USb MIDI coding
lukes27
Hi i have a teensy 2.0 with ATMEGA32U4 i have been trying to convert the teensy arduino midi library so it can be used directly like Usb serial / keyboard examples in the "Code Library" selection on the teensy website.
The main reason for doing this without the arduino is so i can swap USB device profile on startup acording to some dip switches ie be able to choose usb midi , keyboard , serial port .
The problem im having is i can Initialize the USB midi but i can't seem to write anything out.
My code compiles fine in AVR studio with no errors and my computer sees a usb midi device but cant seem to get anything to write out.
Below is how im trying to test it
int main(void)
usb_init();   // this must be ok as computer sees "USB midi"
_delay_ms(1000);
    while(1)
	sendControlChange(16,255,1);
Bellow are the functions i thought are relevant missing out include files and definitions ect
I basically just took sendControlChange() and send_raw() out of the arduino usb_api.cpp
// initialize USB serial
void usb_init(void)
	uint8_t u;
	u = USBCON;
	if ((u & (1<<USBE)) && !(u & (1<<FRZCLK))) return;
	HW_CONFIG();
        USB_FREEZE();				// enable USB
        PLL_CONFIG();				// config PLL
        while (!(PLLCSR & (1<<PLOCK))) ;	// wait for PLL lock
        USB_CONFIG();				// start USB clock
        UDCON = 0;				// enable attach resistor
	usb_configuration = 0;
	usb_suspended = 0;
	debug_flush_timer = 0;
	UDINT = 0;
        UDIEN = (1<<EORSTE)|(1<<SOFE);
	sei();  // init() in wiring.c does this
void sendControlChange(uint8_t control, uint8_t value, uint8_t channel)
	send_raw(0x0B, 0xB0 | ((channel - 1) & 0x0F), control & 0x7F, value & 0x7F);
void send_raw(uint8_t b0, uint8_t b1, uint8_t b2, uint8_t b3)
	uint8_t intr_state, timeout;
	if (!usb_configuration) return;
	intr_state = SREG;
	cli();
	UENUM = MIDI_TX_ENDPOINT;
	timeout = UDFNUML + 2;
	while (1) {
		// are we ready to transmit?
		if (UEINTX & (1<<RWAL)) break;
		SREG = intr_state;
		if (UDFNUML == timeout) return;
		intr_state = SREG;
		cli();
	UEDATX = b0;
	UEDATX = b1;
	UEDATX = b2;
	UEDATX = b3;
	if (!(UEINTX & (1<<RWAL))) UEINTX = 0x3A;
	SREG = intr_state;
ISR(USB_GEN_vect)
	uint8_t intbits, t, i;
	static uint8_t div4=0;
        intbits = UDINT;
        UDINT = 0;
        if (intbits & (1<<EORSTI)) {
		UENUM = 0;
		UECONX = 1;
		UECFG0X = EP_TYPE_CONTROL;
		UECFG1X = EP_SIZE(ENDPOINT0_SIZE) | EP_SINGLE_BUFFER;
		UEIENX = (1<<RXSTPE);
        if ((intbits & (1<<SOFI)) && usb_configuration) {
                t = debug_flush_timer;
                if (t) {
                        debug_flush_timer = --t;
                        if (!t) {
                                UENUM = DEBUG_TX_ENDPOINT;
                                while ((UEINTX & (1<<RWAL))) {
                                        UEDATX = 0;
                                UEINTX = 0x3A;
		if (UEBCLX) UEINTX = 0x3A;
	if (intbits & (1<<SUSPI)) {
		// USB Suspend (inactivity for 3ms)
		UDIEN = (1<<WAKEUPE);
		usb_suspended = 1;
		#if (F_CPU >= 8000000L)
		// WAKEUPI does not work with USB clock freeze
		// when CPU is running less than 8 MHz.
		// Is this a hardware bug?
		USB_FREEZE();			// shut off USB
		PLLCSR = 0;			// shut off PLL
		// to properly meet the USB spec, current must
		// reduce to less than 2.5 mA, which means using
		// powerdown mode, but that breaks the Arduino
		// user's paradigm....
	if (usb_suspended && (intbits & (1<<WAKEUPI))) {
		// USB Resume (pretty much any activity)
		PLL_CONFIG();
		USB_CONFIG();
		UDIEN = (1<<EORSTE)|(1<<SOFE)|(1<<SUSPE);
		usb_suspended = 0;
		return;
// Misc functions to wait for ready and send/receive packets
static inline void usb_wait_in_ready(void)
	while (!(UEINTX & (1<<TXINI))) ;
static inline void usb_send_in(void)
	UEINTX = ~(1<<TXINI);
static inline void usb_wait_receive_out(void)
	while (!(UEINTX & (1<<RXOUTI))) ;
static inline void usb_ack_out(void)
	UEINTX = ~(1<<RXOUTI);
// USB Endpoint Interrupt - endpoint 0 is handled here.  The
// other endpoints are manipulated by the user-callable
// functions, and the start-of-frame interrupt.
ISR(USB_COM_vect)
        uint8_t intbits;
	const uint8_t *list;
        const uint8_t *cfg;
	uint8_t i, n, len, en;
	uint8_t *p;
	uint8_t bmRequestType;
	uint8_t bRequest;
	uint16_t wValue;
	uint16_t wIndex;
	uint16_t wLength;
	uint16_t desc_val;
	const uint8_t *desc_addr;
	uint8_t	desc_length;
	UENUM = 0;
	intbits = UEINTX;
	if (intbits & (1<<RXSTPI)) {
		bmRequestType = UEDATX;
		bRequest = UEDATX;
		read_word_lsbfirst(wValue, UEDATX);
		read_word_lsbfirst(wIndex, UEDATX);
		read_word_lsbfirst(wLength, UEDATX);
		UEINTX = ~((1<<RXSTPI) | (1<<RXOUTI) | (1<<TXINI));
		if (bRequest == GET_DESCRIPTOR) {
			list = (const uint8_t *)descriptor_list;
			for (i=0; ; i++) {
				if (i >= NUM_DESC_LIST) {
					UECONX = (1<<STALLRQ)|(1<<EPEN);  //stall
					return;
				pgm_read_word_postinc(desc_val, list);
				if (desc_val != wValue) {
					list += sizeof(struct descriptor_list_struct)-2;
					continue;
				if (desc_val != wIndex) {
					list += sizeof(struct descriptor_list_struct)-4;
					continue;
				pgm_read_word_postinc(desc_addr, list);
				desc_length = pgm_read_byte(list);
			len = (wLength < 256) ? wLength : 255;
			if (len > desc_length) len = desc_length;
			list = desc_addr;
			do {
				// wait for host ready for IN packet
				do {
					i = UEINTX;
				} while (!(i & ((1<<TXINI)|(1<<RXOUTI))));
				if (i & (1<<RXOUTI)) return;	// abort
				// send IN packet
				n = len < ENDPOINT0_SIZE ? len : ENDPOINT0_SIZE;
				for (i = n; i; i--) {
					pgm_read_byte_postinc(UEDATX, list);
				len -= n;
				usb_send_in();
			} while (len || n == ENDPOINT0_SIZE);
			return;
		if (bRequest == SET_ADDRESS) {
			usb_send_in();
			usb_wait_in_ready();
			UDADDR = wValue | (1<<ADDEN);
			return;
		if (bRequest == SET_CONFIGURATION && bmRequestType == 0) {
			usb_configuration = wValue;
			usb_send_in();
			cfg = endpoint_config_table;
			for (i=1; i<NUM_ENDPOINTS; i++) {
				UENUM = i;
				pgm_read_byte_postinc(en, cfg);
				UECONX = en;
				if (en) {
					pgm_read_byte_postinc(UECFG0X, cfg);
					pgm_read_byte_postinc(UECFG1X, cfg);
        		UERST = 0x1E;
        		UERST = 0;
			return;
		if (bRequest == GET_CONFIGURATION && bmRequestType == 0x80) {
			UEDATX = usb_configuration;
			usb_send_in();
			return;
		if (bRequest == GET_STATUS) {
			i = 0;
			if (bmRequestType == 0x82) {
				UENUM = wIndex;
				if (UECONX & (1<<STALLRQ)) i = 1;
				UENUM = 0;
			UEDATX = i;
			UEDATX = 0;
			usb_send_in();
			return;
		if ((bRequest == CLEAR_FEATURE || bRequest == SET_FEATURE)
		  && bmRequestType == 0x02 && wValue == 0) {
			i = wIndex & 0x7F;
			if (i >= 1 && i <= MAX_ENDPOINT) {
				usb_send_in();
				UENUM = i;
				if (bRequest == SET_FEATURE) {
					UECONX = (1<<STALLRQC)|(1<<RSTDT)|(1<<EPEN);
					UERST = (1 << i);
					UERST = 0;
				return;
                if (wIndex == DEBUG_INTERFACE) {
                        if (bRequest == HID_GET_REPORT && bmRequestType == 0xA1) {
                                len = wLength;
                                do {
                                        do {
                                                i = UEINTX;
                                        // send IN packet
                                                UEDATX = 0;
                                        len -= n;
                                        usb_send_in();
                                return;
                        if (bRequest == HID_SET_REPORT && bmRequestType == 0x21) {
				if (wValue == 0x0300 && wLength == 0x0004) {
					uint8_t b1, b2, b3, b4;
                                        usb_wait_receive_out();
					b1 = UEDATX;
					b2 = UEDATX;
					b3 = UEDATX;
					b4 = UEDATX;
                                        usb_ack_out();
                                        usb_send_in();
					//if (b1 == 0xA9 && b2 == 0x45 && b3 == 0xC2 && b4 == 0x6B)
						//_reboot_Teensyduino_();
					//if (b1 == 0x8B && b2 == 0xC5 && b3 == 0x1D && b4 == 0x70)
						//_restart_Teensyduino_();
	UECONX = (1<<STALLRQ) | (1<<EPEN);	// stall
Any help or advice would be great as not sure where im going wrong.
Cheers for looking
Luke
Ive tried on an windows XP machine and it does work sending data etc :D although comes up named as "usb device" not the name set in the usb descriptors .
But on my windows vista machine it comes up with the correct name but like mentioned before i can not see any written data. This could suggests they may be a problem in the device descriptors ?
Any one had problems with usb midi and vista ?
Ive posted a copy of the usb desctriptors below incase anyone notices anything.
static const uint8_t PROGMEM device_descriptor[] = {
	18,					// bLength
	1,					// bDescriptorType
	0x00, 0x02,				// bcdUSB
	0,					// bDeviceClass
	0,					// bDeviceSubClass
	0,					// bDeviceProtocol
	ENDPOINT0_SIZE,				// bMaxPacketSize0
	LSB(VENDOR_ID), MSB(VENDOR_ID),		// idVendor
	LSB(PRODUCT_ID), MSB(PRODUCT_ID),	// idProduct
	0x00, 0x01,				// bcdDevice
	0,					// iManufacturer
	1,					// iProduct
	0,					// iSerialNumber
	1					// bNumConfigurations
static const uint8_t PROGMEM debug_hid_report_desc[] = {
        0x06, 0xC9, 0xFF,                       // Usage Page 0xFFC9 (vendor defined)
        0x09, 0x04,                             // Usage 0x04
        0xA1, 0x5C,                             // Collection 0x5C
        0x75, 0x08,                             // report size = 8 bits (global)
        0x15, 0x00,                             // logical minimum = 0 (global)
        0x26, 0xFF, 0x00,                       // logical maximum = 255 (global)
        0x95, DEBUG_TX_SIZE,                    // report count (global)
        0x09, 0x75,                             // usage (local)
        0x81, 0x02,                             // Input
        0x95, DEBUG_RX_SIZE,                    // report count (global)
        0x09, 0x76,                             // usage (local)
        0x91, 0x02,                             // Output
        0x95, 0x04,                             // report count (global)
        0xB1, 0x02,                             // Feature
        0xC0                                    // end collection
#define CONFIG1_DESC_SIZE		( 9 + 74 + 32 )
#define DEBUG_HID_DESC_OFFSET		( 9 + 74 + 9 )
//#define CONFIG1_DESC_SIZE		( 9 + 92 + 32 )
//#define DEBUG_HID_DESC_OFFSET		( 9 + 92 + 9 )
static const uint8_t PROGMEM config1_descriptor[CONFIG1_DESC_SIZE] = {
	// configuration descriptor, USB spec 9.6.3, page 264-266, Table 9-10
	9, 					// bLength;
	2,					// bDescriptorType;
	LSB(CONFIG1_DESC_SIZE),			// wTotalLength
	MSB(CONFIG1_DESC_SIZE),
	NUM_INTERFACE,				// bNumInterfaces
	1,					// bConfigurationValue
	0,					// iConfiguration
	0xC0,					// bmAttributes
	50,					// bMaxPower
	// This MIDI stuff is a copy of the example from the Audio Class
	// MIDI spec 1.0 (Nov 1, 1999), Appendix B, pages 37 to 43.
#if 0
	http://www.usb.org/developers/devclass_docs/midi10.pdf
	Section B.3 seems to say these extra descriptors are required,
	but when I add them, MIDI breaks on Linux (haven't tried Mac and
	Windows yet).  TODO: investigate these....
	reported by "John K." on May 7, 2012, subject "USB MIDI descriptors"
	// Standard AC Interface Descriptor
	9,					// bLength
	4,					// bDescriptorType = INTERFACE
	0,					// bInterfaceNumber
	0,					// bAlternateSetting
	0,					// bNumEndpoints
	1,					// bInterfaceClass = AUDIO
	1,					// bInterfaceSubclass = AUDIO_CONTROL
	0,					// bInterfaceProtocol
	0,					// iInterface
	// Class-specific AC Interface Descriptor
	9,					// bLength
	0x24,					// bDescriptorType = CS_INTERFACE
	1,					// bDescriptorSubtype = HEADER
	0x00, 0x01,				// bcdADC
	0x09, 0x00,				// wTotalLength
	1,					// bInCollection
	1,					// baInterfaceNr(1)
        // Standard MS Interface Descriptor,
        9,                                      // bLength
        MIDI_INTERFACE,                         // bInterfaceNumber
        2,                                      // bNumEndpoints
        0x01,                                   // bInterfaceClass (0x01 = Audio)
        0x03,                                   // bInterfaceSubClass (0x03 = MIDI)
        0x00,                                   // bInterfaceProtocol (unused for MIDI)
        0,                                      // iInterface
	// MIDI MS Interface Header, USB MIDI 6.1.2.1, page 21, Table 6-2
	7,					// bLength
	0x01,					// bDescriptorSubtype = MS_HEADER
	0x00, 0x01,				// bcdMSC = revision 01.00
	0x41, 0x00,				// wTotalLength
	// MIDI IN Jack Descriptor, B.4.3, Table B-7 (embedded), page 40
	6,					// bLength
	0x02,					// bDescriptorSubtype = MIDI_IN_JACK
	0x01,					// bJackType = EMBEDDED
	1,					// bJackID, ID = 1
	0,					// iJack
	// MIDI IN Jack Descriptor, B.4.3, Table B-8 (external), page 40
	6,					// bLength
	0x02,					// bJackType = EXTERNAL
	2,					// bJackID, ID = 2
	0,					// iJack
	// MIDI OUT Jack Descriptor, B.4.4, Table B-9, page 41
	9,
	0x03,					// bDescriptorSubtype = MIDI_OUT_JACK
	3,					// bJackID, ID = 3
	1,					// bNrInputPins = 1 pin
	2,					// BaSourceID(1) = 2
	1,					// BaSourcePin(1) = first pin
	0,					// iJack
	// MIDI OUT Jack Descriptor, B.4.4, Table B-10, page 41
	9,
	4,					// bJackID, ID = 4
	1,					// BaSourceID(1) = 1
	0,					// iJack
        // Standard Bulk OUT Endpoint Descriptor, B.5.1, Table B-11, pae 42
        9,                                      // bLength
        5,                                      // bDescriptorType = ENDPOINT
        MIDI_RX_ENDPOINT,                       // bEndpointAddress
        0x02,                                   // bmAttributes (0x02=bulk)
        MIDI_RX_SIZE, 0,                        // wMaxPacketSize
        0,                                      // bInterval
	0,					// bRefresh
	0,					// bSynchAddress
	// Class-specific MS Bulk OUT Endpoint Descriptor, B.5.2, Table B-12, page 42
	5,					// bLength
	0x25,					// bDescriptorSubtype = CS_ENDPOINT
	0x01,					// bJackType = MS_GENERAL
	1,					// bNumEmbMIDIJack = 1 jack
	1,					// BaAssocJackID(1) = jack ID #1
        // Standard Bulk IN Endpoint Descriptor, B.5.1, Table B-11, pae 42
        9,                                      // bLength
        MIDI_TX_ENDPOINT | 0x80,                // bEndpointAddress
        MIDI_TX_SIZE, 0,                        // wMaxPacketSize
        0,                                      // bInterval
	0,					// bRefresh
	0,					// bSynchAddress
	// Class-specific MS Bulk IN Endpoint Descriptor, B.5.2, Table B-12, page 42
	5,					// bLength
	3,					// BaAssocJackID(1) = jack ID #3
        // interface descriptor, USB spec 9.6.5, page 267-269, Table 9-12
        9,                                      // bLength
        DEBUG_INTERFACE,                        // bInterfaceNumber
        2,                                      // bNumEndpoints
        0x03,                                   // bInterfaceClass (0x03 = HID)
        0x00,                                   // bInterfaceSubClass
        0,                                      // iInterface
        // HID interface descriptor, HID 1.11 spec, section 6.2.1
        9,                                      // bLength
        0x21,                                   // bDescriptorType
        0x11, 0x01,                             // bcdHID
        0,                                      // bCountryCode
        1,                                      // bNumDescriptors
        0x22,                                   // bDescriptorType
        sizeof(debug_hid_report_desc),          // wDescriptorLength
        0,
        // endpoint descriptor, USB spec 9.6.6, page 269-271, Table 9-13
        7,                                      // bLength
        DEBUG_TX_ENDPOINT | 0x80,               // bEndpointAddress
        0x03,                                   // bmAttributes (0x03=intr)
        DEBUG_TX_SIZE, 0,                       // wMaxPacketSize
        DEBUG_TX_INTERVAL,                      // bInterval
        7,                                      // bLength
        DEBUG_RX_ENDPOINT,                      // bEndpointAddress
        DEBUG_RX_SIZE, 0,                       // wMaxPacketSize
        DEBUG_RX_INTERVAL,                      // bInterval
// If you're desperate for a little extra code memory, these strings
// can be completely removed if iManufacturer, iProduct, iSerialNumber
// in the device desciptor are changed to zeros.
struct usb_string_descriptor_struct {
	uint8_t bLength;
	uint8_t bDescriptorType;
	int16_t wString[];
static const struct usb_string_descriptor_struct PROGMEM string0 = {
	4,
	3,
	{0x0409}
static const struct usb_string_descriptor_struct PROGMEM string1 = {
	sizeof(STR_PRODUCT),
	3,
	STR_PRODUCT
// This table defines which descriptor data is sent for each specific
// request from the host (in wValue and wIndex).
static const struct descriptor_list_struct {
	uint16_t	wValue;
	uint16_t	wIndex;
	const uint8_t	*addr;
	uint8_t		length;
} PROGMEM descriptor_list[] = {
	{0x0100, 0x0000, device_descriptor, sizeof(device_descriptor)},
	{0x0200, 0x0000, config1_descriptor, sizeof(config1_descriptor)},
        {0x2200, DEBUG_INTERFACE, debug_hid_report_desc, sizeof(debug_hid_report_desc)},
        {0x2100, DEBUG_INTERFACE, config1_descriptor+DEBUG_HID_DESC_OFFSET, 9},
	{0x0300, 0x0000, (const uint8_t *)&string0, 4},
	{0x0301, 0x0409, (const uint8_t *)&string1, sizeof(STR_PRODUCT)},
Thanks for looking
luke
