I2C Communication
ddtav478
Hello,
I have a joystick and gimbal combination where a teensy 4.0 board is attached to the joystick for button inputs while the gimbal has a arduino nano (similar) board attached to the gimbal. The teensy has 23 buttons attached to the joystick and I'm trying to figure out how I can get the teensy to talk to the arduino over I2C to take button inputs as well as gimbal inputs from a magnet based x and y sensor. Here is the code for the teensy
#include <i2c_device.h>
#include <i2c_driver.h>
#include <i2c_driver_wire.h>
#include "i2c_register_slave.h"
int pins[] = {0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 14, 15, 16, 17, 20, 21, 22, 23, 24, 26};
 for (int i = 0; i < 23; i++){
 pinMode(pins[i], INPUT_PULLUP);
 Wire.begin(1);
    Serial.print(digitalRead(pins[i]));
    Serial.print("\t");
delay(5);
I'm trying to get the teensy (slave) to talk to the arduino (master) to hopefully take those inputs and read as a joystick. I haven't really figured out the master code for the arduino as I have been using examples to get going and haven't really gotten far. The code for the teensy basically takes all the inputs from the buttons and prints them as serial data but I haven't been able to get it across to the arduino over i2C.
I posted this question in the aruduino forums and they were pretty much no help.
#include "i2c_driver.h"
#include <i2c_register_slave.h>
 Wire.begin();
    Serial.print("\t");
    Wire.beginTransmission(1);
    Wire.write(digitalRead(pins[i]));
    Wire.endTransmission(false);
delay(5);
So I fixed the code a little. Had to add a wire.endtranmission in there.
This is the slave device, it is very generic but I got it to communicate.
// Wire Slave Receiver
// by Nicholas Zambetti <http://www.zambetti.com>
// Demonstrates use of the Wire library
// Receives data as an I2C/TWI slave device
// Refer to the "Wire Master Writer" example for use with this
// Created 29 March 2006
// This example code is in the public domain.
  Wire.begin(1);                // join I2C bus with address #8
  Wire.onReceive(receiveEvent); // register event
  Serial.begin(9600);           // start serial for output
  delay(5);
// function that executes whenever data is received from master
// this function is registered as an event, see setup()
void receiveEvent(int howMany) {
  while (1 < Wire.available()) { // loop through all but the last
    char c = Wire.read(); // receive byte as a character
    Serial.print("\t");
    Serial.print(c);         // print the character
  int x = Wire.read();    // receive byte as an integer
  Serial.println(x);         // print the integer
   Serial.print("\t");
Now I can see the serial printout. I'm trying to get it in the same format as the master device.
