Which software is right?
Oleum
In version 1.58.1, the hardware versions 4 and 4.1 are not mentioned in the info. While they are mentioned in the version history.
Which one should I use for a 4.1?
Both of those TeensyDuino versions support T4.0 and T4.1. In the drop-downs, you should also see 0.59.x, which are the beta versions of upcoming 1.59. Even though they appear to be older because of the leading 0, they are newer, and I would recommend using the latest one of those, which should be 0.59.4. Versions 1.58 (and 1.59) have updated tools (gcc, etc.), and are preferable to 1.57.x
Click "More info".
It is same info, but printed in a weird order (thanks Arduino IDE) and truncated. You'll see the rest of the supported boards when you click "More info".
Yes, that's right, the button will take you to your website. There, quite far down in the history section, you will find the information about version 1.58:
Updated toolchain to gcc 11.3.1 for Teensy LC, 3.x, 4.x
Thank you
