CopyFromSerial: rawfile-uploader.py not transfer correctly files
darioconcilio
I'm trying to use SparkFun LSM6DS3 with Teensy 3.2, but I have strange behavior.
I follow the sketch sequence as soon as the led stays fixed, then I execute the program in python (using python 2.7 with pySerial) with 3 files (RAW audio format).
Python shows me correct log, but at the end of the transfer the LED (pin 13) remains still fixed.
If I try to load into teensy 3.2 ListFiles example, it shows empty list.
If I try to use CopyFormSD example (with connected SD card) it works.
Where I wrong?
Sketch CopyFromSerial:
 * This is free and unencumbered software released into the public domain.
 * Anyone is free to copy, modify, publish, use, compile, sell, or
 * distribute this software, either in source code form or as a compiled
 * binary, for any purpose, commercial or non-commercial, and by any
 * means.
 * In jurisdictions that recognize copyright laws, the author or authors
 * of this software dedicate any and all copyright interest in the
 * software to the public domain. We make this dedication for the benefit
 * of the public at large and to the detriment of our heirs and
 * successors. We intend this dedication to be an overt act of
 * relinquishment in perpetuity of all present and future rights to this
 * software under copyright law.
 * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
 * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF
 * MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.
 * IN NO EVENT SHALL THE AUTHORS BE LIABLE FOR ANY CLAIM, DAMAGES OR
 * OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE,
 * ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR
 * OTHER DEALINGS IN THE SOFTWARE.
 * For more information, please refer to <http://unlicense.org>
 * This is example code to 1) format an SPI Flash chip, and 2) copy raw
 * audio files (mono channel, 16 bit signed, 44100Hz) to it using the
 * SerialFlash library.  The audio can then be played back using the
 * AudioPlaySerialflashRaw object in the Teensy Audio library.
 * To convert a .wav file to the proper .RAW format, use sox:
 * sox input.wav -r 44100 -b 16 --norm -e signed-integer -t raw OUTPUT.RAW remix 1,2
 * Note that the OUTPUT.RAW filename must be all caps and contain only the following
 * characters: A-Z, 0-9, comma, period, colon, dash, underscore.  (The SerialFlash
 * library converts filenames to caps, so to avoid confusion we just enforce it here).
 * It is a little difficult to see what is happening; aswe are using the Serial port
 * to upload files, we can't just throw out debug information.  Instead, we use the LED
 * (pin 13) to convey state.
 * While the chip is being formatted, the LED (pin 13) will toggle at 1Hz rate.  When
 * the formatting is done, it flashes quickly (10Hz) for one second, then stays on
 * solid.  When nothing has been received for 3 seconds, the upload is assumed to be
 * completed, and the light goes off.
 * Use the 'rawfile-uploader.py' python script (included in the extras folder) to upload
 * the files.  You can start the script as soon as the Teensy is turned on, and the
 * USB serial upload will just buffer and wait until the flash is formatted.
 * This code was written by Wyatt Olson <wyatt@digitalcave.ca> (originally as part
 * of Drum Master http://drummaster.digitalcave.ca and later modified into a
 * standalone sample).
 * Enjoy!
//Buffer sizes
#define USB_BUFFER_SIZE      128
#define FLASH_BUFFER_SIZE    4096
//Max filename length (8.3 plus a null char terminator)
#define FILENAME_STRING_SIZE      13
//State machine
#define STATE_START      0
#define STATE_SIZE      1
#define STATE_CONTENT    2
//Special bytes in the communication protocol
#define BYTE_START      0x7e
#define BYTE_ESCAPE      0x7d
#define BYTE_SEPARATOR    0x7c
//SPI Pins (these are the values on the Audio board; change them if you have different ones)
#define MOSI              11
#define MISO              12
#define SCK               14
#define CSPIN             10
//#define CSPIN           21  // Arduino 101 built-in SPI Flash
void setup(){
  Serial.begin(9600);  //Teensy serial is always at full USB speed and buffered... the baud rate here is required but ignored
  pinMode(13, OUTPUT);
  pinMode(15, INPUT);
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  pinMode(6, OUTPUT);
  analogWriteResolution(10); //0 - 1023
  analogWrite(3, 1023);
  analogWrite(4, 1023);
  analogWrite(5, 1023);
  analogWrite(6, 1023);
  //Set up SPI
  SPI.setMOSI(MOSI);  // uncomment these if using the alternate pins
  SPI.setMISO(MISO);
  SPI.setSCK(SCK);
  if (!SerialFlash.begin(CSPIN)) {
    while (1) {
      Serial.println("Unable to access SPI Flash chip");
  //We start by formatting the flash...
  uint8_t id[5];
  SerialFlash.readID(id);
  if (digitalRead(15) == HIGH) {
    SerialFlash.eraseAll();
  //Flash LED at 1Hz while formatting
  analogWrite(6, 200);
  while (!SerialFlash.ready()) {
    digitalWrite(13, HIGH);
    digitalWrite(13, LOW);
  analogWrite(5, 200);
  //Quickly flash LED a few times when completed, then leave the light on solid
  for(uint8_t i = 0; i < 10; i++){
  //We are now going to wait for the upload program
  while(!Serial.available());
  SerialFlashFile flashFile;
  uint8_t state = STATE_START;
  uint8_t escape = 0;
  uint8_t fileSizeIndex = 0;
  uint32_t fileSize = 0;
  char filename[FILENAME_STRING_SIZE];
  char usbBuffer[USB_BUFFER_SIZE];
  uint8_t flashBuffer[FLASH_BUFFER_SIZE];
  uint16_t flashBufferIndex = 0;
  uint8_t filenameIndex = 0;
  uint32_t lastReceiveTime = millis();
  //We assume the serial receive part is finished when we have not received something for 3 seconds
  while(Serial.available() || lastReceiveTime + 5000 > millis()){
    uint16_t available = Serial.readBytes(usbBuffer, USB_BUFFER_SIZE);
    if (available){
      analogWrite(4, 200);
    for (uint16_t usbBufferIndex = 0; usbBufferIndex < available; usbBufferIndex++){
      analogWrite(3, 200);
      uint8_t b = usbBuffer[usbBufferIndex];
      if (state == STATE_START){
        //Start byte.  Repeat start is fine.
        if (b == BYTE_START){
          for (uint8_t i = 0; i < FILENAME_STRING_SIZE; i++){
            filename[i] = 0x00;
          filenameIndex = 0;
        //Valid characters are A-Z, 0-9, comma, period, colon, dash, underscore
        else if ((b >= 'A' && b <= 'Z') || (b >= '0' && b <= '9') || b == '.' || b == ',' || b == ':' || b == '-' || b == '_'){
          filename[filenameIndex++] = b;
          if (filenameIndex >= FILENAME_STRING_SIZE){
            //Error name too long
            flushError();
            return;
        //Filename end character
        else if (b == BYTE_SEPARATOR){
          if (filenameIndex == 0){
            //Error empty filename
            flushError();
            return;
          //Change state
          state = STATE_SIZE;
          fileSizeIndex = 0;
          fileSize = 0;
        //Invalid character
        else {
          //Error bad filename
          flushError();
          return;
      //We read 4 bytes as a uint32_t for file size
      else if (state == STATE_SIZE){
        if (fileSizeIndex < 4){
          fileSize = (fileSize << 8) + b;
          fileSizeIndex++;
          state = STATE_CONTENT;
          escape = 0;
          if (SerialFlash.exists(filename)){
            SerialFlash.remove(filename);  //It doesn't reclaim the space, but it does let you create a new file with the same name.
          //Create a new file and open it for writing
          if (SerialFlash.create(filename, fileSize)) {
            flashFile = SerialFlash.open(filename);
            if (!flashFile) {
              //Error flash file open
              flushError();
              return;
          else {
            //Error flash create (no room left?)
            flushError();
            return;
        else {
          //Error invalid length requested
          flushError();
          return;
      else if (state == STATE_CONTENT){
        //Previous byte was escaped; unescape and add to buffer
        if (escape){
          escape = 0;
          flashBuffer[flashBufferIndex++] = b ^ 0x20;
        //Escape the next byte
        else if (b == BYTE_ESCAPE){
          //Serial.println("esc");
          escape = 1;
        //End of file
        else if (b == BYTE_START){
          //Serial.println("End of file");
          flashFile.write(flashBuffer, flashBufferIndex);
          flashFile.close();
        //Normal byte; add to buffer
        else {
          flashBuffer[flashBufferIndex++] = b;
        //The buffer is filled; write to SD card
        if (flashBufferIndex >= FLASH_BUFFER_SIZE){
          flashFile.write(flashBuffer, FLASH_BUFFER_SIZE);
  //Success!  Turn the light off.
void loop(){
  //Do nothing.
void flushError(){
  while(Serial.available() || lastReceiveTime + 3000 > millis()){
    if (Serial.readBytes(usbBuffer, USB_BUFFER_SIZE)){
rawfile-uploader.py
#!/usr/bin/python
# Uploads raw audio files to Teensy + Audio board with SPI Flash on board.  To use this program, first
# load the 'CopyFromSerial' example sketch.  When it first runs, it will format the SPI flash chip
# (this may take a long time for larger chips; a 128MB chip that I am using can take almost 10 minutes,
# but smaller 16MB ones should be faster).
# While the chip is being formatted, the LED (pin 13) will toggle at 1Hz rate.  When the formatting is
# done, it flashes quickly (10Hz) for one second, then stays on solid.  When nothing has been received
# for 3 seconds, the upload is assumed to be completed, and the light goes off.
# You can start this program immediately upon plugging in the Teensy.  It will buffer and wait until
# the Teensy starts to read the serial data from USB.
import serial, sys, os, time
if (len(sys.argv) <= 2):
	print("Usage: '" + sys.argv[0] + " <port> <files>' where:\n\t<port> is the TTY USB port connected to Drum Master\n\t<files> is a list of .RAW files (bash globs work).")
	sys.exit()
#Special bytes
BYTE_START = "\x7e"
BYTE_ESCAPE = "\x7d"
BYTE_SEPARATOR = "\x7c"
#Flash size (in MB).  Change this to match how much space you have on your chip.
FLASH_SIZE = 16
totalFileSize = 0;
for i, filename in enumerate(sys.argv):
	if (i >= 2):
		totalFileSize = totalFileSize + os.path.getsize(filename)
flashSizeBytes = FLASH_SIZE * 1024 * 1024
if (totalFileSize > flashSizeBytes):
	print("Too many files selsected.\n\tTotal flash size:\t" + "{:>14,}".format(flashSizeBytes) + " bytes\n\tTotal file size:\t" + "{:>14,}".format(totalFileSize) + " bytes")
	sys.exit()
ser = serial.Serial(sys.argv[1])
print("Uploading " + str(len(sys.argv) - 2) + " files...")
	if (i >= 2):
		startTime = time.time();
		sys.stdout.write(str(i - 1) + ": ")
		sys.stdout.write(filename)
		sys.stdout.flush()
		f = open(filename, "rb")
		fileLength = os.path.getsize(filename)
		try:
			encoded = []
			#Start byte
			encoded.append(BYTE_START)
			#Filename
			for byte in os.path.basename(filename):
				encoded.append(byte)
			#End of filename
			encoded.append(BYTE_SEPARATOR)
			#File length (uint32_t)
			encoded.append(chr((fileLength >> 24) & 0xFF));
			encoded.append(chr((fileLength >> 16) & 0xFF));
			encoded.append(chr((fileLength >> 8) & 0xFF));
			encoded.append(chr((fileLength >> 0) & 0xFF));
			#Binary data, with escaping
			for byte in f.read():
				if byte == BYTE_START or byte == BYTE_ESCAPE:
					encoded.append(BYTE_ESCAPE)
					encoded.append(chr(ord(byte) ^ 0x20))
				else:
					encoded.append(byte);
			#Write end of data byte
			ser.write("".join(encoded))
		finally:
			f.close()
		endTime = time.time();
		print(" (" + str(round(fileLength / 1024 / (endTime - startTime), 2)) + " KB/s)");
print("All files uploaded")
Breakout of LSM6DS3:
https://learn.sparkfun.com/tutorials/lsm6ds3-breakout-hookup-guide/all
