Help with LEDs + playing audio file when button is pressed
jnashself
I'm working on a project that when a button is pressed will fade on/off multiple LEDs (two in the code below) for a specified time and play an audio file. Right now the code as is just constantly fades the LEDs on/off without the button press. The button works to play the audio file but when it is playing the LEDs just go to a high state and stop fading until the audio file stops.
The code I have so far seems to be close but I'm not sure if it can do what I'm wanting or if there a lines in the code just in the wrong place.
Using a Teensy 4.1 with the Audio Shield Rev. D
Thanks for any insight...
//Play a .wav file and flash LEDs when button is pressed:
//Only flashes LEDs when button is not pressed and playing wav file,
//otherwise LEDs run forever. When button is pressed LEDs just go
//into HIGH state (all on)
#include <SerialFlash.h>
const int buttonPin = 33; // Pin connected to the button
const int ledPin = 13; // Pin connected to the onboard LED
const int chipSelect = BUILTIN_SDCARD;
const int ledPin1 = 36; // Pin for the first LED
const int ledPin2 = 14; // Pin for the second LED
unsigned long previousMillis1 = 0; // Stores the previous time for LED 1
unsigned long previousMillis2 = 0; // Stores the previous time for LED 2
const long interval1 = 18; // Interval between brightness changes for LED 1
const long interval2 = 25; // Interval between brightness changes for LED 2
int brightness1 = 0; // Current brightness of the first LED
int brightness2 = 0; // Current brightness of the second LED
int fadeAmount1 = 5; // How much to fade LED 1
int fadeAmount2 = 3; // How much to fade LED 2
bool isPlaying = false; // Flag to indicate if the audio is playing
AudioPlaySdWav playSdWav1;
AudioOutputI2S i2s1;
AudioConnection patchCord1(playSdWav1, 0, i2s1, 0);
AudioConnection patchCord2(playSdWav1, 1, i2s1, 1);
#define SDCARD_CS_PIN BUILTIN_SDCARD
#define SDCARD_MOSI_PIN 11 // not actually used
#define SDCARD_SCK_PIN 13 // not actually used
pinMode(buttonPin, INPUT_PULLUP);
pinMode(ledPin, OUTPUT);
pinMode(ledPin1, OUTPUT);
pinMode(ledPin2, OUTPUT);
AudioMemory(20);
sgtl5000_1.enable();
sgtl5000_1.volume(0.4);
SPI.setMOSI(SDCARD_MOSI_PIN);
SPI.setSCK(SDCARD_SCK_PIN);
while (1) {
Serial.println("Setup complete.");
unsigned long currentMillis = millis(); // Get the current time
// Check if it's time to change brightness for LED 1
if (currentMillis - previousMillis1 >= interval1) {
// Save the last time you changed brightness for LED 1
previousMillis1 = currentMillis;
// Update the brightness of LED 1
analogWrite(ledPin1, brightness1);
// Change brightness for LED 1
brightness1 = brightness1 + fadeAmount1;
// Reverse direction when reaching max or min brightness for LED 1
if (brightness1 <= 0 || brightness1 >= 255) {
fadeAmount1 = -fadeAmount1;
if (digitalRead(buttonPin) == LOW && !isPlaying) { // If button is pressed and audio is not playing
digitalWrite(ledPin, HIGH); // Turn on LED to indicate playback
isPlaying = true;
Serial.println("Playing .wav file");
playSdWav1.play("Tiger.wav"); // Play the .wav file
while (playSdWav1.isPlaying()) { // Wait until playback is finished
isPlaying = false;
digitalWrite(ledPin, LOW);// Turn off LED
// Check if it's time to change brightness for LED 2
if (currentMillis - previousMillis2 >= interval2) {
// Save the last time you changed brightness for LED 2
previousMillis2 = currentMillis;
// Update the brightness of LED 2
analogWrite(ledPin2, brightness2);
// Change brightness for LED 2
brightness2 = brightness2 + fadeAmount2;
// Reverse direction when reaching max or min brightness for LED 2
if (brightness2 <= 0 || brightness2 >= 255) {
fadeAmount2 = -fadeAmount2;
digitalWrite(ledPin1, LOW);
digitalWrite(ledPin2, LOW);
This code stops loop() cycling that is stopping the LED cycling.
Rewrite loop() to use a static isPlaying {or GLOBAL as it is} to allow it to start on a button press and monitor the value of playSdWav1.isPlaying() to set it back false when complete but not stop the loop() with the while() as written.
Also when pasting code put it in CODE blocks using the "</>" icon on the toolbar.
Seems a small change like this might work?
if (!isPlaying && digitalRead(buttonPin) == LOW ) { // If button is pressed and audio is not playing
  isPlaying = true;
if (!playSdWav1.isPlaying()) { // Update when playback is finished
  isPlaying = false;
