I am trying to employ an MX1508 dual H-bridge motor controller in a project that I am working on. I have no problem getting my Teensy 4.1 to actuate a motor attached to the H-bridge, but the only library that I can find that is set up to work with PWM speed control with the MX1508 (https://github.com/Saeterncj/MX1508) fails to compile.
My hope is that someone on the forum will be able to confirm that the library will (or will not) compile on their computer. I have never had problems with compiling libraries until recently, but over the last few days, I had problems compiling several, so either I am experiencing a run of bad luck, or there is something partially awry with the compiler (or the user).
To keep things simple I attempted to compile the following minimal code:
#include <MX1508.h>
#define PINA 36
#define PINB 37
#define NUMPWM 2
#define PWM 100
MX1508 motorA(PINA,PINB, FAST_DECAY, NUMPWM);
void setup() {}
motorA.motorGo(PWM);
And here are the voluminous error messages generated by the compiler:
C:\Users\Michael\AppData\Local\Temp\.arduinoIDE-unsaved2023327-548-19k8st8.wur5\sketch_apr27a\sketch_apr27a.ino:5:16: warning: invalid conversion from 'int' to 'NumOfPwmPins' [-fpermissive]
5 | #define NUMPWM 2
| int
C:\Users\Michael\AppData\Local\Temp\.arduinoIDE-unsaved2023327-548-19k8st8.wur5\sketch_apr27a\sketch_apr27a.ino:8:38: note: in expansion of macro 'NUMPWM'
8 | MX1508 motorA(PINA,PINB, FAST_DECAY, NUMPWM);
In file included from C:\Users\Michael\AppData\Local\Temp\.arduinoIDE-unsaved2023327-548-19k8st8.wur5\sketch_apr27a\sketch_apr27a.ino:1:
c:\Users\Michael\Documents\Arduino\libraries\MX1508/MX1508.h:21:78: note: initializing argument 4 of 'MX1508::MX1508(uint8_t, uint8_t, DecayMode, NumOfPwmPins)'
21 | MX1508(uint8_t pinIN1, uint8_t pinIN2, DecayMode decayMode, NumOfPwmPins numPWM);
c:\Users\Michael\Documents\Arduino\libraries\MX1508\MX1508.cpp: In member function 'void MX1508::setResolution(unsigned int)':
c:\Users\Michael\Documents\Arduino\libraries\MX1508\MX1508.cpp:32:25: error: 'ICR1' was not declared in this scope
32 | if(_useAnalogWrite16) ICR1 = pwmResolution;
In file included from C:\Users\Michael\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\cores\teensy4/wiring.h:39,
from C:\Users\Michael\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\cores\teensy4/WProgram.h:46,
from C:\Users\Michael\AppData\Local\Temp\arduino\sketches\6D542608C537E51812A9D89560841D14/pch/Arduino.h:6,
from c:\Users\Michael\Documents\Arduino\libraries\MX1508\MX1508.h:4,
from c:\Users\Michael\Documents\Arduino\libraries\MX1508\MX1508.cpp:1:
c:\Users\Michael\Documents\Arduino\libraries\MX1508\MX1508.cpp: In member function 'void MX1508::setPWM16(uint8_t, unsigned int)':
c:\Users\Michael\Documents\Arduino\libraries\MX1508\MX1508.cpp:37:22: error: 'PB1' was not declared in this scope; did you mean 'B1'?
37 | DDRB |= _BV(PB1) | _BV(PB2); /* set pin 9and 10 as outputs */
C:\Users\Michael\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\cores\teensy4/core_pins.h:45:38: note: in definition of macro '_BV'
45 | #define _BV
(1<<
c:\Users\Michael\Documents\Arduino\libraries\MX1508\MX1508.cpp:37:33: error: 'PB2' was not declared in this scope
45 | #define _BV
(1<<
c:\Users\Michael\Documents\Arduino\libraries\MX1508\MX1508.cpp:38:5: error: 'TCCR1A' was not declared in this scope
38 | TCCR1A = _BV(COM1A1) | _BV(COM1B1) | _BV(WGM11); // non-inverting PWM, mode 14 fastPWM, TOP =ICR1
c:\Users\Michael\Documents\Arduino\libraries\MX1508\MX1508.cpp:38:18: error: 'COM1A1' was not declared in this scope
45 | #define _BV
(1<<
c:\Users\Michael\Documents\Arduino\libraries\MX1508\MX1508.cpp:38:32: error: 'COM1B1' was not declared in this scope
45 | #define _BV
(1<<
c:\Users\Michael\Documents\Arduino\libraries\MX1508\MX1508.cpp:38:46: error: 'WGM11' was not declared in this scope
45 | #define _BV
(1<<
c:\Users\Michael\Documents\Arduino\libraries\MX1508\MX1508.cpp:39:9: error: 'TCCR1B' was not declared in this scope
39 | TCCR1B = _BV(WGM13) | _BV(WGM12) | prescaler ; // rescaler must be 1->5, 1,8,64,256,1028 respectively
c:\Users\Michael\Documents\Arduino\libraries\MX1508\MX1508.cpp:39:22: error: 'WGM13' was not declared in this scope
45 | #define _BV
(1<<
c:\Users\Michael\Documents\Arduino\libraries\MX1508\MX1508.cpp:39:35: error: 'WGM12' was not declared in this scope
45 | #define _BV
(1<<
c:\Users\Michael\Documents\Arduino\libraries\MX1508\MX1508.cpp:40:9: error: 'ICR1' was not declared in this scope
40 | ICR1 = resolution;
c:\Users\Michael\Documents\Arduino\libraries\MX1508\MX1508.cpp: In member function 'void MX1508::analogWrite16(uint8_t, uint16_t)':
c:\Users\Michael\Documents\Arduino\libraries\MX1508\MX1508.cpp:50:26: error: 'OCR1A' was not declared in this scope
50 | case 9: OCR1A = val; break;
c:\Users\Michael\Documents\Arduino\libraries\MX1508\MX1508.cpp:51:26: error: 'OCR1B' was not declared in this scope
51 | case 10: OCR1B = val; break;
exit status 1
Compilation error: exit status 1
I have reinstalled the Arduino 2.1.0 IDE without effect, but perhaps reinstalling the IDE does not touch the compiler if is found to already exist.
Thanks for your help.
Tim
#include <MX1508.h>
#define PINA 36
#define PINB 37
#define NUMPWM 2
#define PWM 100
void setup() {}
| int
45 | #define _BV
45 | #define _BV
45 | #define _BV
45 | #define _BV
45 | #define _BV
45 | #define _BV
45 | #define _BV
exit status 1
Tim
