Issue with fade function
adramelek
Hello,
I'm experimenting with teensy and I don't understand why the fade function isn't working properly at the first launch of the raw file, but only at the second and further. Here is my code from the recorder example. Thanks for your help ! Cédric
// Record sound as raw data to a SD card, and play it back.
// Requires the audio shield:
//   http://www.pjrc.com/store/teensy3_audio.html
// Three pushbuttons need to be connected:
//   Record Button: pin 0 to GND
//   Stop Button:   pin 1 to GND
//   Play Button:   pin 2 to GND
// This example code is in the public domain.
#include <Bounce.h>
#include <SerialFlash.h>
AudioInputI2S            i2s2;           //xy=278,225
AudioAnalyzePeak         peak1;          //xy=451,270
AudioRecordQueue         queue1;         //xy=454,225
AudioPlaySdRaw           playRaw1;       //xy=540,75
AudioEffectFade          fade1;          //xy=574,183
AudioOutputI2S           i2s1;           //xy=820,159
AudioConnection          patchCord1(i2s2, 0, queue1, 0);
AudioConnection          patchCord2(i2s2, 0, peak1, 0);
AudioConnection          patchCord3(playRaw1, fade1);
AudioConnection          patchCord4(fade1, 0, i2s1, 0);
AudioConnection          patchCord5(fade1, 0, i2s1, 1);
AudioControlSGTL5000     sgtl5000_1;     //xy=438,374
// Bounce objects to easily and reliably read the buttons
Bounce buttonRecord = Bounce(0, 8);
Bounce buttonStop =   Bounce(1, 8);  // 8 = 8 ms debounce time
Bounce buttonPlay =   Bounce(2, 8);
// which input on the audio shield will be used?
// Use these with the Teensy Audio Shield
#define SDCARD_CS_PIN    10
#define SDCARD_MOSI_PIN  11   // Teensy 4 ignores this, uses pin 11
#define SDCARD_SCK_PIN   13  // Teensy 4 ignores this, uses pin 13
// Use these with the Teensy 3.5 & 3.6 & 4.1 SD card
//#define SDCARD_CS_PIN    BUILTIN_SDCARD
//#define SDCARD_MOSI_PIN  11  // not actually used
//#define SDCARD_SCK_PIN   13  // not actually used
// Use these for the SD+Wiz820 or other adaptors
//#define SDCARD_CS_PIN    4
// Remember which mode we're doing
int mode = 0;  // 0=stopped, 1=recording, 2=playing
// The file where data is recorded
File frec;
  // Configure the pushbutton pins
  pinMode(0, INPUT_PULLUP);
  pinMode(1, INPUT_PULLUP);
  pinMode(2, INPUT_PULLUP);
  AudioMemory(60);
  sgtl5000_1.enable();
  sgtl5000_1.volume(0.8);
  // Initialize the SD card
  SPI.setMOSI(SDCARD_MOSI_PIN);
  SPI.setSCK(SDCARD_SCK_PIN);
    while (1) {
  // First, read the buttons
  buttonRecord.update();
  buttonStop.update();
  buttonPlay.update();
  // Respond to button presses
  if (buttonRecord.fallingEdge()) {
    Serial.println("Record Button Press");
    if (mode == 2) stopPlaying();
    if (mode == 0) startRecording();
  if (buttonStop.fallingEdge()) {
    Serial.println("Stop Button Press");
    if (mode == 1) stopRecording();
  if (buttonPlay.fallingEdge()) {
    Serial.println("Play Button Press");
    if (mode == 0) startPlaying();
  // If we're playing or recording, carry on...
  if (mode == 1) {
    continueRecording();
  if (mode == 2) {
    continuePlaying();
void startRecording() {
  Serial.println("startRecording");
  if (SD.exists("RECORD.RAW")) {
    // The SD library writes new data to the end of the
    // file, so to start a new recording, the old file
    // must be deleted before new data is written.
    SD.remove("RECORD.RAW");
  frec = SD.open("RECORD.RAW", FILE_WRITE);
  if (frec) {
    queue1.begin();
    mode = 1;
void continueRecording() {
  if (queue1.available() >= 2) {
    byte buffer[512];
    // into a 512 byte buffer.  The Arduino SD library
    // writes are used.
    memcpy(buffer, queue1.readBuffer(), 256);
    queue1.freeBuffer();
    memcpy(buffer+256, queue1.readBuffer(), 256);
    // write all 512 bytes to the SD card
    //elapsedMicros usec = 0;
    frec.write(buffer, 512);
    // Uncomment these lines to see how long SD writes
    // are taking.  A pair of audio blocks arrives every
    // 5802 microseconds, so hopefully most of the writes
    // take well under 5802 us.  Some will take more, as
    // the SD library also must write to the FAT tables
    // and the SD card controller manages media erase and
    // wear leveling.  The queue1 object can buffer
    // approximately 301700 us of audio, to allow time
    // for occasional high SD card latency, as long as
    // the average write time is under 5802 us.
    //Serial.print("SD write, us=");
    //Serial.println(usec);
void stopRecording() {
  Serial.println("stopRecording");
  queue1.end();
  if (mode == 1) {
      frec.write((byte*)queue1.readBuffer(), 256);
    frec.close();
  mode = 0;
void startPlaying() {
  Serial.println("startPlaying");
  AudioNoInterrupts();
    fade1.fadeIn(1000);
  playRaw1.play("RECORD.RAW");
  AudioInterrupts();
  mode = 2;
void continuePlaying() {
if(playRaw1.lengthMillis()-playRaw1.positionMillis()<=500){
  fade1.fadeOut(500);
  if (!playRaw1.isPlaying()) {
      Serial.println("fade");
    playRaw1.stop();
    mode = 0;
void stopPlaying() {
  if (mode == 2){
    playRaw1.stop();
  mode = 0;
Which version of Teensyduino are you using? There's a fix to the fader available in the Teensyduino 1.60 beta (link is to latest, but that may change).
The fix is that the fader wouldn't change values if it wasn't being fed audio, so even if you put fade1.fadeOut(500); in your setup() (which you haven't...), nothing would have happened. As the fader starts at max volume, your first playback will do so too, so you need to use the 1.60 beta, and ensure you set the fader to minimum volume before you first play back.
Also note ... if you stop playing by pressing the button ... you don't turn the fader down, so the next play will start at maximum volume again!
Ah thank you ! Cool this beta version solve the problem ! I now reset to zero each fader, at the begining and at stop, it was in fact very logical :) Many thanks !
