SplendidSplendid
New member
I am attempting to use this page to assist in making a MIDI project (https://www.pjrc.com/teensy/td_midi.html).
I have several Arduino boards along with a couple of Teensy boards.
Under the "Transmitting Messages" I see there are usbMIDI calls. I am wondering where this is coming from since I have not included any sort of library. Also, the code never compiles unless I select a Teensy board within the IDE.
Is this a built in library that is only used for Teensy? I have been looking for more documentation on the library but I am coming up short. I have browsed to the "MIDIcontroller library" hyperlink on that same pjrc page but it seems like it is not the same as the usbMIDI calls under "Transmitting Messages".
I would really like to understand and see more documentation if it is listed somewhere, curious where it is pulling the library from or if it is built into Teensyduino.
Thanks.
Thanks.
