I have a setup with 2 teensys, the first is the main controller and sends a number over serial (using easy transfer) after a button push to the other, which tells the second teensy which WAV file to play. I have to do this as the first is doing a lot of FastLED stuff and it wasn't playing nicely with that and the audio on one teensy
At the moment, it is queing the wav files, so when you hit the pushbutton (on the first teensy) several times, it queues the wav file so it finishes playing each time before the next sample starts.
What i would like is either to layer the WAVs up, so the first carries on playing but the next sample starts at the moment the button is pushed, or if that is not possible then to stop the first wav playing as soon as the second one starts.
Here's the code from the audio teensy that recieves the number over easytransfer.
Ignore the pushbutton in this code as it's just used for testing without the serial.
As always, I'm grateful for any help!
Best,
Rob
Best,
Rob
// Simple WAV file player example
// Three types of output may be used, by configuring the code below.
// 1: Digital I2S - Normally used with the audio shield:
// http://www.pjrc.com/store/teensy3_audio.html
// 2: Digital S/PDIF - Connect pin 22 to a S/PDIF transmitter
// https://www.oshpark.com/shared_projects/KcDBKHta
// 3: Analog DAC - Connect the DAC pin to an amplified speaker
// http://www.pjrc.com/teensy/gui/?info=AudioOutputAnalog
// To configure the output type, first uncomment one of the three
// output objects. If not using the audio shield, comment out
// the sgtl5000_1 lines in setup(), so it does not wait forever
// trying to configure the SGTL5000 codec chip.
// The SD card may connect to different pins, depending on the
// hardware you are using. Uncomment or configure the SD card
// pins to match your hardware.
// Data files to put on your SD card can be downloaded here:
// http://www.pjrc.com/teensy/td_libs_AudioDataFiles.html
// This example code is in the public domain.
#include <Arduino.h>
#include <SerialFlash.h>
#include <Bounce2.h>
#include <EasyTransfer.h>
AudioPlaySdWav playWav1;
// Use one of these 3 output types: Digital I2S, Digital S/PDIF, or Analog DAC
AudioOutputI2S audioOutput;
//AudioOutputSPDIF audioOutput;
//AudioOutputAnalog audioOutput;
AudioConnection patchCord1(playWav1, 0, audioOutput, 0);
AudioConnection patchCord2(playWav1, 1, audioOutput, 1);
#define SDCARD_CS_PIN 10
#define SDCARD_MOSI_PIN 7
#define SDCARD_SCK_PIN 14
// Use these with the Teensy 3.5 & 3.6 SD card
//#define SDCARD_CS_PIN BUILTIN_SDCARD
//#define SDCARD_MOSI_PIN 11 // not actually used
//#define SDCARD_SCK_PIN 13 // not actually used
// Use these for the SD+Wiz820 or other adaptors
//#define SDCARD_CS_PIN 4
/* ========== EasyTransfer ============
//create object
EasyTransfer ET;
struct RECEIVE_DATA_STRUCTURE{
//put your variable definitions here for the data you want to receive
//THIS MUST BE EXACTLY THE SAME ON THE OTHER ARDUINO
int16_t sound;
//give a name to the group of data
RECEIVE_DATA_STRUCTURE mydata;
void playFile(const char *filename)
Serial.print("Playing file: ");
Serial.println(filename);
// Start playing the file. This sketch continues to
// run while the file plays.
playWav1.play(filename);
// A brief delay for the library read WAV info
delay(5);
// Simply wait for the file to finish playing.
while (playWav1.isPlaying())
// uncomment these lines if you audio shield
// has the optional volume pot soldered
//float vol = analogRead(15);
//vol = vol / 1024;
// sgtl5000_1.volume(vol);
/* ========== pushButton ============
set pushbutton to pin 3
create pushbutton object
when the single button is pushed, select a
random candle on MyCandleRack to animate
the burntime of the candle is handled by the candlerack
const byte buttonPin = 2;
Bounce debouncePushButton = Bounce();
void pushButton()
if (debouncePushButton.update())
if (debouncePushButton.fell())
playFile("HAL.WAV"); // filenames are always uppercase 8.3 format
Serial1.begin(9600);
//start the library, pass in the data details and the name of the Serial port. Can be Serial, Serial1, Serial2, etc.
ET.begin(details(mydata), &Serial1);
// Audio connections require memory to work. For more
AudioMemory(8);
// Comment these out if not using the audio adaptor board.
// This may wait forever if the SDA & SCL pins lack
// pullup resistors
sgtl5000_1.enable();
sgtl5000_1.volume(0.5);
SPI.setMOSI(SDCARD_MOSI_PIN);
SPI.setSCK(SDCARD_SCK_PIN);
if (!(SD.begin(SDCARD_CS_PIN)))
// stop here, but print a message repetitively
while (1)
pinMode(buttonPin, INPUT_PULLUP);
debouncePushButton.attach(buttonPin);
debouncePushButton.interval(50);
pushButton();
//check and see if a data packet has come in.
if(ET.receiveData()){
//this is how you access the variables. [name of the group].[variable name]
//since we have data, we will blink it out.
//Serial.println(mydata.sound);
switch (mydata.sound)
case 0:
Serial.print("We're at case ");
case 1:
case 2:
//you should make this delay shorter then your transmit delay or else messages could be lost
//delay(250);
