package main
import (
"embedded/rtos"
"time"
"unsafe"
"github.com/embeddedgo/imxrt/devboard/teensy4/board/leds"
"github.com/embeddedgo/imxrt/hal/dma"
func main() {
// Number of words to copy.
const n = 1e4 // must be <= 32767 because of Example 2.
// We use dma.Alloc instead of builtin make function because we need cache-
// aligned buffers. If you have ordinary (non cache-aligned) buffers you
// can still use DMA with them but the beginning and end of the buffers may
// require special treatment.
src := dma.Alloc[uint32](n)
dst := dma.Alloc[uint32](n)
// Initialize the source memory with some pattern.
for i := range src {
src[i] = uint32(i<<16 | i)
// We leave the safe field if we start messing around with DMA.
srcAddr := unsafe.Pointer(&src[0])
dstAddr := unsafe.Pointer(&dst[0])
// Make sure all the values we wrote down in src are in place.
rtos.CacheMaint(rtos.DCacheClean, srcAddr, n*4)
// Ungate the DMA clock and configure the controller to use round robin
// arbitration and halt on any error.
d := dma.DMA(0)
d.EnableClock(true)
d.CR.SetBits(dma.ERCA | dma.ERGA | dma.HOE)
// Allocate a free DMA channel. Because the priorities for all channels
// (even unused) must be unique in fixed arbitration mode AllocChannel is
// usually used together with round robin arbitration.
c := d.AllocChannel(false)
// Example 1. Transfer all data in the minor loop.
// Pros: Simple and fast.
// Cons: May increase the overall DMA latency/jitter because the minor loop
// cannot be preempted in the round robin mode. Fixed arbitration isn't a
// 100% solution because nested preemption isn't supported.
// Flush and invalidate anything in the cache related to the dst buffer.
rtos.CacheMaint(rtos.DCacheCleanInval, dstAddr, n*4)
// Prepare a Transfer Control Descriptor. As the CRS[START] bit is set, the
// transfer will start immediately after we write the prepared TCD to the
// DMA local memory.
tcd := dma.TCD{
SADDR: srcAddr, // source address
SOFF: 4, // added to SADDR after each read
ATTR: dma.S32b | dma.D32b, // src and dst data transfer sizes
ML_NBYTES: n * 4, // number of bytes for minor loop
SLAST: -n * 4, // added to SADDR when CITER reaches zero
DADDR: dstAddr, // destination address
DOFF: 4, // added to DADDR after each write
ELINK_CITER: 1, // number of itreations in major loop
DLAST_SGA: -n * 4, // added to DADDR when CITER reaches zero
CSR: dma.START, // start the transfer immediately
ELINK_BITER: 1, // reloaded to ELINK_CITER when CITER reaches zero
c.WriteTCD(&tcd)
waitAndCheck(c, dst)
// Example 2. Transfer data using major and minor loops.
// Pros: The DMA engine can handle multiple active channels at the same time
// while it is possible to ensure ML_NBYTES uninterrupted transfer for each
// of them.
// Cons: More complex and slower than transfering all data in minor loop.
// Clear destination buffer.
for i := range dst {
dst[i] = 0
// Modify the TCD from Example 1. to use the major loop to the extreme.
tcd.ML_NBYTES = 4 // extremely short (one-iteration) minor loop
tcd.ELINK_CITER = n // number of iterations in major loop, must be <= 32767
tcd.ELINK_BITER = n // must be the same as ELINK_CITER
tcd.CSR = dma.DREQ // stop at the end of major loop, required because of AE
c.WriteTCD(&tcd)
// CSR[START] runs the major loop for one iteration only. We use DMAMUX AE
// (always enabled) request and CSR[DREQ] to run the major loop to the end.
c.SetMux(dma.En | dma.AE) // assert the DMA request permanently
c.EnableReq() // accept requests
// Blink slow if all went well.
for {
leds.User.Toggle()
time.Sleep(time.Second / 2)
// WaitAndCheck waits for the end of transfer and checks the content of the dst
// buffer. It blinks fast endlessly if there is no proper pattern in dst.
func waitAndCheck(c dma.Channel, dst []uint32) {
for c.TCD().CSR.LoadBits(dma.DONE) == 0 {
for i, w := range dst {
for w != uint32(i<<16|i) {
leds.User.Toggle()
time.Sleep(time.Second / 8)
