hi there,
when sending poly pressure out of a teensy 3.6 via usb-host port, it does not work properly.
when i send the same data via usb-midi it works fine.
sending poly pressure via usb-host results in VERY sporadic data being sent (only on note on maybe).
i am sending the exact same command for both ports, see code snippet:
for usb-host i am sending to 8 ports of a hub. i use this method for all different kinds of messages, aftertouch, note on and off, control change, pitchbend...it works on all messages except for poly pressure. could there be a bug in the usb-host midi implementation?
usbMIDI.sendPolyPressure(map_string_Fsr, active_Note[1], 3);
for (int i=0; i<7; i++) {
if (i != footpedal) {
midilist[i]->sendPolyPressure(map_string_Fsr, active_Note[1], 3);
midilist[i]->send_now();
