This ESP WiFi2Serial Module is so much fun. I could get 2 Modules here in Germany but i had to do some modification in order to flash the firmware update to 0018000922. I used a stereo microscope for the soldering and if anyone needs artificial insemination ...? i think now i am fit for it.
I hoked it up directly to Serial1 on the Teensy3.1 and supported it with a breadboard powersupply of 3.3V
It costs me some long nights to adapt some code from https://hackaday.io/project/3072-esp8266-retro-browser for my heavy testing. It has no delay() function in the main loop as most of the other codes have and it runs with different Baud rates nevertheless.
If anyone can make a library out of it, it could be useful.
is this while (Serial1.available()) maybe not efficient for Teensy because Serial1 is always available after Serial1.begin() even if the buffer is empty?
/* ESP8266 RetroBrowser for Teensy3.1 (direct connection , only separate 3,3V for ESP)
originated from http://hackaday.io/project/3072/instructions
#define SSID "MAX" // WLAN SSID
#define PASS "87xxxxxxxxxxxx" // WLAN PW
#define DEST_HOST "retro.hackaday.com"
#define DEST_IP "192.254.235.21"
#define TIMEOUT 10000 // ms connection to AP maybe slow
#define CONTINUE false
#define HALT true
#define CPU_RESTART_ADDR (uint32_t *)0xE000ED0C
#define CPU_RESTART_VAL 0x5FA0004
#define CPU_RESTART (*CPU_RESTART_ADDR = CPU_RESTART_VAL); //may restart Teensy with macro CPU_RESTART but loose USB connection
#define ECHO_COMMANDS // Un-comment to echo AT+ commands to serial monitor
// Print error message and loop stop.
void errorHalt(String msg)
Serial.println(msg);
Serial.println("*HALT*");
//CPU_RESTART //xxx
while(true){};
// Read characters from WiFi module and echo to serial until keyword occurs or timeout.
boolean echoFind(String keyword)
byte current_char = 0;
byte keyword_length = keyword.length();
// Fail if the target string has not been sent by deadline.
long deadline = millis() + TIMEOUT;
while(millis() < deadline)
if (Serial1.available())
char ch = Serial1.read();
Serial.write(ch);
if (ch == keyword[current_char])
if (++current_char == keyword_length)
return true;
return false; // Timed out
// Read and echo all available module output.
// (Used when we're indifferent to "OK" vs. "no change" responses or to get around firmware bugs.)
void echoFlush()
{while(Serial1.available()) Serial.write(Serial1.read());}
// Echo module output until 3 newlines encountered.
// (Used when we're indifferent to "OK" vs. "no change" responses.)
void echoSkip()
echoFind("\n"); // Search for nl at end of command echo
echoFind("\n"); // Search for 2nd nl at end of response.
echoFind("\n"); // Search for 3rd nl at end of blank line.
// Send a command to the module and wait for acknowledgement string
// (or flush module output if no ack specified).
// Echoes all data received to the serial monitor.
boolean echoCommand(String cmd, String ack, boolean halt_on_fail)
Serial1.println(cmd);
#ifdef ECHO_COMMANDS
Serial.print("-->"); Serial.println(cmd);
// If no ack response specified, skip all available module output.
if (ack == "")
echoSkip();
// Otherwise wait for ack.
if (!echoFind(ack)) // timed out waiting for ack string
if (halt_on_fail) // CONTINUE=false - skip critical halt
errorHalt(cmd+" *failed");// Critical failure halt. ( ack not empty and not found and Halt true )
return false; // Let the caller handle it.
Serial.println("*==================*"); // request and answer OK
return true; // ack blank or ack found
// Connect to the specified wireless network.
boolean connectWiFi()
String cmd = "AT+CWJAP=\""; cmd += SSID; cmd += "\",\""; cmd += PASS; cmd += "\"";
//AT+CWJAP="SSID","12345678"
if (echoCommand(cmd, "OK", CONTINUE)) // Join Access Point
Serial.println("*connected to WiFi*");
return true;
Serial.println("*Connection to WiFi failed.");
return false;
// ******** SETUP ********
Serial.begin(115200); // Arduino serial Monitor via USB Teensy3.1
Serial1.begin(115200); // Communication with ESP8266
Serial1.setTimeout(TIMEOUT);
delay(5000); // wait for serial init
// echoCommand("AT+CIOBAUD=115200", "BAUD->115200", CONTINUE); // or 9600 if you like it - slow need hard reset
while(!Serial); // wait for open USBser
Serial.println("*ESP8266 Demo*\n\r*0018000922 !*");
Serial.println("*on Teensy 3.1*");
echoCommand("AT+CHELLO", "OK", CONTINUE);
echoCommand("AT+RST", "[System Ready, Vendor:www.ai-thinker.com]", HALT); // Reset & test if the module is ready
Serial.println("*Module is ready.");
echoCommand("AT+GMR", "OK", CONTINUE); // Retrieves the firmware ID (version number) of the module.
// Get connection status
echoCommand("AT+CIPSTATUS", "OK", CONTINUE); // Status:TCP/IP
echoCommand("AT+CWMODE=1", "", HALT); // Station mode - maybe " no change " only
echoCommand("AT+CWMODE?","OK", CONTINUE);// Get module access mode.
echoCommand("AT+CWLAP", "OK", CONTINUE); // List available access points
echoCommand("AT+CIPMUX=1", "OK", HALT); // Allow multiple connections (we'll only use the first).
echoCommand("AT+CIPMODE?", "OK", HALT); // default=0
//connect to the wifi
boolean connection_established = false;
for(int i=0;i<5;i++)
if(connectWiFi())
connection_established = true;
echoCommand("AT+CIFSR", "OK", HALT); // Echo IP address. also 0.0.0.0 is possible but bad)
if (!connection_established) errorHalt("*Connection failed");
delay(5000);
//echoCommand("AT+CWSAP?", "OK", CONTINUE); // set the parameters of AP and Test - maybe only first time useful
// ******** LOOP ********
// Establish TCP connection
// AT+CIPSTART=0,"TCP","192.254.235.21",80
String cmd = "AT+CIPSTART=0,\"TCP\",\""; cmd += DEST_IP; cmd += "\",80";
if (!echoCommand(cmd, "Linked", HALT)) return; //no ip//Link typ ERROR
echoCommand("AT+CIPSTATUS", "OK", CONTINUE); // Status:3 ist ok
// Build HTTP request. GET / HTTP/1.1
//Host: retro.hackaday.com:80
cmd = "GET / HTTP/1.1\r\nHost: "; cmd += DEST_HOST; cmd += ":80\r\n\r\n";
// Ready the module to receive raw data
if (!echoCommand("AT+CIPSEND=0,"+String(cmd.length()), ">", HALT))
echoCommand("AT+CIPCLOSE", "", CONTINUE);
Serial.println("*Connection timeout.");
return;
// Send the raw HTTP request
echoCommand(cmd, "OK", CONTINUE); // GET
// Loop forever echoing data received from destination server.
while(true)
errorHalt("ONCE ONLY"); // never happens to me
