Problem installing Arduino IDE 1.8.19 and Teensyduino 1.59 on RPI5 Bookworm
I'm running Arduino IDE 1.8.19 and Teensyduino 1.59.0 on a clean install RPI5 Bookworm running on an m.2 nVME hosted on PCIExpress bus.
After a number of false starts, I've loaded Arduino IDE and Teensyduino using a script from Paul Stoffregen Aug 24, 2020 with minor changes to reflect latest release versions, which goes
wget https://downloads.arduino.cc/arduino-1.8.19-linuxaarch64.tar.xz
wget https://www.pjrc.com/teensy/td_159/TeensyduinoInstall.linuxaarch64
wget https://www.pjrc.com/teensy/49-teensy.rules
sudo cp 49-teensy.rules /etc/udev/rules.d/
tar -xf arduino-1.8.19-linuxaarch64.tar.xz
chmod 755 TeensyduinoInstall.linuxaarch64
./TeensyduinoInstall.linuxaarch64 --dir=arduino-1.8.19
cd arduino-1.8.19
If I go into the arduino-1.8.19 direcotry and click on 'Arduino', it runs, finds boards including Teensy4.1 and I can successfully compile.
I have two problems;
1. The Arduino application doesn't appear in the desktop menu, either under Programming or Electronics. How do I make this happen?
2. Teensyduino is started when the Arduino IDE tries to upload code to the T4.1, but uploading never starts, whether I press the programming button or not.
- Arduino IDE finds port /dev/bus/usb/003/009 Bootloader (Teensy 4.1)
- Arduino IDE times out with the message,
Teensy did not respond to a USB-based request to enter program mode.
An error occurred while uploading the sketch
Can anyone help me, please?
