Results 1 to 6 of 6
Thread: Help with pot - linear vs audio
    Jan 2020
    9
    I've received a load of these slide potentiometers from here: https://www.mouser.co.uk/ProductDeta...pI22NVZw%3D%3D
    As you can see on the link, these are linear potentiometers. However, when I read them with the Teensy's ADC I get what look very like audio/log values.
    Can someone give me a sanity check here, as I'm really confused how this could be the case - I've checked this model on some other major suppliers website and it's also listed as linear. Is it possible that some sort of wiring issue could cause some sort of non-linearality with a linear pot (I'm thinking no, or at least not without the output being essentially noise)?
    Here is the code I'm testing with: very vanilla (just a built in Arduino IDE example:
    // These constants won't change. They're used to give names to the pins used:
    const int analogInPin = A0; // Analog input pin that the potentiometer is attached to
    const int analogOutPin = 9; // Analog output pin that the LED is attached to
    int sensorValue = 0; // value read from the pot
    int outputValue = 0; // value output to the PWM (analog out)
    // initialize serial communications at 9600 bps:
    // read the analog in value:
    sensorValue = analogRead(analogInPin);
    // map it to the range of the analog out:
    outputValue = map(sensorValue, 0, 1023, 0, 255);
    // change the analog out value:
    analogWrite(analogOutPin, outputValue);
    // print the results to the Serial Monitor:
    Serial.print("sensor = ");
    Serial.print(sensorValue);
    Serial.print("\t output = ");
    Serial.println(outputValue);
    // wait 2 milliseconds before the next loop for the analog-to-digital
    // converter to settle after the last reading:
    delay(2);
    Senior Member PaulS's Avatar
    Apr 2015
    Netherlands
    1,253
    This fader comes in 2 resistance taper flavors: with audio taper or with linear taper. See this table:
    If it is really a linear fader, you should read a sensorValue of ~0 at one end, ~1023 at the other end and ~512 in the middle.
    The Mouser link refers to: PTB0153-2010BPB103. That should be a 10K linear taper. Do you see that part# somewhere on the housing?
    Paul
    PS: how did you wire this fader to the Teensy?
    Jul 2020
    2,017
    Check the pinout. Fader pinouts are not intuitive, you need to check them.
    Apr 2015
    Netherlands
    1,253
    Ran your code on a home-made MIDI-controller with 100mm linear ALPS faders [exact same pinout as your Bourns faders].
    The sensorValue values look very linear in relation to the position of the faderknob.
    Fader pin 1 connected to Teensy GND, fader pin 2 connected to Teensy pin A0(14), fader pin 3 connected to Teensy pin 3V3.
    Paul
    Don't forget to disable the digital input hysteresis.
    https://forum.pjrc.com/threads/69671...-Analog-Inputs
    Apr 2015
    Netherlands
    1,253
    Quote Originally Posted by SmashedTransistors View Post
    Good suggestion when using a Teensy 4.x.
    In my quick test above, a Teensy LC was used so this is not applicable.
    But not knowing which Teensy the OP used, it might be useful. Although I doubt in his case this solves his issues seen.
    Paul
