Looking at the schematic I see that the on board button effectively takes PGM to GND, well pin 13 (P5.2) on MINI54TAN, while reset is from the ARM processor.
What is the difference between the two pins in terms of bottom line function and in taking a button off to a concealed switch on a carrier board, which pin is to be most effective in the day to day working life of a Teensy in a bespoke application?
I'm aware that the reset over serial bus isn't as implemented by Arduino, I've not had time yet to try testing the function of the two buttons, can anyone give me a heads up on this?
On another front, I use DipTrace as my main PCB CAD package, I've got the Teensy 3 (all pins) and the Teensy 2 (not the ++) as patterns and schematics. PM me with your email address and I'll be more than happy to send them over - please note, if you're using versions before 2.3 the libraries won't work. Oh, and I don't have the 3D models!
Many thanks,
David
Many thanks,
David
