You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser.
If you happen to have six 10k resistors, you could put three in parallel on each of SDA and SCL.
Pete
Looks like you've wired it as if it was a Rev C. See the table here.
The two I2C pins might work better with 3k3 resistors.
Pete
TEENSYDUINO returns 160 as the version and not 162
Loading…
Loading…
