Narrowboater
Please find below my code for linking 2-n T3.6s using
DMA
8 bit parallel data transfer
a round-robin record transfer using 4-508 byte records
identical code on all processors
This is just a fun program with no practical application as far as I can see as it uses too many pins leaving few useful ones eg SPI for other work.
The code is somewhat crude but I believe it works.
It is not particularly optimised for speed and I see about 577000 bytes per sec travelling around the ring for a 508 byte record on a 3 teensy ring with no real work being done on each record.
Any comments would be appreciated.
There is one known bug as follows:
When the inbound DMA is first enabled, it executes one minor loop immediately despite the fact that it is supposed to be hardware triggered by a clock pin which it does properly ever after. The code includes a one-time bodge to reset the TCD after this minor loop and it seems to work perfectly thereafter. If anybody can shed light on this I would be grateful.
DMA
// DmaSharexx.ino
// This is a Fun program with no defined application and probably no practical use.
// NOTE: This program uses very crude code owing to a lack of brain cells in the author.
// It may contain crude coding errors!
// Objectives:
// To share data between n teensies where n is any number greater than 1 using
// a round robin technique with a single record of 4-508 bytes passed from one to the next
// using the same code in all teensies connected in a ring.
// To pass data 8 bits at a time
// To use DMA to the maximum extent for both data input and output
// Comments:
// The physical configuration is the same on all teensies
// The same code is used on all teensies
// 18 pins are used:
// 8 data in - contiguous bits on Port D
// 8 data out - contiguous bits on Port C
// 1 clock pin in - Pin 3 on Port A
// 1 clock pin out - Pin 33 on Port E
// [10 LED driving debug pins are also in the code but are not essential]
// This does not leave many pins for doing anything else and, more importantly,
// uses up pins normally used for other things eg SPI
// The main loop has to adhere to a specific protocol, with opportunities to do
// useful work within that. It cannot observe its own routine and call on these
// services when it wants to.
// The data record length is fixed at 4 - 508 bytes & must be a multiple of 4.
// The upper limit is fixed by DMA using 9 bits for the length when linking.
// Only one record is travelling around the ring.
// The data throughput is the sum of the read, processing, and write times for
// all the processors on the ring.
// Measured: For 3 processors & Rec Len = 508
// 577037 bytes/sec = ~4.6Mbits/sec.
// The main loop() code could be simplified for more speed.
// The code uses dmaChannel mostly but not entirely. Direct TCD manipulation is also used. (??)
// Basic Mechanism:
// Main Loop:
// If record read
// process record
// write the record (with or without changes)
// Detailed Mechanism:
// A DMA read channel is permanently enabled, awaiting a hardware trigger.
// This will wait without blocking the cpu until activated by an incoming clock pulse,
// On completion the DMA read will call an interrupt which will flag the read buffer as FULL.
// The main loop detects the read and processes the record.
// It then writes the record by starting a DMA channel (the data-out channel) to throw
// the bytes of the record at the port.
// After each 4 bytes (one minor transfer which is one port-write), this channel stops
// and triggers another channel (the clock channel) which throws a succession of
// bits at an output pin, generating a clock signal.
// The clock channel triggers itself until complete and then triggers the data-out
// channel to send the next byte.
// This process continues until the data-out channel has sent the entire record.
// The record write does not check for the following processor being ready to receive,
// it is assumed that it always is.
// The main loop must always write the record out again.
// The main loop can take as long as it likes between reading a record and
// rewriting it, but obviously this delays the record around the ring.
// Other Details:
// All port transfers are 32 bit. The T3.6 has 8 bit port capability but this is not used.
// All data is translated from 8 bit to 32 bit before sending.
// All data is translated from 32 bit to 8 bit after receiving.
// Both data and clock are sent to the ports' toggle registers to ensure that
// only the bits desired are affected, other bits on the ports are not affected.
// The clock data out consists of a load of no-op bits to the port followed by
// a single toggle bit, a string of no-ops, a toggle bit, and more no-ops.
// This can be tailored to give a desired clock pulse width.
// The record length is fixed at compile time for all the processors involved.
// The DMA data-out channel is configured to send a final byte which sets the port
// to 0xFF. This enables the toggling function to calculate toggle bits on the
// assumption that the port always starts off as 0xFF. The final byte is not clocked
// and so is not read by the following processor.
// Unfortunately it is necessary at this time to specify the serial numbers of all
// the teensies used in the program.
// The teensy with the lowest serial will function as the Master, which is responsible
// for creating the record in the beginning, but has no other function.
// The contents of the record are entirely up to the user, a CRC check of some
// sort is recommended.
#include <DMAChannel.h>
#include <TeensyID.h>
// Teensy Serial Number
union {
uint32_t myTeensySerial;
uint8_t serial[4];
} myId;
uint32_t serialList[3] = {578792,840980,841146}; // Ix = 1,2,3 - 0=error
uint32_t noOfProcessors = (sizeof(serialList))/4; // there must be a better way!
uint8_t mySerialIx = 0;
// Master
bool weAreMaster; // true = we will generate the starting record
volatile bool initialRecordToBeCreated; // true = we will be haven't yet generated the start record
#define myEMPTY false
#define myFULL true
volatile bool ibPackedBuffStatus = myEMPTY;
volatile uint32_t dmaGetCnt = 0;
uint32_t loopCnt = 0;
uint32_t startMillis = 0;
// CHANNEL ORDER IS NOT IMPORTANT (to be confirmed)
// The following uses available channels from 0 upwards
// They are usually 0,1,2 but may change if libraries alloc channels first
// The code is not number dependant
// The relevant priority wrt libraries if used should be considered
DMAChannel ibDmaTcdDataChan; // 0 IB data channel
DMAChannel obDmaTcdDataChan; // 1 OB data channel
DMAChannel obDmaTcdClockChan; // 2 OB clock channel
// BUFFERS
// CHANGE THIS (AND ONLY THIS) TO SET THE RECORD SIZE
#define DMADATASIZE8 508 // in bytes - min 4 max 508 (9 bits)
#define DMABUFFSIZEIBPK32 (DMADATASIZE8)
#define DMABUFFSIZEIBPK8 (DMADATASIZE8 * 4)
#define DMABUFFSIZEIBUP32 (DMADATASIZE8/4)
#define DMABUFFSIZEIBUP8 (DMADATASIZE8+1) // +1 is for the term 0x FF flag
#define DMABUFFSIZEOBUP32 (DMADATASIZE8/4)
#define DMABUFFSIZEOBUP8 (DMADATASIZE8+1) // +1 is for the term 0x FF flag
#define DMABUFFSIZEOBPK32 (DMADATASIZE8+1) // +1 is for the term 0x FF flag in a uint32
#define DMABUFFSIZEOBPK8 ((DMADATASIZE8+1) * 4)
// INBOUND
// IB data is read in as 1 byte stored as uint32_t's in ibPackedBuff
// and then condensed as 1 byte as 1 byte into ibUnpackedBuff
volatile uint32_t padding1[32]; // paddings defined to detect buffer overruns in testing
union {
volatile uint32_t buff32[DMABUFFSIZEIBPK32]; //
volatile uint8_t buff8 [DMABUFFSIZEIBPK8]; // for presetting ib area to detect ib change, only
} volatile ibPackedBuff;
volatile uint32_t padding2[32];
union {
volatile uint32_t buff32[DMABUFFSIZEIBUP32]; // for user data manip only
volatile char str[44];
volatile uint32_t serial;
volatile uint8_t buff8 [DMABUFFSIZEIBUP8];
} volatile ibUnpackedBuff;
// OUTBOUND
// Data is stored by the user as bytes in obUnpackedBuff and then expanded to
// uint32_t per byte in toggle format as the data is written to the port toggle register.
// This makes it easy to just hit the bottom 8 bits of the port register.
// The T3.6 can do 8 bit port writes but this is not supported by later devices eg T4.x
// so is not used here.
volatile uint32_t padding3[32];
union {
volatile uint32_t buff32[DMABUFFSIZEOBUP32]; // for user data manip only
volatile uint8_t buff8 [DMABUFFSIZEOBUP8];
} volatile obUnpackedBuff;
volatile uint32_t padding4[32];
union {
volatile uint32_t buff32[DMABUFFSIZEOBPK32];
volatile uint8_t buff8 [DMABUFFSIZEOBPK8];
} volatile obPackedBuff;
volatile uint32_t padding5[32];
// CLOCK
// Only two toggle bytes transmitted change anything, the rest are
// just no-ops to fix the position with respect to the data byte and
// to set the width of the clock pulse.
#define OBCLOCKDATALEN8 (2*4) // must be 8 - 508 and a multiple of 4
volatile uint32_t padding6;
union {
volatile uint32_t buff32[OBCLOCKDATALEN8/4];
volatile uint8_t buff8 [OBCLOCKDATALEN8];
} volatile obClock;
// TEENSY IO REGISTERS for Teensy 3.6
// WARNING - "V" PINS ARE ON THE BACK OF THE BOARD
// WARNING You cannot use the pin values via pinXtable[n] from the tables below
// without explicitly translating them into the correct registers for the device
// you are using so explicit pin numbers are used in this program for simplicity.
// *=*=* PortA, 10 bits
// V V V
// A5,A12,A13,A14,A15,A16,A17,A26,A28,A29
//byte pinAtable[] = { 25, 3, 4, 26, 27, 28, 39, 42, 40, 41};
// none used
// *=*=* PortB, 16 bits
// V V V V V V
// B0, B1, B2, B3, B4, B5,B10,B11,B16,B17,B18,B19,B20,B21,B22,B23
//byte pinBtable[] = { 16, 17, 19, 18, 49, 50, 31, 32, 0, 1, 29, 30, 43, 46, 44, 45};
// debug D5 D6 D8 D7 D2 D1 D9 D10 D4 D3
// *=*=* PortC -> 12 bits, but LED is on pin 13, pins all in binary order!!!!
// all on front
// C0, C1, C2, C3, C4, C5, C6, C7, C8, C9,C10,C11
//uint8_t pinCtable[] = { 15, 22, 23, 9, 10, 13, 11, 12, 35, 36, 37, 38};
// using the first 8 bits for data inbound
// *=*=* PortD, 8 bits in binary order.
// all on front
// D0, D1, D2, D3, D4, D5, D6, D7
//uint8_t pinDtable[] = { 2, 14, 7, 8, 6, 20, 21, 5};
// using the first 8 bits for data outbound
// *=*=* PortE, 5 bits, in binary order.
// V V
// E10,E11,E24,E25,E26 NOT CONTIG
//byte pinEtable[] = { 56, 57, 33, 34, 24};
// clock out, in * *
// note: E0 - E5 used by built-in SDCARD
// using 33 & 34 as clock out & clock in
#define CLOCK_OUT_PIN 33 // NOT REFERENCED - the port bit is used instead
#define CLOCK_OUT_PORT_BIT (1<<0) // Pin 33 = bit 24 of Port E = 0th bit of MSByte
#define CLOCK_IN_PIN 34 // NOT REFERENCED - only the port E is accessed!
// 10 pins used to drive LEDs for debugging
#define DEBUG_PIN_01 32
#define DEBUG_PIN_02 31
#define DEBUG_PIN_03 30
#define DEBUG_PIN_04 29
#define DEBUG_PIN_05 16
#define DEBUG_PIN_06 17
#define DEBUG_PIN_07 18
#define DEBUG_PIN_08 19
#define DEBUG_PIN_09 0
#define DEBUG_PIN_10 1
// PRINT ROUTINES
void printIbPackedBuff(int event, int loop) {
Serial.printf("IBPK %d %d\n",event,loop);
for (int ii = 0; ii < DMABUFFSIZEIBPK8;ii++ ){
Serial.printf("%02X ",ibPackedBuff.buff8[ii]);
if (ii > 0) {
if ((ii+1) % 4 == 0) {Serial.printf(" ");}
if ((ii+1) % 16 == 0) {Serial.printf("\n");}
void printIbUnpackedBuff(int event, int loop) {
Serial.printf("IBUP %d %d - \n",event,loop);
for (int ii = 0; ii < DMABUFFSIZEIBUP8;ii++ ){
Serial.printf("%02X ",ibUnpackedBuff.buff8[ii]);
if (ii > 0) {
void printObPackedBuff(int event) {
Serial.printf("OBPK %d %d - \n",event,loop);
for (int ii = 0; ii < DMABUFFSIZEOBPK8;ii++ ){
Serial.printf("%02X ",obPackedBuff.buff8[ii]);
if (ii > 0) {
if ((DMABUFFSIZEOBPK8)%16==0){}
else {Serial.printf("\n");}
// BUFFER INITIALISATION ROUTINES
void setClockBuff() {
// Clear whole buffer to no-ops
for (int ii=0;ii<OBCLOCKDATALEN8/4;ii++){
obClock.buff32[ii] = 0x00; // address NO pins - this is a NO-OP
// set a specific pin bit here, that pin will be toggled
// on the first and last of the minor loops
// LSB FIRST so bit 24 is in the last byte!
obClock.buff8[3] = CLOCK_OUT_PORT_BIT; // set toggle pin for low
obClock.buff8[OBCLOCKDATALEN8 - 1] = CLOCK_OUT_PORT_BIT; // set toggle pin for high
void preSetIbPackedBuff() {
// Used for debugging only to prove that DMA has written to the buffer
for (int ii=0;ii<DMABUFFSIZEIBPK32-1;ii++){
ibPackedBuff.buff32[ii] = 0xAABBCCDD;
ibPackedBuff.buff32[DMABUFFSIZEIBPK32-1] = 0x11223344;
void setIbUnpackedBuff() {
for (int ii=0;ii<DMABUFFSIZEIBUP8;ii++) {
ibUnpackedBuff.buff8[ii] = 0x00;
ibUnpackedBuff.buff8[DMABUFFSIZEIBUP8-1] = 0xFF;
void setIbUnpackedBuffTesting() {
// Used in debugging only
ibUnpackedBuff.buff8[ii] = ii + 16;
return;
ibUnpackedBuff.buff8[0] = 0x11;
ibUnpackedBuff.buff8[1] = 0x12;
ibUnpackedBuff.buff8[2] = 0x13;
ibUnpackedBuff.buff8[3] = 0x14;
ibUnpackedBuff.buff8[4] = 0x15;
ibUnpackedBuff.buff8[5] = 0x16;
ibUnpackedBuff.buff8[6] = 0x17;
ibUnpackedBuff.buff8[7] = 0x18;
ibUnpackedBuff.buff8[8] = 0x19;
ibUnpackedBuff.buff8[9] = 0x1A;
ibUnpackedBuff.buff8[10] = 0x1B;
ibUnpackedBuff.buff8[11] = 0x0C;
// PACKING / UNPACKING ROUTINES
void unPackIbPkToIbUp() {
// Unpack IB Data - from ibPackedBuff to ibUnpackedBuff, freeing ibPackedBuff
for (int ii = 0; ii < DMABUFFSIZEIBPK32;ii++ ){
// The GPIO port is 32 bit but we only want 8
ibUnpackedBuff.buff8[ii] = ibPackedBuff.buff8[(ii*4)+0]; // in leftmost byte
void moveIbUpToObUp() {
for (int ii=0;ii<DMABUFFSIZEIBUP8;ii++) { // inc terminal 0xFF
obUnpackedBuff.buff8[ii] = ibUnpackedBuff.buff8[ii];
void packObUpToObPk() {
// assumes that the port takes bits 31-0 as 4 bytes
// Force the 0xFF in the INPUT data before we begin
obUnpackedBuff.buff8[DMABUFFSIZEOBUP8-1] = 0xFF; // force 0xFF for toggling
// convert the data in bytes to int32s
for (int ii=0;ii<DMABUFFSIZEOBUP8;ii++) {
obPackedBuff.buff8[(ii*4)+1] = 0x00;
obPackedBuff.buff8[(ii*4)+2] = 0x00;
obPackedBuff.buff8[(ii*4)+3] = 0x00;
if (ii==0) {
obPackedBuff.buff8[(ii*4)+0] = 0xFF ^ obUnpackedBuff.buff8[ii];
obPackedBuff.buff8[(ii*4)+0] = obUnpackedBuff.buff8[ii-1] ^ obUnpackedBuff.buff8[ii];
char transferSizeS[17];
char ssizeS[17];
char dsizeS[17];
void showTransferSize(int32_t size) {
switch (size) {
case 0: strcpy(transferSizeS,"8 bit"); break;
case 1: strcpy(transferSizeS,"16 bit"); break;
case 2: strcpy(transferSizeS,"32 bit"); break;
case 4: strcpy(transferSizeS,"16-byte burst"); break;
case 5: strcpy(transferSizeS,"32-byte burst"); break;
default: strcpy(transferSizeS,"INVALID");
void dumpDmaTcd (DMAChannel &dmabc, uint32_t event ) {
// FOR DEBUGGING ONLY
// THIS CODE NEEDS COMPLETE CHECKING
// NOTE using
// void dumpDmaTcd (DMAChannel dmabc, uint32_t event ) {
// results in the function reporting the TCD data correctly
// BUT DMA will fail invisibly afterwards!!!!
// Using & is essential !
// 32 bit registers have the low order byte first?
Serial.printf("\n*** TCD For Channel %d %s %d\n",dmabc.channel,"for Event",event);
// DMA STUFF
Serial.printf("DMA\n");
// DMA_CR
Serial.printf(" DMA_CR: %08X\n", DMA_CR);
Serial.printf(" DMA_CR_ES: %x\n" , DMA_ES);
Serial.printf(" DMA_CR_ERQ: %08X\n", DMA_ERQ);
Serial.printf(" DMA_CR_EEI: %x \n" , DMA_EEI);
Serial.printf(" DMA CR_ERR: %x\n" , DMA_ERR);
uint32_t *myQ = (uint32_t *)(0x4000800C);
Serial.printf("ERQ set for channels ");
if (*myQ & 0x000001) {Serial.printf("0 ");}
if (*myQ & 0x000002) {Serial.printf("1 ");}
if (*myQ & 0x000004) {Serial.printf("2 ");}
if (*myQ & 0x000008) {Serial.printf("3 ");}
Serial.printf( " DMA_ERQ %08X",*myQ); Serial.printf("\n");
//uint32_t *myX4 = (uint32_t *)(&DMA_CDNE); Serial.printf(" DMA_CDNE %08X",*myX4); is a clear reg!
uint32_t *myX5 = (uint32_t *)(&DMA_INT); Serial.printf( " DMA_INT %08X",*myX5);
uint32_t *myX6 = (uint32_t *)(&DMA_ERR); Serial.printf( " DMA_ERR %08X",*myX6);
uint32_t *myX8 = (uint32_t *)(&DMA_HRS); Serial.printf( " DMA_HRS %08X\n",*myX8);
// TCD STUFF
Serial.printf("TCD\n");
Serial.printf(" SADDR:%08X SOFF:%d",(uint32_t)dmabc.TCD->SADDR,dmabc.TCD->SOFF);
Serial.printf(" DADDR:%08X DOFF:%d",(uint32_t)dmabc.TCD->DADDR,dmabc.TCD->DOFF);
Serial.printf(" NBYTES:%d SLAST:%d\n", dmabc.TCD->NBYTES,dmabc.TCD->SLAST);
// TCD ATTR
int32_t dsize = dmabc.TCD->ATTR & 0b0000000000000111;
int32_t dmod = dmabc.TCD->ATTR & 0b0000000011111000; dmod >>= 3;
int32_t ssize = dmabc.TCD->ATTR & 0b0000011100000000; ssize >>= 8;
int32_t smod = dmabc.TCD->ATTR & 0b1111100000000000; smod >>= 11;
showTransferSize(ssize); strcpy(ssizeS,transferSizeS);
showTransferSize(dsize); strcpy(dsizeS,transferSizeS);
Serial.printf(" ATTR:%08X",dmabc.TCD->ATTR);
Serial.printf(" SMOD:%X SSIZE:%X DMOD:%d DSIZE:%d",smod,ssize,dmod,dsize);
Serial.printf(" SSIZE:%s DSIZE:%s\n",ssizeS,dsizeS);
uint16_t citer;
uint16_t citerCh;
char celnkS[17];
int16_t citerelnk = dmabc.TCD->CITER & 0x8000;
Serial.printf(" CITER:%08X",dmabc.TCD->CITER);
if (citerelnk != 0) {
citer = dmabc.TCD->CITER & 0x01FF;
citerCh = (dmabc.TCD->CITER & 0x3E00)>>9;
sprintf(celnkS,"YES, CH=%d",citerCh);
strcpy(celnkS,"NO ");
citer = dmabc.TCD->CITER & 0x7FFF;
uint32_t biter;
uint16_t biterCh;
char belnkS[17];
int16_t biterelnk = dmabc.TCD->BITER & 0x8000;
Serial.printf(" BITER:%08X",dmabc.TCD->BITER);
if (biterelnk != 0) {
biter = dmabc.TCD->BITER & 0x01FF;
biterCh = (dmabc.TCD->BITER & 0x3E00)>>9;
sprintf(belnkS,"YES, CH=%d",biterCh);
strcpy(belnkS,"NO ");
biter = dmabc.TCD->BITER & 0x7FFF;
Serial.printf(" CITER:%d BITER:%d CELNK:%s BELNK:%s\n",
citer, biter, celnkS, belnkS);
if (citerelnk != biterelnk) {
Serial.printf("CELNK DOES NOT MATCH BELNK\n");
if (citer != biter) {
Serial.printf("CITER DOES NOT MATCH BITER\n");
Serial.printf(" DLASTSGA:%08X\n", dmabc.TCD->DLASTSGA);
// CSR
Serial.printf(" CSR:%08X\n", dmabc.TCD->CSR);
Serial.printf(" BWC=%08X ", dmabc.TCD->CSR & DMA_TCD_CSR_BWC(0));
Serial.printf(" LINKCH=%08X ", dmabc.TCD->CSR & DMA_TCD_CSR_MAJORLINKCH(0));
Serial.printf(" MAJLINK=%08X\n", dmabc.TCD->CSR & DMA_TCD_CSR_MAJORELINK);
Serial.printf(" ESG=%08X ", dmabc.TCD->CSR & DMA_TCD_CSR_ESG);
Serial.printf(" DREQ=%08X ", dmabc.TCD->CSR & DMA_TCD_CSR_DREQ);
Serial.printf(" INTH=%08X ", dmabc.TCD->CSR & DMA_TCD_CSR_INTHALF);
Serial.printf(" INTF=%08X ", dmabc.TCD->CSR & DMA_TCD_CSR_INTMAJOR);
Serial.printf(" START=%08X\n", dmabc.TCD->CSR & DMA_TCD_CSR_START);
Serial.printf(" ACTIVE=%08X ", dmabc.TCD->CSR & DMA_TCD_CSR_ACTIVE);
Serial.printf(" DONE=%08X ", dmabc.TCD->CSR & DMA_TCD_CSR_DONE);
//Serial.printf("CITER:%0X %d\n",dmabc.TCD->CITER, dmabc.TCD->CITER);
//showDmaErr(dmabc.channel);
void showDmaErr(int ch) {
uint32_t *myErr = (uint32_t *)(0x40008004);
int worki;
//Serial.print("chECP=");
//Serial.println((int)myECP2,HEX);
Serial.print("Error Register: ");
Serial.println(*myErr,HEX);
worki = *myErr & 0x80000000; worki >>= 31;
if (worki==1){
worki = *myErr & 0x00000001; worki >>= 0;
if (worki==1){Serial.printf("DBE error\n");}
worki = *myErr & 0x00000002; worki >>= 1;
if (worki==1){Serial.printf("SBE error\n");}
worki = *myErr & 0x00000004; worki >>= 2;
if (worki==1){Serial.printf("SGE error\n");}
worki = *myErr & 0x00000008; worki >>= 3;
if (worki==1){Serial.printf("NCE error\n");}
worki = *myErr & 0x00000010; worki >>= 4;
if (worki==1){Serial.printf("DOE error\n");}
worki = *myErr & 0x00000020; worki >>= 5;
if (worki==1){Serial.printf("DAE error\n");}
worki = *myErr & 0x00000040; worki >>= 6;
if (worki==1){Serial.printf("SOE error\n");}
worki = *myErr & 0x00000080; worki >>= 7;
if (worki==1){Serial.printf("SAE error\n");}
worki = *myErr & 0x00001F00; worki >>= 8;
Serial.printf("error channel %d\n",worki);
worki = *myErr & 0x00004000; worki >>= 14;
if (worki==1){Serial.printf("CPE error\n");}
worki = *myErr & 0x00008000; worki >>= 15;
if (worki==1){Serial.printf("GPE error\n");}
worki = *myErr & 0x00010000; worki >>= 16;
if (worki==1){Serial.printf("ECX error\n");}
// TODO - USE portConfigRegister(pin);
void forceDataPinsHigh() { // used for debugging
// USE DIGITS DIRECTLY
digitalWrite(15,HIGH);
digitalWrite(22,HIGH);
digitalWrite(23,HIGH);
digitalWrite(9, HIGH);
digitalWrite(10,HIGH);
digitalWrite(13,HIGH);
digitalWrite(11,HIGH);
digitalWrite(12,HIGH);
// NOTE The last pin in the pin table gives the highest value bit
delayMicroseconds(5); // REQUIRED
int32_t getCiter(DMAChannel &dmabc) {
uint16_t citer;
return citer;
int32_t getBiter(DMAChannel &dmabc) {
uint16_t biter;
return biter;
void forceDataPinsLow() { // used for debugging
digitalWrite(15,LOW);
digitalWrite(22,LOW);
digitalWrite(23,LOW);
digitalWrite(9, LOW);
digitalWrite(10,LOW);
digitalWrite(13,LOW);
digitalWrite(11,LOW);
digitalWrite(12,LOW);
// DATA OUTPUT=PORTC INPUT=PORTD
// CLOCK OUTPUT=PORTE INPUT=PORTE
// DEBUGGING START
// 10 pins drive LEDs for debug communication when Serial is not in use
// ie when all processors are being powered by direct power USB source
// Setup debug pins
pinMode(DEBUG_PIN_01, OUTPUT);
pinMode(DEBUG_PIN_02, OUTPUT);
pinMode(DEBUG_PIN_03, OUTPUT);
pinMode(DEBUG_PIN_04, OUTPUT);
pinMode(DEBUG_PIN_05, OUTPUT);
pinMode(DEBUG_PIN_06, OUTPUT);
pinMode(DEBUG_PIN_07, OUTPUT);
pinMode(DEBUG_PIN_08, OUTPUT);
pinMode(DEBUG_PIN_09, OUTPUT);
pinMode(DEBUG_PIN_10, OUTPUT);
digitalWrite(DEBUG_PIN_01, LOW);
digitalWrite(DEBUG_PIN_02, LOW);
digitalWrite(DEBUG_PIN_03, LOW);
digitalWrite(DEBUG_PIN_04, LOW);
digitalWrite(DEBUG_PIN_05, LOW);
digitalWrite(DEBUG_PIN_06, LOW);
digitalWrite(DEBUG_PIN_07, LOW);
digitalWrite(DEBUG_PIN_08, LOW);
digitalWrite(DEBUG_PIN_09, LOW);
digitalWrite(DEBUG_PIN_10, LOW);
// DEBUGGING END
delay(5000);
// Handle the serial number of this Teensy
teensySN(myId.serial);
myId.myTeensySerial = __builtin_bswap32(myId.myTeensySerial); // IS THIS NECESSARY ? !!!
mySerialIx = getSerialIx(myId.myTeensySerial);
Serial.printf("SER=%d\n",myId.myTeensySerial);
// The processor with the lowest id is the Master
weAreMaster = true;
bool weAreInList = false;
for (uint32_t ii=0;ii<noOfProcessors;ii++){
if (serialList[ii] < myId.myTeensySerial) {weAreMaster = false;}
if (serialList[ii] == myId.myTeensySerial) {weAreInList = true ;}
if (weAreMaster){
initialRecordToBeCreated = true;
Serial.printf("MASTER=YES\n");
initialRecordToBeCreated = false;
Serial.printf("MASTER=NO\n");
// If our serial number is not in the list, hard stop
if (!weAreInList) {
Serial.printf("OUR SERIAL %d NOT IN LIST\n",myId.myTeensySerial);
Serial.printf(" %d\n",serialList[ii]);
while(1==1){} // HARD LOOP
Serial.printf("NOPR %d\n",noOfProcessors); // for debugging
// Build the clocking data
setClockBuff();
// Setup Data Input Pins
//for (int ii=0;ii<8;ii++) {pinMode(pinDtable[ii], INPUT);} WILL NOT WORK
pinMode(2, INPUT);
pinMode(14, INPUT);
pinMode(7, INPUT);
pinMode(8, INPUT);
pinMode(6, INPUT);
pinMode(20, INPUT);
pinMode(21, INPUT);
pinMode(5, INPUT);
// Setup Output Pins
pinMode(15,OUTPUT); // LSB
pinMode(22,OUTPUT);
pinMode(23,OUTPUT);
pinMode(9, OUTPUT);
pinMode(10,OUTPUT);
pinMode(13,OUTPUT);
pinMode(11,OUTPUT);
pinMode(12,OUTPUT); // MSB
// Set up Clock Pins
pinMode(33, OUTPUT);
digitalWrite(33, HIGH);
pinMode(34, INPUT);
// Put the data pins into a known starting position
forceDataPinsHigh();
// Set up the DMA channels
To initialize the eDMA: (ex the manual)
1. Write to the CR if a configuration other than the default is desired.
2. Write the channel priority levels to the DCHPRIn registers if a configuration other than the default is desired.
3. Enable error interrupts in the EEI register if so desired.
4. Write the 32-byte TCD for each channel that may request service.
5. Enable any hardware service requests via the ERQH and ERQL registers.
6. Request channel service via either:
• Software: setting the TCDn_CSR[START]
• Hardware: slave device asserting its eDMA peripheral request signal
// DMA CLOCK CHANNEL - ch 0
Serial.printf("Clock Channel is %d\n",obDmaTcdClockChan.channel);
//1 Write CR
//2 Write Priority
//3 Enable Error Interrupts
//4 Write TCD
obDmaTcdClockChan.begin();
obDmaTcdClockChan.destination((volatile uint32_t&)GPIOE_PTOR); // clock pin TOGGLE register
obDmaTcdClockChan.sourceBuffer((uint32_t *)obClock.buff32,OBCLOCKDATALEN8); // len is in BYTES!!!
obDmaTcdClockChan.disableOnCompletion();
//5 Enable any hardware service requests via the ERQH and ERQL registers.
// ERQH and ERQL are not defined anywhere!!!
//6 Request channel service via either:
// • Software: setting the TCDn_CSR[START]
// • Hardware: slave device asserting its eDMA peripheral request signal
// DMA DATA OB CHANNEL
Serial.printf("OB Channel is %d\n",obDmaTcdDataChan.channel);
//1 Write CR
//2 Write Priority
//4 Write TCD
obDmaTcdDataChan.begin();
obDmaTcdDataChan.destination((volatile uint32_t&)GPIOC_PTOR); // TOGGLE REGISTER
obDmaTcdDataChan.sourceBuffer((uint32_t *)obPackedBuff.buff32,(DMABUFFSIZEOBPK8)); // LEN in BYTES!!!
obDmaTcdDataChan.transferCount(DMABUFFSIZEOBPK32);
obDmaTcdDataChan.disableOnCompletion();
// Bandwidth Control. Provides a means of controlling the amount of bus bandwidth the eDMA uses.
// 00 No stalls–consume 100% bandwidth
// 01 Reserved
// 10 eDMA stalls for 4 cycles after each read/write
// 11 eDMA stalls for 8 cycles after each read/write
//obDmaTcdDataChan.TCD->CSR |= 0xC000; // or in the BWC
obDmaTcdClockChan.triggerAtTransfersOf( obDmaTcdDataChan);
obDmaTcdClockChan.triggerAtTransfersOf( obDmaTcdClockChan);
obDmaTcdDataChan.triggerAtCompletionOf( obDmaTcdClockChan);
// following not used as we send 0xFF to set the port but do not require
// the receiver to read it (as we could not get it to work!)
// not used - obDmaTcdClockChan.triggerAtCompletionOf(obDmaTcdDataChan);
// DMA DATA IB CHANNEL
Serial.printf("IB Channel is %d\n",ibDmaTcdDataChan.channel);
//1 Write CR
//2 Write Priority
//4 Write TCD
// Note This channel should never run against the other 2 channels but might
// encounter Library channels if any are added.
ibDmaTcdDataChan.begin();
ibDmaTcdDataChan.source((volatile uint32_t&) GPIOD_PDIR);
ibDmaTcdDataChan.destinationBuffer(ibPackedBuff.buff32,DMABUFFSIZEIBPK8); // note byte length
ibDmaTcdDataChan.transferCount(DMABUFFSIZEIBPK32); // ?????????????????????????????
// This channel is continuously enabled:
// ibDmaTcdDataChan.disableOnCompletion();
ibDmaTcdDataChan.attachInterrupt(dmaGetEndedInterrupt);
ibDmaTcdDataChan.interruptAtCompletion();
// The following type of "enable request" is needed for hardware triggering
ibDmaTcdDataChan.enable(); // same as next: // this triggers 1 minor loop
// DMA_SERQ = ibDmaTcdDataChan.channel;
// This channel is left enabled at the end of each major loop
//Address: 4002_1000h base + 0h offset + (1d × i), where i=0d to 31d
uint32_t *myQ = (uint32_t *)(0x40021000)+ibDmaTcdDataChan.channel;
*myQ = 0;
// *myQ = DMAMUX_ENABLE | (DMAMUX_SOURCE_PORTA & 63) ;
dumpDmaTcd(ibDmaTcdDataChan, 11111);
// *myQ = DMAMUX_ENABLE | DMAMUX_SOURCE_PORTA ;
*myQ = DMAMUX_ENABLE | DMAMUX_SOURCE_PORTE ;
dumpDmaTcd(ibDmaTcdDataChan, 22222);
//NVIC_SET_PRIORITY(IRQ_PORTE, 32); // not tried yet
PORTE_PCR25 |= PORT_PCR_IRQC(2); // Trigger DMA request on falling edge
// MISC NOTES
ibDmaTcdDataChan.triggerAtHardwareEvent(DMAMUX_SOURCE_PORTE);
dumpDmaTcd(ibDmaTcdDataChan, 33333);
delay(3000); // allow time for dma to do mischief
dumpDmaTcd(ibDmaTcdDataChan, 44444);
// **** Start Right Royal Bodge
// No matter how we set up the IB DMA channel, we always get one minor loop executed
// BEFORE we have received an input clock pin interrupt!
// This leaves the channel out of phase with the sender.
// This bodge modifies the TCD to look like new
// CRUDE RESET
ibDmaTcdDataChan.TCD->CITER = ibDmaTcdDataChan.TCD->BITER;
// **** End Right Royal Bodge
if (weAreMaster) {delay(2000);} // ensure others are ready to read
dumpDmaTcd(ibDmaTcdDataChan, 55555);
Serial.println("SETUP ENDED");
startMillis = millis(); // for debugging
//bool __sync_bool_compare_and_swap (type *ptr, type oldval type newval, ...)
//type __sync_val_compare_and_swap (type *ptr, type oldval type newval, ...)
//These builtins perform an atomic compare and swap. That is, if the current value of *ptr is oldval, then write newval into *ptr.
//The “bool” version returns true if the comparison is successful and newval was written.
//The “val” version returns the contents of *ptr before the operation.
inline bool enqueue( volatile unsigned int *lock ) { // not used
return (__sync_bool_compare_and_swap( lock, 0, 1 ) );
// returns true if lock was 0 and was replaced by 1
// returns false if lock was 1 ie owned by someone else
//Prior to initializing the corresponding module, set SCGC5[PORTx] in the SIM module to enable the clock. Before turning off the clock, make sure to disable the module.
inline void dequeue( volatile unsigned int *lock ) { // not used
asm volatile ( "" ::: "memory" );
*lock = 0;
// sets lock to 0, releasing it
return;
void doDmaGet() {
// no longer required as IB DMA now continuously enabled
void doDmaPut() {
// DMA_SERQ = 1; // Start OB - NOT needed
obDmaTcdDataChan.TCD->CSR |= DMA_TCD_CSR_START ; // 0x0001
void dmaGetEndedInterrupt() { // Called by DMA IB on completion of read
//ibDmaTcdDataChan.clearInterrupt(); // same as:
DMA_CINT = ibDmaTcdDataChan.channel; // clear interrupt
ibPackedBuffStatus = myFULL;
uint8_t getSerialIx(uint32_t thisSerial) {
uint8_t ix = 0; // 0=error
for (uint32_t ii=0;ii<noOfProcessors;ii++) {
if (thisSerial == serialList[ii]) {ix=ii+1;}
return ix;
volatile bool myIbPackedBuffStatus = myEMPTY;
// Caution - ibPackedBuffStatus is also changed in an interrupt
// We can change it here when the IB DMA channel is not running
loopCnt++;
if (millis()-startMillis > 10000){ // debugging
printIbUnpackedBuff(dmaGetCnt,loopCnt);
dumpDmaTcd(obDmaTcdDataChan, 91);
dumpDmaTcd(obDmaTcdClockChan, 92);
dumpDmaTcd(ibDmaTcdDataChan, 93);
showDmaErr(obDmaTcdDataChan.channel);
showDmaErr(obDmaTcdClockChan.channel);
showDmaErr(ibDmaTcdDataChan.channel);
unPackIbPkToIbUp();
while(1==1){}
// Handle Startup
if (initialRecordToBeCreated) {
setIbUnpackedBuff();
moveIbUpToObUp();
packObUpToObPk();
doDmaPut();
return;
// Handle Get-Got Interrupt Flag
noInterrupts();
myIbPackedBuffStatus = ibPackedBuffStatus;
interrupts();
// Handle Get Got
if (myIbPackedBuffStatus == myFULL) {
dmaGetCnt++;
//printIbPackedBuff(dmaGetCnt,loopCnt);
unPackIbPkToIbUp();
//printIbUnpackedBuff(dmaGetCnt,loopCnt);
// *** START Work - tinker with the record here in ib unpacked buffer
ibUnpackedBuff.buff32[mySerialIx]++;
// *** END Work
moveIbUpToObUp();
//printObUnpackedBuff(dmaGetCnt,loopCnt); // function does not exist
packObUpToObPk();
//printObPackedBuff(dmaGetCnt,loopCnt);
doDmaPut();
void setDebugPins(int32_t val) {
// Set the 10 debug pins to show val to the extent that 10 bits allows
val <<= 22;
if (val < 0){digitalWrite(DEBUG_PIN_01, HIGH);} else {digitalWrite(DEBUG_PIN_01, LOW );}
val <<= 1;
if (val < 0){digitalWrite(DEBUG_PIN_02, HIGH);} else {digitalWrite(DEBUG_PIN_02, LOW );}
val <<= 1;
if (val < 0){digitalWrite(DEBUG_PIN_03, HIGH);} else {digitalWrite(DEBUG_PIN_03, LOW );}
val <<= 1;
if (val < 0){digitalWrite(DEBUG_PIN_04, HIGH);} else {digitalWrite(DEBUG_PIN_04, LOW );}
val <<= 1;
if (val < 0){digitalWrite(DEBUG_PIN_05, HIGH);} else {digitalWrite(DEBUG_PIN_05, LOW );}
val <<= 1;
if (val < 0){digitalWrite(DEBUG_PIN_06, HIGH);} else {digitalWrite(DEBUG_PIN_06, LOW );}
val <<= 1;
if (val < 0){digitalWrite(DEBUG_PIN_07, HIGH);} else {digitalWrite(DEBUG_PIN_07, LOW );}
val <<= 1;
if (val < 0){digitalWrite(DEBUG_PIN_08, HIGH);} else {digitalWrite(DEBUG_PIN_08, LOW );}
val <<= 1;
if (val < 0){digitalWrite(DEBUG_PIN_09, HIGH);} else {digitalWrite(DEBUG_PIN_09, LOW );}
val <<= 1;
if (val < 0){digitalWrite(DEBUG_PIN_10, HIGH);} else {digitalWrite(DEBUG_PIN_10, LOW );}
