philip.porhammer
/* dead on real time clock with SRAM
How do i read and write the SRAM
const int cs=10; //chip select RTC
long MoonTimePoint=52830;// 2bytes
int Hi=0;
int Lo=126;
int moonPoint=0;// 1
int Latitude=7;// 1
int DayOfWeek=4;// 1
int WeekOfYear=35;//1
RTC_init();
//day(1-31), month(1-12), year(0-99), hour(0-23), minute(0-59), second(0-59)
SetTimeDate(24, 1, 16, 1, 30, 29);
// Serial.println(ReadTimeDate());
StoreData();
int StoreData(){ delay(100);
digitalWrite(cs, LOW);
SPI.transfer(0x98);
SPI.transfer(0x00);
SPI.transfer(0x01);
SPI.transfer(0x02);
SPI.transfer(0x03);
SPI.transfer(0x09);
digitalWrite(cs, HIGH);
delay(50);
int aa=99;
int ab=99;
int ac=99;
int ad=99;
int ae=99;
SPI.transfer(0x18);
aa= SPI.transfer(0x00);
ab= SPI.transfer(0x00);
ac= SPI.transfer(0x00);
ad= SPI.transfer(0x00); Lo= SPI.transfer(0x00);
ae= SPI.transfer(0x00);
Serial.println(" ") ;
Serial.print(" o = ") ;
Serial.print(aa) ; Serial.print(" o = ") ;
Serial.print(ab) ; Serial.print(" o = ") ;
Serial.print(ac) ; Serial.print(" o = ") ;
Serial.print(ad) ; Serial.print(" o = ") ;
Serial.print(ae) ; Serial.print(" o = ") ;
Serial.println(" lo ") ;
int RTC_init(){
pinMode(cs,OUTPUT); // chip select
// start the SPI library:
SPI.begin();
SPI.setBitOrder(MSBFIRST);
SPI.setDataMode(SPI_MODE1); // both mode 1 & 3 should work
//set control register
SPI.transfer(0x8E);
SPI.transfer(0x60); //60= disable Osciallator and Battery SQ wave @1hz, temp compensation, Alarms disabled
delay(10);
int SetTimeDate(int d, int mo, int y, int h, int mi, int s){
int TimeDate [7]={s,mi,h,0,d,mo,y};
for(int i=0; i<=6;i++){
if(i==3)
i++;
int b= TimeDate/10;
int a= TimeDate-b*10;
if(i==2){
if (b==2)
b=B00000010;
else if (b==1)
b=B00000001;
TimeDate= a+(b<<4);
SPI.transfer(i+0x80);
SPI.transfer(TimeDate);
String ReadTimeDate(){
String temp;
int TimeDate [7]; //second,minute,hour,null,day,month,year
if(i==3)
i++;
SPI.transfer(i+0x00);
unsigned int n = SPI.transfer(0x00);
int a=n & B00001111;
if(i==2){
int b=(n & B00110000)>>4; //24 hour mode
if(b==B00000010)
b=20;
else if(b==B00000001)
b=10;
TimeDate=a+b;
else if(i==4){
TimeDate=a+b*10;
else if(i==5){
int b=(n & B00010000)>>4;
TimeDate=a+b*10;
else if(i==6){
int b=(n & B11110000)>>4;
TimeDate=a+b*10;
else{
int b=(n & B01110000)>>4;
TimeDate=a+b*10;
temp.concat(TimeDate[4]);
temp.concat("/") ;
temp.concat(TimeDate[5]);
temp.concat("/") ;
temp.concat(TimeDate[6]);
temp.concat(" ") ;
temp.concat(TimeDate[2]);
temp.concat(":") ;
temp.concat(TimeDate[1]);
temp.concat(":") ;
temp.concat(TimeDate[0]);
return(temp);
int Hi=0;
int Lo=126;
int Latitude=7;// 1
RTC_init();
StoreData();
SPI.transfer(0x98);
SPI.transfer(0x00);
SPI.transfer(0x01);
SPI.transfer(0x02);
SPI.transfer(0x03);
SPI.transfer(0x09);
delay(50);
int aa=99;
int ab=99;
int ac=99;
int ad=99;
int ae=99;
SPI.transfer(0x18);
int RTC_init(){
SPI.begin();
SPI.transfer(0x8E);
delay(10);
if(i==3)
i++;
int b= TimeDate/10;
if(i==2){
if (b==2)
b=B00000010;
else if (b==1)
b=B00000001;
TimeDate= a+(b<<4);
String temp;
if(i==3)
i++;
if(i==2){
if(b==B00000010)
b=20;
b=10;
TimeDate=a+b;
else if(i==4){
TimeDate=a+b*10;
else if(i==5){
TimeDate=a+b*10;
else if(i==6){
TimeDate=a+b*10;
else{
TimeDate=a+b*10;
temp.concat("/") ;
temp.concat("/") ;
temp.concat(" ") ;
temp.concat(":") ;
temp.concat(":") ;
return(temp);
