Hi folks! A few years ago this forum was very helpful with the guitar-mounted midi controller that I built (here's a video if you'd like to check it out), and it recently occurred to me that I could significantly simplify my setup if I just added a extra TRS jack to my project box and connected my expression pedal to that. Then I would only need to connect my little Teensy-LC box to my laptop and use it for both my guitar mounted midi controller and my expression pedal, and then I wouldn't need to worry about replacing the batteries in my iRig Blueboard all the time.
So it's been a while, but if memory serves, I just need to wire a TRS jack to the pins on the other side of the Teensy board -- the side with the paired pins. I'm a little less clear on the what to add to my existing code. So this is all my long-winded way of asking what's the code for an expression pedal? Sorry for such a newbie question; I did look around for an answer on the website, and I gathered that I'll need the analogRead() function, but other than that I'm really not sure. Here's my code so far. As you can see, it's just a simple twelve button (six rocker) setup, and all I want to do is add one knob. Thanks!
#include <Bounce.h> // Bounce library makes button change detection easy
const int channel = 0;
const int CC5 = 16 ;
const int CC6 = 17 ;
const int CC7 = 18 ;
const int CC8 = 19 ;
const int CC9 = 20 ;
const int CC10 = 21 ;
const int CC11 = 22 ;
const int CC12 = 23 ;
Bounce button1 = Bounce(1, 5); // 5 = 5 ms debounce time
Bounce button2 = Bounce(2, 5); // which is appropriate for good quality mechanical pushbuttons
Bounce button3 = Bounce(3, 5);
Bounce button4 = Bounce(4, 5);
Bounce button5 = Bounce(5, 5);
Bounce button6 = Bounce(6, 5);
Bounce button7 = Bounce(7, 5);
Bounce button8 = Bounce(8, 5);
Bounce button9 = Bounce(9, 5);
Bounce button10 = Bounce(10, 5);
Bounce button11 = Bounce(11, 5);
Bounce button12 = Bounce(12, 5);
pinMode(1, INPUT_PULLUP);
pinMode(2, INPUT_PULLUP);
pinMode(3, INPUT_PULLUP);
pinMode(4, INPUT_PULLUP);
pinMode(5, INPUT_PULLUP);
pinMode(6, INPUT_PULLUP);
pinMode(7, INPUT_PULLUP);
pinMode(8, INPUT_PULLUP);
pinMode(9, INPUT_PULLUP);
pinMode(10, INPUT_PULLUP);
pinMode(11, INPUT_PULLUP);
pinMode(12, INPUT_PULLUP);
button1.update();
button2.update();
button3.update();
button4.update();
button5.update();
button6.update();
button7.update();
button8.update();
button9.update();
button10.update();
button11.update();
button12.update();
// CC messages when each button is pressed
if (button1.fallingEdge()) {
usbMIDI.sendNoteOn(60, 99, channel); // 60 = C4
if (button2.fallingEdge()) {
usbMIDI.sendNoteOn(61, 99, channel); // 61 = C#4
if (button3.fallingEdge()) {
usbMIDI.sendNoteOn(62, 99, channel); // 62 = D4
if (button4.fallingEdge()) {
usbMIDI.sendNoteOn(63, 99, channel); // 63 = Eb4
if (button5.fallingEdge()) {
usbMIDI.sendControlChange(CC5, 127, channel);
if (button6.fallingEdge()) {
usbMIDI.sendControlChange(CC6, 127, channel);
if (button7.fallingEdge()) {
usbMIDI.sendControlChange(CC7, 127, channel);
if (button8.fallingEdge()) {
usbMIDI.sendControlChange(CC8, 127, channel);
if (button9.fallingEdge()) {
usbMIDI.sendControlChange(CC9, 127, channel);
if (button10.fallingEdge()) {
usbMIDI.sendControlChange(CC10, 127, channel);
if (button11.fallingEdge()) {
usbMIDI.sendControlChange(CC11, 127, channel);
if (button12.fallingEdge()) {
usbMIDI.sendControlChange(CC12, 127, channel);
// CC messages when each button is released
if (button1.risingEdge()) {
usbMIDI.sendNoteOff(60, 0, channel);
if (button2.risingEdge()) {
usbMIDI.sendNoteOff(61, 0, channel);
if (button3.risingEdge()) {
usbMIDI.sendNoteOff(62, 0, channel);
if (button4.risingEdge()) {
usbMIDI.sendNoteOff(63, 0, channel);
if (button5.risingEdge()) {
usbMIDI.sendControlChange(CC5, 0, channel);
if (button6.risingEdge()) {
usbMIDI.sendControlChange(CC6, 0, channel);
if (button7.risingEdge()) {
usbMIDI.sendControlChange(CC7, 0, channel);
if (button8.risingEdge()) {
usbMIDI.sendControlChange(CC8, 0, channel);
if (button9.risingEdge()) {
usbMIDI.sendControlChange(CC9, 0, channel);
if (button10.risingEdge()) {
usbMIDI.sendControlChange(CC10, 0, channel);
if (button11.risingEdge()) {
usbMIDI.sendControlChange(CC11, 0, channel);
if (button12.risingEdge()) {
usbMIDI.sendControlChange(CC12, 0, channel);
// MIDI Controllers should discard incoming MIDI messages.
while (usbMIDI.read()) {
