I have a three teensy 4.1 setup below.
The idea is that teensy1 sends a packages filled with data to teensy2 and vice versa using DMA. I'm adding a third, middle teensy to act as a delayer to delay (a chosen amount of time z) the packages sent between the two teensys. To delay the packages, I was thinking of putting the received packages in a queue and timestamping when the packages were received. When the chosen amount of delay has passed, I then upload the package into a send array and send it to the other teensy. I've tested the setup and code (using dummy data variables) with teensy 1 and teensy 2 connected directly (no middle teensy) and the code works. However when I add the middle teensy, my data seems to stop in the middle and none of the packages or queues get updated. In the mid teensy code, you can see that I put a bunch of print statements, but the code stops after the first print statement on the very first line of the loop. I don't really understand why this is happening. I'm not sure if I set up the DMA linking incorrectly. Any advice or debugging suggestions would be appreciated.
Here's the main code and possible snippets of the from the included files I thought might helpful. Let me know if there is anything I might be missing.
Teensy 1 and 2 code (you may have seen a version of this on another thread of mine)
Mid Teensy code
.linkCh function
link_uart LPUART
TCD_ts
#include "DMASensor.h"
#include "DMAnChannel.h"
#include "DMAUART.h"
#include "Avatar_pinmap.h"
#include "Avatar_params.h"
#define sButton 33
#define LABELPRINT(label, value) Serial.print(label); Serial.print(": "); Serial.println(value);
#define PRINT(msg) Serial.println(msg);
DMAUART uart_enc, uart_link, uart_state;
DMAnChannel dma_link_s, dma_link_r, dma_state_s, dma_state_r;
uint32_t foo = 0xFFFFFFFF;
const uint8_t encoder_command = 0x54;
volatile uint16_t curr = 0;
volatile uint16_t rec_link[5];
volatile uint16_t snd_link[5];
int i = 0, j = 0, k=0, b=0;
pinMode(sButton, INPUT);
Serial.print("init done");
Serial.println("Press button to start");
while (digitalRead(sButton) == HIGH) {
// Configure GPT1 for encoder reading timestamping
CCM_CCGR1 |= CCM_CCGR1_GPT1_BUS(CCM_CCGR_ON); // Enable clock to GPT1 module
GPT1_CR = 0; // Disable for configuration
GPT1_PR = 2400 - 1; // Prescale 24 MHz clock by 3 => 8 MHz
GPT1_CR = GPT_CR_EN /* Enable timer */
| GPT_CR_CLKSRC(1) /* 24 MHz peripheral clock as clock source */
| GPT_CR_FRR /* Free-Run, do not reset */;
snd_link[0] = 255;
uart_link.init(LINK_CH, link_uart);
// Init DMA channels that handle sending/recieving position data over the device link bus
dma_link_s.init(0, snd_link, &(uart_link.ctrl->DATA), uart_link.dma_src_tx, link_send_tcd);
dma_link_r.init(9, &(uart_link.ctrl->DATA), rec_link, uart_link.dma_src_rx, link_receive_tcd);
dma_link_s.initPIT(2400);
Serial.println("start");
i = i + 1;
k++;
curr = currupdate();
snd_link[4] = curr;
if (i > 100) {
i = 0;
if (rec_link[0] != 255||!checkPar(rec_link[4])) {
uart_link.flushRX();
j++;
LABELPRINT("PARITY FAILURES", j);
Serial.print("record ");
Serial.print(rec_link[0]);
Serial.print(" ");
Serial.print(rec_link[1]);
Serial.print(" ");
Serial.print(rec_link[2]);
Serial.print(" ");
Serial.print(rec_link[3]);
Serial.print(" ");
Serial.print(rec_link[4]);
Serial.print(" ");
Serial.print(rec_link[5]);
Serial.println("");
Serial.print("send ");
Serial.print(snd_link[0]);
Serial.print(" ");
Serial.print(snd_link[1]);
Serial.print(" ");
Serial.print(snd_link[2]);
Serial.print(" ");
Serial.print(snd_link[3]);
Serial.print(" ");
Serial.print(snd_link[4]);
Serial.print(" ");
Serial.print(snd_link[5]);
Serial.println("");
uint16_t currupdate() {
// Serial.println("updating");
float f = 1.15 + i * 0.01; //dynamic dummy variable
int parity = 0;
uint16_t f16,n;
f16 = (uint16_t) (f * 1000);
n = f16;
while (n) {
n &= (n - 1);
parity ^= 1;
f16 =(uint16_t) f16<<1|parity;
return f16;
boolean checkPar(uint16_t num){
int pn, par;
par = num&1;
num>>=1;
while (num) {
num &= (num - 1);
pn ^= 1;
return pn == par;
Mid Teensy code
#define sButton 33
#define quesize 8192
#define delaytime 1000 // the time of delay is 550-100us(the rate
#define msgsize 5
// DMA channels and UART
DMAUART uart_link2, uart_link1, uart_state1, uart_state2;
DMAnChannel dma_link1_s, dma_link1_r, dma_link2_s, dma_link2_r, dma_state1_s, dma_state1_r, dma_state2_s, dma_state2_r;
// initialize arrays for recieve and sending
volatile uint16_t rec_T1[msgsize] = {0};
volatile uint16_t snd_T2[msgsize] = {0};
volatile uint16_t rec_T2[msgsize] = {0};
volatile uint16_t snd_T1[msgsize] = {0};
//initilize queue for delayed messages
volatile uint16_t delayque1[quesize][msgsize];
volatile uint16_t delayque2[quesize][msgsize];
//init time array to store corresponding delayque store time
unsigned long timeque1[quesize], timeque2[quesize], st, e;
// init indexes and counters
unsigned int indexk1, indexi1, indexk2, indexi2;
int i1 = 0, p1 = 0, k1 = 0, i2 = 0, p2 = 0, k2 = 0;
// init delayques with 0
for (int i = 0; i < quesize; i++) {
for (int j = 0; j < msgsize; j++) {
delayque1[i][j] = 0;
delayque2[i][j] = 0;
//send arrays first send 255
snd_T2[0] = 255;
snd_T1[0] = 255;
//init button to sync all teensys
// init links uart channels
//LINK1_CH is serial6, LINK2_CH is serial4
uart_link1.init(LINK1_CH, link_uart);
uart_link2.init(LINK2_CH, link_uart);
//init links dma channel
dma_link1_s.init(0, snd_T2, &(uart_link1.ctrl->DATA), uart_link1.dma_src_tx, link_send_tcd);
dma_link1_r.init(5, &(uart_link1.ctrl->DATA), rec_T1, uart_link1.dma_src_rx, link_receive_tcd);
dma_link2_s.init(1, snd_T1, &(uart_link2.ctrl->DATA), uart_link2.dma_src_tx, link_send_tcd);
dma_link2_r.init(6, &(uart_link2.ctrl->DATA), rec_T2, uart_link2.dma_src_rx, link_receive_tcd);
// dma_curr_r.initPIT(2400);
dma_link1_r.linkCh(dma_link2_s.ch);
dma_link2_r.linkCh(dma_link1_s.ch);
Serial.println("in loop");
//checks if incomming messages are not scrambled
if (rec_T1[0] != 255 || !checkPar(rec_T1[4])) {
uart_link1.flushRX();
p1++;
Serial.print("PARITY FAILURES: ");
Serial.println(p1++);
else {
//save incoming msg from link1 into delayque1
Serial.println("store msg1");
for (int z = 0; z < msgsize; z++) {
delayque1[k1][z] = rec_T1[z];
//timestamping in timeque to cooresponding with delayque1
Serial.println("store time of msg1");
timeque1[k1] = micros();
indexk1++;
k1 = indexk1 % quesize;
if (rec_T2[0] != 255 || !checkPar(rec_T2[4])) {
uart_link2.flushRX();
p2++;
Serial.println(p2++);
else {
//save incoming msg from link2 into delayque2
Serial.println("store msg2");
//save rec_link in delayarray[k]
delayque2[k2][z] = rec_T2[z];
//timestamping in timeque to cooresponding with delayque2
Serial.println("store time of msg2");
timeque2[k2] = micros();
indexk2++;
k2 = indexk2 % quesize;
//checks if the the wanted delay has passed
if (micros() - timeque1[i1] >= delaytime) {
//uploads the delayed msg into the send array to send through the other link
Serial.println("upload delayed msg1 to channel");
for (int z; z < msgsize; z++) {
snd_T1[z] = delayque1[i1][z];
indexi1++;
i1 = indexi1 % quesize;
if (micros() - timeque2[i2] >= delaytime) {
Serial.println("upload delayed msg2 to channel");
snd_T1[z] = delayque1[i2][z];
indexi2++;
i2 = indexi2 % quesize;
boolean checkPar(uint16_t num) {
int pn, par;
par = num & 1;
num >>= 1;
while (num) {
num &= (num - 1);
pn ^= 1;
return pn == par;
.linkCh function
void DMAnChannel::linkCh(uint16_t link_ch) {
if ((link_ch < 0) || (link_ch > 31)) {return;} // channel range guard
TCD->CSR &= ~(0b111111 << 7); // clear any previous channel linking and DONE flag
TCD->CSR |= (link_ch & 0b11111) << 8; // set new channel to link to
TCD->CSR |= 0b1 << 5; // enable channel linking
link_uart LPUART
LPUART_t link_uart = {
.GLOBAL = 0x0, // LPUART1_GLOBAL
.PINCFG = 0x0,
.BAUD = 0xBA00001,
.STAT = 0xC00000,
.CTRL = 0x300000,
.DATA = 0x1000,
.MATCH = 0x0,
.MODIR = 0x6,
.FIFO = 0xC10099,
.WATER = 0x20000 //& (0b11 << 10)
TCD_ts
TCD_t link_receive_tcd = { // DMA configuration for recieving position data over the LINK channel
.SADDR = 0, // Source address
.SOFF = 0, // Adjustment to the source address made after every minor loop iteration
.ATTR = (0b000000 << 11) | (0b000 << 8) | (0b000000 << 3) | (0b000), // SMOD | SSIZE | DMOD | DSIZE
.NBYTES = 2, // Set number of bytes to transfer per minor loop iteration
.SLAST = 0, // Source address adjustment after major loop completion
.DADDR = 0, // Destination address
.DOFF = 1,
.CITER = (0b0 << 15) | 5, // CITER and BITER must be the same when the TCD memory is loaded by software. CITER will decrement with each minor loop
.DLASTSGA = -10,//check what this is
.CSR = (0b00 << 14) | (0b00000 << 8) | (0b0 << 5) | (0b0 << 4) | (0b0 << 3) | (0b0 << 2), // BWC | MAJORLINKCH | ESG | DREQ | INTHALF | INTMAJOR
.BITER = (0b0 << 15) | 5 // Channel linking disabled | single service request (NO major looping)
TCD_t link_send_tcd = { // DMA configuration for sending position data over the LINK channel
.SOFF = 1, // Adjustment to the source address made after every minor loop iteration
.SLAST = -10, // Source address adjustment after major loop completion
.DOFF = 0,
.DLASTSGA = 0,
