Andy Belov
Is there a difference in read/write speed of SD card between the one soldered directly onto Teensy 4.0 vs. one on the new Audio Board?
I'd like to use the one on Teensy 4.0, but I also need the USB host contacts and using them both doesn't seem to be possible.
Will I be able to record audio from the Audio Board onto it's SD card? At what rate?
Thank you.
Thank you.
