Page 5 of 5 FirstFirst ... 3 4 5
Results 101 to 123 of 123
Thread: teensy 3 MAC address
  1. #101
    Quote Originally Posted by manitou View Post
    Using ubuntu 16.04, IDE 1.8.8/1.37 on T3.6@180mhz, works for me with Fast Faster or Fastest using Frank's example
    #include <TeensyMAC.h>
      Serial.printf("Serial: %u\n", teensySerial());
      Serial.printf("MAC: 0x%012llX\n", teensyMAC());
    MAC: 0x04E9E5032337
    Serial: 2056230
    MAC: 0x04E9E5032337
    Serial: 2056230
    MAC: 0x04E9E5032337
    Serial: 2056230
    MAC: 0x04E9E5032337
    Serial: 2056230
    still works after unplugging/plugging USB cable.
    Tested on 2 different T3.6
    wow, this is super strange
    so, the only thing I have different is some data saved in the eeprom
    I will try to erase the entire eeprom and test again, but this is really funny...
  2. #102
    Senior Member+ manitou's Avatar
    Join Date
    Jan 2013
    Posts
    2,235
    perhaps you should post the sketch that is failing. And does the simple sketch above work for you ?
  3. #103
    Join Date
    Jan 2013
    Posts
    2,235
    Yeah, verily. the following sketch on T3.6@180mhz exhibits the bad behavior you describe.
      eeprom perf (cycle power to confirm)
    #include <EEPROM.h>
    unsigned long t;
      int i,val,errs=0;
      Serial.begin(9600); while(!Serial); delay(5000);
      Serial.print("EEPROM length: ");
      Serial.println(EEPROM.length());
      Serial.println("initial read");
    	for (i=0;i<100;i++) {
    		val = EEPROM.read(i);
    		if (val != i) {
    			Serial.print(val);
    			Serial.print(" should be ");
    			Serial.println(i);
          errs++;
      Serial.print("read errs "); Serial.println(errs);
    #if 0
    	t=micros();
    	for (i=0;i<100;i++) EEPROM.write(i, i);
    	t=micros()-t;
    	Serial.print("write "); Serial.println(t);
    	int i,val;
    	t=micros();
    	for (i=0;i<100;i++) val = EEPROM.read(i);
    	t=micros()-t;
    	Serial.print("100 reads (us) "); Serial.println(t);
     Serial.println(val);  // reference val
    	delay(2000);
    it runs correctly after compile/upload, but unplug/plug USB results in trailing 00's in MAC ?
    (you need to run it once with EEPROM write block enabled #if 1 if you want to pass my EEPROM read check in loop())
    I don't know why it fails with EEPROM (doesn't fail @120mhz)
    Frank's system register 0x40041000 reads 0 after the unplug/plug, instead of having the stored value of the MAC ?
  4. #104
    Senior Member+ KurtE's Avatar
    Join Date
    Jan 2014
    Posts
    5,690
    The sketch also works on my MAC running Mac Sierra Tried faster and Fastest with LTO at 180mhz. Also tried modifying and retrieved the serial number and MAC as first lines in code before Serial.begin()...
    Is there anything else different about your hardware? Like are you powering from USB or is there external power turning it on and off?
  5. #105
    Senior Member PaulStoffregen's Avatar
    Join Date
    Nov 2012
    Posts
    20,753
    Quote Originally Posted by lorenzofattori View Post
    You could have save us quite a bit of time, and had an answer much sooner, if only you had posted the actual code you were really using!
    This is why we have the "Forum Rule" about posting complete code. Please, follow this rule. It really is easy to post your *actual* code, and it really does make helping you much easier and faster.
  6. #106
    Quote Originally Posted by PaulStoffregen View Post
    Sorry Paul, I didn't want to upset you. I always try to post the code, but this time the code is the same of Frank's library.
    on post #90 I said that both teensy have something stored in the eeprom, but it's not used in the current Sketch
    I will try to wipe the eeprom and see if something changes
    Update: tried to clear the EEPROM with eeprom_clear but still not behaving correctly using Frank's code.
    Tested on Ubuntu with arduino 1.8.3 and teensyduino 1.37
    @KurtE: for this test is just teensy 3.6 with nothing connected, powered (and serial) over usb
  7. #107
    Join Date
    Nov 2012
    Posts
    20,753
    Ok, I've put this one on my list of bugs to investigate.
  8. #108
    Join Date
    Jan 2013
    Posts
    2,235
    the sketch in post #103 exhibits the strange behavior ...
    the smallest test case is to just add #include <EEPROM.h> to Frank's small sketch
  9. #109
    So you confirm you get the same behavior when using eeprom?
  10. #110
    Join Date
    Jan 2013
    Posts
    2,235
    well, upon further review, Frank's sketch
    on T3.6@180mhz works after compile/upload, but if you unplug/plug in USB power, then it reports 0 in lower bytes of MAC. (with no EEPROM refs). @120mhz MAC value is good across power cycles. ? this contradicts what i was getting in earlier posts??, using 1.8.3/1.37.
    EDIT: from the K66 beta test thread, this function
    void mactst() {
        uint64_t num64;
        uint32_t num;
        __disable_irq();
          FTFL_FSTAT = FTFL_FSTAT_RDCOLERR | FTFL_FSTAT_ACCERR | FTFL_FSTAT_FPVIOL;
        *(uint32_t *)&FTFL_FCCOB3 = 0x41070000;
        FTFL_FSTAT = FTFL_FSTAT_CCIF;
        while (!(FTFL_FSTAT & FTFL_FSTAT_CCIF)) ; // wait
        num64 = *(uint64_t *)&FTFL_FCCOB7;
        __enable_irq();
        num = num64;
        Serial.println(num,HEX);
        num = num64>>32;
    properly prints the MAC address across power cycles @180mhz (though i actually had remembered that it did not work @180mhz)
    EDIT: ARGH On another T3.6@180mhz, the simple sketch is working across power cycles ???? now i'm really confused.
    ? It will fail if EEPROM.h is present @180mhz, BUT after that, it fails across power cycles, even with EEPROM.h removed???
    this is getting above my pay grade
  11. #111
    Senior Member+ defragster's Avatar
    Join Date
    Feb 2015
    Posts
    10,059
    @Manitou : How is the 'Power Cycle' done if not pulling USB? Perhaps a warm reset/restart?
    Where does the TeensyMAC.h in use come from?
    Before Paul did the edit for T_3.6's MAC under HSRUN I discovered the MAC could be read before HSRUN was enabled, once the MCU does that it is cached so a failure returns what was there on subsequent calls. That could explain it surviving until power loss, assuming re-programming is not HSRUN speed and leaves the value in the process - and that area isn't cleared.
  12. #112
    Join Date
    Jan 2013
    Posts
    2,235
    Quote Originally Posted by defragster View Post
    yes, by power-cycling i meant, closing the monitor, pulling the USB cable, then plugging it back in, and enabling the monitor.
    Frank's TeensyMAC https://github.com/FrankBoesing/TeensyMAC
    EEPROM.h does an init() that messes with the FTFL stuff as i recall
  13. #113
    void mactst() {
        uint64_t num64;
        uint32_t num;
        __disable_irq();
        __enable_irq();
        num = num64;
        num = num64>>32;
    I will give it a try with my code and see
  14. #114
    will be back on this issue in the next days, any chance that you already had a look on that?
    Thanks
    Lorenzo
  15. #115
    @Paul, any chance you had a look on it? after a lot of months I now need to continue with this project and I was wondering to use the mac or serial for some security checking.
    Thanks
    Lorenzo
  16. #116
    void mactst() {
        uint64_t num64;
        uint32_t num;
        __disable_irq();
        __enable_irq();
        num = num64;
        num = num64>>32;
    After a looong time I finally had time to test it, and the code posted here fixes the eeprom bug. thanks
  17. #117
    Senior Member brtaylor's Avatar
    Join Date
    Mar 2016
    Location
    Portland, OR
    Posts
    537
    With Teensy 3.6 at any CPU setting above 120 MHz, running this code (https://github.com/FrankBoesing/Teen.../PrintInfo.ino) and library (https://github.com/FrankBoesing/TeensyMAC) works fine if the code is uploaded via USB; however, on power cycles (i.e. unplugging and re-plugging the USB cable) results in 0 for the serial and an incorrect mac address. Arduino version 1.8.9 and Teensyduino 1.46 on Linux Debian 9.
  18. #118
    Join Date
    Feb 2015
    Posts
    10,059
    Certain T_3.6 elements - EEPROM I recall - are inaccessible over 120 MHz when the CPU is overvolted for High Speed Run operation. There is a system call to drop speed& voltage - make the call - then return the voltage&speed:
    kinetis_hsrun_disable();
    // over 120 MHz restriced access
    kinetis_hsrun_enable();
    This drops the voltage and the CPU to 120 MHz between those calls. Certain system clocks will be changed with this and some buses will not function properly if active resulting in missed data - Serial UART ports was one for instance.
    If more info is needed Paul probably left more distinct notes in the forum try search for :: kinetis_hsrun_
  19. #119
    Join Date
    Jan 2013
    Posts
    2,235
    Quote Originally Posted by brtaylor View Post
    here is the sketch I use https://github.com/manitou48/teensy3...ter/getmac.ino
  20. #120
    Join Date
    Mar 2016
    Location
    Portland, OR
    Posts
    537
    Awesome, I can confirm that works. Thanks!
  21. #121
    Join Date
    Jan 2013
    Posts
    2,235
    hmmm, i just ran it on T3.6 and it seems to repeat the first 3 bytes ... need to find my working copy
    maybe this
    void prmac() {
        uint64_t num64;
        uint32_t num;
        __disable_irq();
        __enable_irq();
        num = num64;
        num = num64>>32;
  22. #122
    Join Date
    Mar 2016
    Location
    Portland, OR
    Posts
    537
    maybe this
    void prmac() {
        uint64_t num64;
        uint32_t num;
        __disable_irq();
        __enable_irq();
        num = num64;
        num = num64>>32;
    You're right, now that I take a closer look - the bytes are repeated.
    The prmac function seems to work fine.
  23. #123
    Join Date
    Feb 2015
    Posts
    10,059
    I just went back to this thread: https://forum.pjrc.com/threads/57595...ess-Teensy-4-0 - helped get user to find T4 Serial# - but updated T4 code wasn't integrated back to TeensyID yet.
    It links to this : https://github.com/sstaub/TeensyID - that should work for T3.x and T_LC
    I haven't tested - assume it works. Not sure if it does anything differently.
    As posted on that thread - I pulled the startup code PJRC uses to get the Serial# - that is in the T_3 cores too. Not sure if it does anything differently.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
