jim lee
Reaction score
16
    • jim lee
      Yes? Are you saying "Yes to the dress?"
    • jim lee
      WAIT! Got it. The IDE "lost" one of the libraies LC_lilParser. This caused all the 100 million wierd errors. The "fix" was to un-install the lost liberary using the IDE's library manager, re-install it using the library manager then restarting...
    • jim lee
      Wait, I'm using 15.2.1 and this just started last night. This 15.1.0 is over a year old. Wouldn't I have seen this before?
    • jim lee
      dangerous relocation: unsupported relocation I got a ton of them. I don't know what they are trying to tell me. Any hints? Anyone ran into this before? Thanks!
    • jim lee
      jim lee replied to the thread How to hook up CAN bus?.
      Hahaha! Now you tell me! I wrote my own NMEA2K library from scratch. https://github.com/leftCoast/LC_J1939 And was that a brain ripper! I"ll have a look at his. I'm sure there's a lot I can gather from it.
    • jim lee
      I was foggy on the entire baud rate of NMEA2K. There was a baud() command on my orignial harware. It was originally set to 500E3. I asked about it, and thought they said each device sets it's own? Or something similar? I was taking in a lot of...
    • jim lee
      Yes, the resistors are there. And the ends of my tiny bus. One thing I failed to mention is that this is NMEA2000 bus. It runs on the extended CAN Bus.
    • jim lee
      So, I"m still missing something on this built in CAN bus thing. I"m using the Adafruit can bus interface along with FlexCAN_T4 library. Running the example I found at FlexCAN_T4 Github.. #include <FlexCAN_T4.h> FlexCAN_T4<CAN3, RX_SIZE_256...
    • jim lee
      I was unclear on my question. I can add in the library, no problem. It's that actual line with the < > brackets that I don't really understand how it works. FlexCAN_T4<CAN1, RX_SIZE_256, TX_SIZE_16> Can0;
    • jim lee
      Ok I'm assuming this : FlexCAN_T4 is the library I want to use for this "TJA1051" board. This says it it goof for Teensy 4.0 processors. The way the example creates the instance of the interface : FlexCAN_T4<CAN1, RX_SIZE_256, TX_SIZE_16> Can0...
  • Loading…
  • Loading…
