local_dani_21
Hi Paul, hi everybody
I've been using a Teensy - hardware serial - RPi - setup using Mattias Schlenkers "nuage" for a while (http://www.arduino-hausautomation.de/nuage/). It works very well. It would be very interesting though to be able to program the teensy using hardware serial. Is that possible? If not - why? Would there be a possible solution (e.g. with a modified Halfkay)?. I think it would make teensies a lot more attractive, if the original Arduino IDE could be used to upload code to a (nuage)-network attached teensy. Mattias offered to modify his nuage-setup if possible so it would work well with your great boards.
Thanks for considering,
Dani
Dani
