I got a Teensy3.0 for Xmas, and I'm just now getting around to trying it out. Unfortunately, it doesn't seem to work.
I've installed the beta10 software for teensy3 that is given at http://www.pjrc.com/teensy/beta/arduino-1.0.3-teensy3-beta10-macos.zip
In the Arduino.app given, I set:
Tools->Board = Teensy3.0
Tools->USB Type = Serial
Tools->CPU Speed = 96Mhz
Tools->Programmer = Arduino as ISP
I load the Blink sketch, change the timing to blink every half second (so I will be able to tell the diff from the default blink app), and I change the ledPin to 13.
I plug the Teensy3 in to the USB, and it blinks once a second.
I click on Upload in the given Arduino.app, and the code compiles, and the Teensy.app is launched. The Auto light is lit. The Teensy3 keeps blinking once a second.
I get a message from the Arduino.app that I need to press the button, so I do. The light goes out and nothing happens.
Just in case, I try running upload again, both just before, just after, and just as I press the reload button on the Teensy3. No blinks. No change.
I turn off Auto mode in Teensy.app, open the Blink.cpp.hex file, and note that the upload and reset buttons remain disabled.
I press the reload button, and still no change. When I unplug and replug the Teensy3, it starts the slow 1-second Blink program it came with.
I'm running OS X 10.8.2, so I go into the System Information app, and look at the USB devices connected. I see no device for the Teensy3. I unplug and replug the Teensy3 and refresh, and still no device. I press the Reload button on the Teensy3 and refresh the USB list again and still no device.
Is my Teensy3 just dead? Do I need to install some sort of device driver that I failed to find mention of?
