 1-4 will have their volumes adjustable on the sliders and 5 will be set to a constant volume. Everything is working right now except the first .wav file does not play.
It is easy to mix 4 audio files but in this case, I need 5, so I did this with the audio design tool:
(First I tried just putting the 5th track straight into mixer 5 but for some reason it didn't work. I've tried so many things but I got this to work until it didn't which is why I'm here.)
I'm printing all the slider values and can see they're all working. I've gotten this to work in the past few days but all of a sudden it doesn't work. All my wav files right now, ONE.wav, TWO.wav, THREE.wav, FOUR.wav, FIVE.wav, are the exact same file just renamed. They are 48.4MB, 1411kbps, and 4:48 minutes long. Again, only ONE.wav is not playing when I hit the button.
Here's the code:
Hey everyone,
Here's the code:
HTML:
#include <Arduino.h>
#include <Button.h>
AudioPlaySdWav playSdWav5; //xy=643,497
AudioPlaySdWav playSdWav4; //xy=649,385
AudioPlaySdWav playSdWav2; //xy=652,245
AudioPlaySdWav playSdWav3; //xy=652,310
AudioPlaySdWav playSdWav1; //xy=653,175
AudioMixer4 mix3; //xy=892,504
AudioMixer4 mix2; //xy=897,245
AudioMixer4 mix1; //xy=898,351
AudioMixer4 mix4; //xy=898,633
AudioMixer4 mix5; //xy=1110,289
AudioOutputI2S headphones; //xy=1316,294
AudioConnection patchCord1(playSdWav5, 0, mix3, 0);
AudioConnection patchCord2(playSdWav5, 1, mix4, 0);
AudioConnection patchCord3(playSdWav4, 0, mix2, 3);
AudioConnection patchCord4(playSdWav4, 1, mix1, 3);
AudioConnection patchCord5(playSdWav2, 0, mix2, 1);
AudioConnection patchCord6(playSdWav2, 1, mix1, 1);
AudioConnection patchCord7(playSdWav3, 0, mix2, 2);
AudioConnection patchCord8(playSdWav3, 1, mix1, 2);
AudioConnection patchCord9(playSdWav1, 0, mix2, 0);
AudioConnection patchCord10(playSdWav1, 1, mix1, 0);
AudioConnection patchCord11(mix3, 0, mix5, 2);
AudioConnection patchCord12(mix2, 0, mix5, 0);
AudioConnection patchCord13(mix1, 0, mix5, 1);
AudioConnection patchCord14(mix4, 0, mix5, 3);
AudioConnection patchCord15(mix5, 0, headphones, 0);
AudioConnection patchCord16(mix5, 0, headphones, 1);
AudioControlSGTL5000 audioShield; //xy=1128,416
#define SDCARD_CS_PIN 10
#define SDCARD_MOSI_PIN 7
#define SDCARD_SCK_PIN 14
#define NUM_SENSORS 4
const int sliderPins[NUM_SENSORS] = { A14, A15, A16, A17 };
double gains[NUM_SENSORS];
int potValues[NUM_SENSORS];
#define buttonPin1 0
Button button1(buttonPin1);
Serial.begin(9600); // Starts the serial communication
button1.begin();
AudioMemory(10);
audioShield.enable();
audioShield.volume(0.85);
mix1.gain(0, 0.4);
mix1.gain(1, 0.4);
mix1.gain(2, 0.4);
mix1.gain(3, 0.4);
mix2.gain(0, 0.4);
mix2.gain(1, 0.4);
mix2.gain(2, 0.4);
mix2.gain(3, 0.4);
mix5.gain(0, 0.8);
mix5.gain(1, 0.8);
mix5.gain(2, 0.8);
mix5.gain(3, 0.8);
mix3.gain(0, 0.1);
mix4.gain(0, 0.1);
SPI.setMOSI(SDCARD_MOSI_PIN);
SPI.setSCK(SDCARD_SCK_PIN);
// stop here, but print a message repetitively
while (1) {
//Serial.println("Unable to access the SD card");
for (int i = 0; i < NUM_SENSORS; i++) {
potValues[i] = analogRead(sliderPins[i]);
gains[i] = (potValues[i] * 1.0) / 1023.0;
Serial.print(gains[i]);
Serial.print("\t");
Serial.print(AudioMemoryUsageMax());
Serial.print("\t");
mix1.gain(0, gains[0]);
mix1.gain(1, gains[1]);
mix1.gain(2, gains[2]);
mix1.gain(3, gains[3]);
mix2.gain(0, gains[0]);
mix2.gain(1, gains[1]);
mix2.gain(2, gains[2]);
mix2.gain(3, gains[3]);
mix3.gain(0, .1);
mix4.gain(0, .1);
if (button1.pressed()) {
playSdWav1.play("ONE.wav");
delay(10); // wait for library to parse WAV info
playSdWav2.play("TWO.wav");
playSdWav3.play("THREE.wav");
playSdWav4.play("FOUR.wav");
playSdWav5.play("FIVE.wav");
// if (playSdWav1.isPlaying() == false) {
// //Serial.println("Start playing 1");
// playSdWav1.play("ONE.wav");
// delay(10); // wait for library to parse WAV info
// if (playSdWav2.isPlaying() == false) {
// //Serial.println("Start playing 2");
// playSdWav2.play("TWO.wav");
// if (playSdWav3.isPlaying() == false) {
// //Serial.println("Start playing 3");
// playSdWav3.play("THREE.wav");
// if (playSdWav4.isPlaying() == false) {
// //Serial.println("Start playing 4");
// playSdWav4.play("FOUR.wav");
// if (playSdWav5.isPlaying() == false) {
// playSdWav5.play("FIVE.wav");
