PJRC Teensy 4.0 Beta Breakout Board and Audio Adapter Version D compatible ?
A quick question. Was using the PJRC Teensy 4.0 beta version breakout board with a couple of audio adapter version D. Cannot access SD card on audio adapter with WavFilePlayer. Tried various SPI settings with no luck. Version B Audio adapter works fine. Both of the version D adapters work fine with the T4.1 breakout board. Searched the vast forum but could not find anything obvious Using Arduino 1.8.19 and TD 1.59B2...
Version D responds with:
Unable to access the SD card
That breakout board is wired for Rev B or Rev C. At the time it was made (mid 2019), Rev B was the latest version.
Rev D won't work (unless wires are used to route the signals where needed).
Thanks, kinda what I suspected. Just wanted to make sure I was not missing something.
Senior Member+
yeah - the breakout socket re-routed for T_4.0 to have audio with Rev B/C was ... 'unique'
- You may not post replies
- You may not edit your posts
Forum Rules
