I'm using Arduino 1.8.19 / Teensyduino 1.56 to code a custom PCB which has a Teensy 4.1 and 3 external MCP4922 dual channel DACs. The code is meant to take a buffer of data and send it to the appropriate DAC/channel. There is no receive part back to the Teensy.
I had previously adapted code from a different project to send data to the DACs using SPI and DMA on Teensy 3.2, but having made a new version of the PCB with Teensy 4.1, I have been having trouble porting the code. I have got it working using just SPI, but I'm going around in circles with the DMA part after many hours reading the reference manual, trying to find examples and info from others doing a similar project.
I am posting part of the schematic and a simplified chunk of code to show where I'm up to (it should just be the DMA configuration bits which need checking). Any help would be gratefully received (or if anyone has an example of code for Teensy 4.1 using SPI and DMA to write to external MCP4xxx DACs, then I could try to use that too).
#include <DMAChannel.h>
DMAChannel spi_dma(false);
#define SPI_DMA_MAX 4096
static uint32_t spi_dma_q[2][SPI_DMA_MAX] __attribute__((aligned(32))); // Double buffer
static unsigned spi_dma_which; // Which buffer is being processed
static unsigned spi_dma_count; // How full the buffer is
//static unsigned spi_dma_in_progress; // DMA in progress flag
volatile int spi_dma_in_progress; // DMA in progress flag
// Not sure how these are allocated, or if they're correct, but they function on Teensy 3.2
#define SPI_DMA_CS_IC3 0
#define SPI_DMA_CS_IC5 1
#define SPI_DMA_CS_IC4 2
// Teensy 4.1 SS pins connected to DACs
const int SS0_IC5 = 8;
const int SS1_IC4 = 6;
const int SS1_IC3 = 22;
#define SDI 11
#define SCK 13
#define DELAY_PIN 7
#define IO_PIN 5
// settings
static int OFF_SHIFT = 5;
static int OFF_DWELL0 = 0;
static int OFF_DWELL1 = 2;
static int OFF_DWELL2 = 2;
static int NORMAL_SHIFT = 2;
static uint16_t x_pos;
static uint16_t y_pos;
#define DAC_CHAN_A 0
#define DAC_CHAN_B 1
static int DAC_X_CHAN = 1;
static int DAC_Y_CHAN = 0;
#define MAX_PTS 3000
static unsigned rx_points;
static unsigned num_points;
typedef struct ColourIntensity {
uint8_t red;
uint8_t green;
uint8_t blue;
} ColourIntensity_t;
static ColourIntensity_t LastColInt;
// Chunk of data to process using DMA or SPI
typedef struct DataChunk {
uint16_t x;
uint16_t y;
uint8_t red;
uint8_t green;
uint8_t blue;
} DataChunk_t;
static DataChunk_t Chunk[MAX_PTS];
#define REFRESH_RATE 20000u
// Set SS pins to 3 DACs to output
pinMode(SS0_IC5, OUTPUT);
digitalWriteFast(SS0_IC5, HIGH);
delayNanoseconds(100);
pinMode(SS1_IC4, OUTPUT);
digitalWriteFast(SS1_IC4, HIGH);
pinMode(SS1_IC3, OUTPUT);
digitalWriteFast(SS1_IC3, HIGH);
pinMode(DELAY_PIN, OUTPUT);
pinMode(IO_PIN, OUTPUT);
digitalWriteFast(DELAY_PIN, 0);
pinMode(SDI, OUTPUT);
pinMode(SCK, OUTPUT);
delay(1); // https://www.pjrc.com/better-spi-bus-design-in-3-steps/
draw_test_pattern();
SPI.begin();
SPI.beginTransaction(SPISettings(20000000, MSBFIRST, SPI_MODE0));
/* uint32_t fastio = IOMUXC_PAD_SRE | IOMUXC_PAD_DSE(3) | IOMUXC_PAD_SPEED(3); Do the 3 pins need to be configured for DMA?
// from old Teensy 3.2 code : configure the output on pins 6, 8, 22 for !SS0 from the SPI hardware
// and pin 6 for !SS1.
CORE_PIN6_CONFIG = fastio;
CORE_PIN8_CONFIG = fastio;
CORE_PIN22_CONFIG = fastio;
// Set up a DMA channel to send the SPI data
spi_dma.begin(true); // Allocate the DMA channel first
spi_dma.destination((volatile uint8_t &) LPSPI4_TDR); // SHOULD BE UINT32_T???
spi_dma.disableOnCompletion();
spi_dma.triggerAtHardwareEvent( DMAMUX_SOURCE_LPSPI4_TX ); // start
spi_dma.transferSize(4); // write all 32-bits
// send something to get it started
spi_dma_which = 0;
spi_dma_count = 0;
spi_dma_tx_append(0, 1);
spi_dma_tx_append(0, 2);
spi_dma_tx();
static uint32_t frame_micros;
uint32_t now;
while (1)
now = micros();
// make sure we flush the partial buffer once the last one has completed
if (spi_dma_tx_complete())
if (rx_points == 0 && now - frame_micros > REFRESH_RATE)
spi_dma_tx();
frame_micros = now;
// if there are any DMAs currently in transit, wait for them to complete
while (!spi_dma_tx_complete())
// now start any last buffered ones and wait for those to complete.
spi_dma_tx();
for(unsigned n = 0 ; n < num_points ; n++)
const DataChunk_t pt = Chunk[n];
if (pt.red + pt.green + pt.blue == 0)
draw_moveto(pt.x, pt.y);
brightness(pt.red, pt.green, pt.blue);
_draw_lineto(pt.x, pt.y, NORMAL_SHIFT);
brightness(0, 0, 0);
goto_x(2048);
goto_y(2048);
static void draw_test_pattern()
rx_points = 0;
rx_append(0, 0, 0, 0, 0);
rx_append(1024, 0, 128, 128, 128);
rx_append(1024, 1024, 128, 128, 128);
rx_append(0, 1024, 128, 128, 128);
rx_append(0, 0, 128, 128, 128);
void rx_append(int x, int y, uint8_t red, uint8_t green, uint8_t blue)
rx_points ++;
Chunk[rx_points].x = x & 0xFFF;
Chunk[rx_points].y = y & 0xFFF;
Chunk[rx_points].red = red;
Chunk[rx_points].green = green;
Chunk[rx_points].blue = blue;
void draw_moveto(int x1, int y1)
dwell(OFF_DWELL1);
_draw_lineto(x1, y1, OFF_SHIFT);
dwell(OFF_DWELL2);
static inline void brightness(uint8_t red, uint8_t green, uint8_t blue)
dwell(OFF_DWELL0);
if (LastColInt.red != red)
LastColInt.red = red;
// Some confusion here as to what to send : the SPI_DMA_CS or SS pin ...
MCP4922_write(SPI_DMA_CS_IC5, DAC_CHAN_B, red << 4);
// MCP4922_write(SS0_IC5, DAC_CHAN_B, red << 4);
if (LastColInt.green != green)
LastColInt.green = green;
MCP4922_write(SS0_IC5, DAC_CHAN_A, green << 4);
if (LastColInt.blue != blue)
LastColInt.blue = blue;
MCP4922_write(SS0_IC5, DAC_CHAN_B, blue << 4);
static inline void goto_x(uint16_t x)
x_pos = x;
MCP4922_write(SS1_IC4, DAC_X_CHAN, 4095 - x);
static inline void goto_y(uint16_t y)
y_pos = y;
MCP4922_write(SS1_IC4, DAC_Y_CHAN, 4095 - y);
static void dwell(const int count)
for (int i = 0 ; i < count ; i++)
if (i & 1)
goto_x(x_pos);
goto_y(y_pos);
static inline void _draw_lineto(int x1, int y1, const int bright_shift)
int dx;
int dy;
int sx;
int sy;
const int x1_orig = x1;
const int y1_orig = y1;
int x_off = x1 & ((1 << bright_shift) - 1);
int y_off = y1 & ((1 << bright_shift) - 1);
x1 >>= bright_shift;
y1 >>= bright_shift;
int x0 = x_pos >> bright_shift;
int y0 = y_pos >> bright_shift;
goto_x(x_pos);
goto_y(y_pos);
if (x0 <= x1)
dx = x1 - x0;
sx = 1;
dx = x0 - x1;
sx = -1;
if (y0 <= y1)
dy = y1 - y0;
sy = 1;
dy = y0 - y1;
sy = -1;
int err = dx - dy;
while (1)
if (x0 == x1 && y0 == y1)
int e2 = 2 * err;
if (e2 > -dy)
err = err - dy;
x0 += sx;
goto_x(x_off + (x0 << bright_shift));
if (e2 < dx)
err = err + dx;
y0 += sy;
goto_y(y_off + (y0 << bright_shift));
// ensure that we end up exactly where we want
goto_x(x1_orig);
goto_y(y1_orig);
void MCP4922_write(int cs_pin, byte dac, uint16_t value)
value &= 0x0FFF; // mask out just the 12 bits of data
// add the output channel A or B on the selected DAC, and buffer flag
#if 1
// select the output channel on the selected DAC, buffered, no gain
value |= 0x7000 | (dac == 1 ? 0x8000 : 0x0000);
#else
// select the output channel on the selected DAC, unbuffered, no gain
value |= 0x3000 | (dac == 1 ? 0x8000 : 0x0000);
if (spi_dma_tx_append(value, cs_pin) == 0)
return;
// wait for the previous line to finish
while(!spi_dma_tx_complete())
// now send this line, which swaps buffers
spi_dma_tx();
static int spi_dma_tx_append(uint16_t value, int spi_dma_cs)
spi_dma_q[spi_dma_which][spi_dma_count++] = 0 | ((uint32_t)value) | (spi_dma_cs << 16); // enable the chip select line
if (spi_dma_count == SPI_DMA_MAX)
return 1;
return 0;
static void spi_dma_tx()
if (spi_dma_count == 0)
return;
digitalWriteFast(DELAY_PIN, 1);
// add a EOQ to the last entry
spi_dma_q[spi_dma_which][spi_dma_count-1] |= (1<<27);
spi_dma.clearComplete();
spi_dma.clearError();
spi_dma.sourceBuffer(spi_dma_q[spi_dma_which], 4 * spi_dma_count); // in bytes, not thingies
spi_dma_which = !spi_dma_which;
spi_dma_count = 0;
LPSPI4_CR &= ~LPSPI_CR_MEN; // Disable LPSPI:
LPSPI4_CFGR1 |= LPSPI_CFGR1_NOSTALL; // Prevent stall from RX
//LPSPI4_TCR = 15; // Framesize 16 Bits - seems to stop things working on Teensy 4.1
LPSPI4_FCR = 0; // Fifo Watermark
LPSPI4_DER = LPSPI_DER_TDDE; // TX DMA Request Enable
LPSPI4_CR |= LPSPI_CR_MEN; // Enable LPSPI
digitalWrite(SS0_IC5, LOW);
digitalWrite(SS1_IC4, LOW);
digitalWrite(SS1_IC3, LOW);
spi_dma.enable();
spi_dma_in_progress = 1;
static int spi_dma_tx_complete()
if (!spi_dma_in_progress) // if nothing is in progress, we're "complete"
return 1;
if (!spi_dma.complete())
return 0;
digitalWrite(SS0_IC5, HIGH);
digitalWrite(SS1_IC4, HIGH);
digitalWrite(SS1_IC3, HIGH);
delayMicroseconds(5);
LPSPI4_CR &= ~LPSPI_CR_MEN; // disable LPSPI:
spi_dma_in_progress = 0;
return 1;
