I'm having some trouble trying to move a stepper motor with my teensy 4.1.
I'm using the AccelStepper motor library and micro-ros in order to communicate from my computer to the teensy. Due to the function to communicate from micro-ros I must call in the void loop(), the loop stops for a few microseconds which results in the stepper motor not being able to step whenever it needs and it moves very slowly. Is there a way I could call this function that wouldn't stop my teensy for calling the necessary steps? I learned that I could use an ESP32 and utilize its second core, is there an alternative for this for the teensy?
This is the code I'm using:
The function that stops the stepper is:
Does anyone know how I could solve this problem? Thanks in advance.
C++:
#include <AccelStepper.h>
#include <micro_ros_arduino.h>
#include <stdio.h>
#include <rcl/rcl.h>
#include <rcl/error_handling.h>
#include <rclc/rclc.h>
#include <rclc/executor.h>
#include <geometry_msgs/msg/quaternion.h>
rcl_subscription_t subscriber;
geometry_msgs__msg__Quaternion msg;
rclc_executor_t executor;
rclc_support_t support;
rcl_allocator_t allocator;
rcl_node_t node;
rcl_timer_t timer;
const int numSteppers = 1;
const int stepperPullPins[numSteppers] = {7};
const int stepperDirPins[numSteppers] = {8};
const int stepperEnablePins[numSteppers] = {9};
AccelStepper stepper[numSteppers] {
AccelStepper(1,stepperPullPins[0],stepperDirPins[0])
float steps = 8000.0;
int posObjectiu[numSteppers] = {0};
#define LED_PIN 13
#define RCCHECK(fn) { rcl_ret_t temp_rc = fn; if((temp_rc != RCL_RET_OK)){error_loop();}}
#define RCSOFTCHECK(fn) { rcl_ret_t temp_rc = fn; if((temp_rc != RCL_RET_OK)){}}
void error_loop(){
while(1){
digitalWrite(LED_PIN, !digitalRead(LED_PIN));
void subscription_callback(const void * msgin)
const geometry_msgs__msg__Quaternion * msg = (const geometry_msgs__msg__Quaternion *)msgin;
posObjectiu[0]=int(msg->w);
set_microros_transports();
pinMode(LED_PIN, OUTPUT);
digitalWrite(LED_PIN, HIGH);
delay(2000);
allocator = rcl_get_default_allocator();
//create init_options
RCCHECK(rclc_support_init(&support, 0, NULL, &allocator));
// create node
RCCHECK(rclc_node_init_default(&node, "micro_ros_arduino_node", "", &support));
// create subscriber
RCCHECK(rclc_subscription_init_default(
&subscriber,
&node,
ROSIDL_GET_MSG_TYPE_SUPPORT(geometry_msgs, msg, Quaternion),
"steppers"));
// create executor
RCCHECK(rclc_executor_init(&executor, &support.context, 1, &allocator));
RCCHECK(rclc_executor_add_subscription(&executor, &subscriber, &msg, &subscription_callback, ON_NEW_DATA));
for (int i = 0; i < numSteppers; i++) {
pinMode(stepperPullPins[i],OUTPUT);
pinMode(stepperDirPins[i],OUTPUT);
pinMode(stepperEnablePins[i],OUTPUT);
digitalWrite(stepperEnablePins[i],HIGH);
stepper[i].setMaxSpeed(5000.0);
stepper[i].setAcceleration(500.0);
stepper[i].setSpeed(100.0);
stepper[i].setMinPulseWidth(10);
Serial.println("Test:");
RCCHECK(rclc_executor_spin_some(&executor, RCL_MS_TO_NS(100)));
stepper[i].moveTo(posObjectiu[i]);
stepper[i].setSpeed(250.0);
stepper[i].runSpeedToPosition();
