* A basic toy send example.
* This example is part of the TeensyDMX library.
* (c) 2019-2020 Shawn Silverman
#include <TeensyDMX.h>
namespace teensydmx = ::qindesign::teensydmx;
// Pin for enabling or disabling the transmitter.
// This may not be needed for your hardware.
constexpr uint8_t kTXPin = 17;
// Create the DMX sender on Serial1.
teensydmx::Sender dmxTx{Serial1};
// Data for 3 channels.
uint8_t data[3]{0x44, 0x88, 0xcc};
// Turn on the LED, for indicating activity
pinMode(LED_BUILTIN, OUTPUT);
digitalWriteFast(LED_BUILTIN, HIGH);
// Set the pin that enables the transmitter; may not be needed
pinMode(kTXPin, OUTPUT);
digitalWriteFast(kTXPin, HIGH);
// Set some channel values. These are being set in setup() to
// illustrate that values are 'sticky'. They stay set until changed.
// There's no special function to call for each iteration of loop().
// Set channel 1 to 128
dmxTx.set(1, 128);
// Set channels 10-12 to the 3 values in 'data'
dmxTx.set(10, data, 3);
// Call this after setting up the channel contents if you want to
// guarantee that the values are used as the initial contents;
// transmission doesn't start until after begin() is called.
// If it doesn't matter, begin() can be called before setting the
// channel contents.
dmxTx.begin();
// Do something, maybe alter channel values.
