// E1.31 Receiver code base by Andrew Huxtable (andrew@hux.net.au).Adapted and modified by
// ccr (megapixel.lighting).
// This code may be freely distributed and used as you see fit for non-profit
// purposes and as long as the original author is credited and it remains open
// source
// Please configure your Lighting product to use Unicast to the IP the device is given from your DHCP server
// Multicast is not currently supported due to bandwidth/processor limitations
// You will need the Ethercard and FastLed Libraries from:
// [url]https://github.com/FastLED/FastLED/releases[/url]
// The Atmega328 only has 2k of SRAM. This is a severe limitation to being able to control large
// numbers of smart pixels due to the pixel data needing to be stored in an array as well as
// a reserved buffer for receiving Ethernet packets. This code will allow you to use a maximum of 240 pixels
// as that just about maxes out the SRAM on the Atmega328.
// There is deliberately no serial based reporting from the code to conserve SRAM. There is a **little**
// bit available if you need to add some in for debugging but keep it to an absolute minimum for debugging
// only.
#include <Ethernet.h>
#include <EthernetUdp.h>
#define USE_OCTOWS2811
#include<OctoWS2811.h>
#include<FastLED.h>
// enter desired universe and subnet (sACN first universe is 1)
#define DMX_SUBNET 0
#define DMX_UNIVERSE 1 //**Start** universe
// Set a different MAC address for each...
byte mac[] = { 0x74, 0x69, 0x69, 0x2D, 0x30, 0x15 };
// Uncomment if you want to use static IP
// ethernet interface ip address
IPAddress ip(10, 0, 0, 77); //IP address of ethernet shield
EthernetUDP Udp;
// By sacrificing some of the Ethernet receive buffer, we can allocate more to the LED array
// but this is **technically** slower because 2 packets must be processed for all 240 pixels.
/// DONT CHANGE unless you know the consequences...
#define ETHERNET_BUFFER 636 //540
#define CHANNEL_COUNT 3456 //because it divides by 3 nicely
#define NUM_LEDS 1152 // can not go higher than this - Runs out of SRAM
#define NUM_LEDS_PER_STRIP 144
#define NUM_STRIPS 8
#define UNIVERSE_COUNT 7
#define LEDS_PER_UNIVERSE 170
//#define BRIGHTNESS 100
// Define the array of leds
CRGB leds[NUM_STRIPS * NUM_LEDS_PER_STRIP];
// Pin layouts on the teensy 3:
// OctoWS2811: 2,14,7,8,6,20,21,5
unsigned char packetBuffer[ETHERNET_BUFFER];
int c = 0;
float fps = 0;
unsigned long currentMillis = 0;
unsigned long previousMillis = 0;
pinMode(9, OUTPUT);
digitalWrite(9, LOW); // reset the WIZ820io
delay(10);
digitalWrite(9, HIGH); // reset the WIZ820io
//pinMode(10, OUTPUT);
// digitalWrite(10, HIGH); // de-select WIZ820io
//pinMode(4, OUTPUT);
//digitalWrite(4, HIGH); // de-select the SD Card
delay(10);
// Using different LEDs or colour order? Change here...
LEDS.addLeds<OCTOWS2811>(leds, NUM_LEDS_PER_STRIP);
LEDS.setBrightness(32);
Ethernet.begin(mac,ip);
Udp.begin(5568);
Serial.print("server is at ");
Serial.println(Ethernet.localIP());
//Once the Ethernet is initialised, run a test on the LEDs
initTest();
void sacnDMXReceived(unsigned char* pbuff, int count, int unicount) {
if (count > CHANNEL_COUNT) count = CHANNEL_COUNT;
byte b = pbuff[113]; //DMX Subnet
if ( b == DMX_SUBNET) {
b = pbuff[114]; //DMX Universe
Serial.println(b );
if ( b >= DMX_UNIVERSE && b <= DMX_UNIVERSE + UNIVERSE_COUNT ) {
if ( pbuff[125] == 0 ) { //start code must be 0
int ledNumber = (b - DMX_UNIVERSE) * LEDS_PER_UNIVERSE;
// sACN packets come in seperate RGB but we have to set each led's RGB value together
// this 'reads ahead' for all 3 colours before moving to the next led.
//Serial.println("*");
for (int i = 126;i < 126+count;i = i + 3){
byte charValueR = pbuff[i];
byte charValueG = pbuff[i+1];
byte charValueB = pbuff[i+2];
leds[ledNumber] = CRGB(charValueR,charValueG,charValueB);
//Serial.println(ledNumber);
ledNumber++;
//Serial.println(unicount);
if (unicount == 10){
LEDS.show();
int checkACNHeaders(unsigned char* messagein, int messagelength) {
//Do some VERY basic checks to see if it's an E1.31 packet.
//Bytes 4 to 12 of an E1.31 Packet contain "ACN-E1.17"
//Only checking for the A and the 7 in the right places as well as 0x10 as the header.
//Technically this is outside of spec and could cause problems but its enough checks for us
//to determine if the packet should be tossed or used.
//This improves the speed of packet processing as well as reducing the memory overhead.
//On an Isolated network this should never be a problem....
if ( messagein[1] == 0x10 && messagein[4] == 0x41 && messagein[12] == 0x37) {
int addresscount = (byte) messagein[123] * 256 + (byte) messagein[124]; // number of values plus start code
return addresscount -1; //Return how many values are in the packet.
return 0;
void initTest() //runs at board boot to make sure pixels are working
LEDS.showColor(CRGB(255, 0, 0)); //turn all pixels on red
LEDS.showColor(CRGB(0, 255, 0)); //turn all pixels on green
LEDS.showColor(CRGB(0, 0, 255)); //turn all pixels on blue
LEDS.showColor(CRGB(0, 0, 0)); //turn all pixels off
//Process packets
int packetSize = Udp.parsePacket(); //Read UDP packet count
if (c >= 10){
c = 0;
if(packetSize){
//Serial.println(packetSize);
Udp.read(packetBuffer,ETHERNET_BUFFER); //read UDP packet
int count = checkACNHeaders(packetBuffer, packetSize);
if (count) {
//Serial.print("packet size first ");
c = c + 1;
// calculate framerate
currentMillis = millis();
if(currentMillis > previousMillis){
fps = 1 / ((currentMillis - previousMillis) * 0.001);
fps = 0;
previousMillis = currentMillis;
if (fps > 10 && fps < 500)// don't show numbers below or over given ammount
Serial.println(fps);
sacnDMXReceived(packetBuffer, count, c); //process data function
