PJWD
New member
I'm aiming to make a polyphonic synth with arcade buttons for the keyboard wired directly to the pins of a Teensy 3.2 with an Audio Shield attached.
I'm using the code below, with a Waveform object for each individual button. At present I'm touching a cable connected to Ground to each pin to act as the button press. When the first pin (0) is pressed the audio sounds loud, the next ones, (1, 2, 3, 4) are less loud, then the next (5, 8, 16) are even quieter. 17 sound a similar level to 1, 2, 3 and 4. 20 is quieter and 21, 24, 25 make no sound.
I have tried the pins in a different order and the same thing happens in the same sequence (eg 24 loud, 25, 26, 27, 28 less loud, 29, 30 ,31 quiet etc...)
I have also rebuilt the patch in the Audio System Design Tool several times, creating the objects in different orders and the result is the same.
The patch in the Audio System Design Tool looks like this:
Any help or suggestions gratefully received!
#include <Bounce.h>
AudioSynthWaveform waveform12; //xy=68,570
AudioSynthWaveform waveform2; //xy=71,82
AudioSynthWaveform waveform11; //xy=71,527
AudioSynthWaveform waveform10; //xy=78,474
AudioSynthWaveform waveform13; //xy=79,612
AudioSynthWaveform waveform1; //xy=82,36
AudioSynthWaveform waveform8; //xy=83,388
AudioSynthWaveform waveform9; //xy=83,429
AudioSynthWaveform waveform7; //xy=85,344
AudioSynthWaveform waveform3; //xy=87,125
AudioSynthWaveform waveform4; //xy=92,175
AudioSynthWaveform waveform6; //xy=95,293
AudioSynthWaveform waveform5; //xy=96,239
AudioEffectEnvelope envelope1; //xy=229.00000381469727,39
AudioEffectEnvelope envelope5; //xy=231,243
AudioEffectEnvelope envelope10; //xy=231,476
AudioEffectEnvelope envelope6; //xy=235,292
AudioEffectEnvelope envelope13; //xy=234,617
AudioEffectEnvelope envelope9; //xy=238,437
AudioEffectEnvelope envelope11; //xy=238.00000381469727,522.0000076293945
AudioEffectEnvelope envelope3; //xy=240,134
AudioEffectEnvelope envelope2; //xy=243,84
AudioEffectEnvelope envelope7; //xy=243,342
AudioEffectEnvelope envelope4; //xy=246,177
AudioEffectEnvelope envelope12; //xy=247,576
AudioEffectEnvelope envelope8; //xy=257,388
AudioMixer4 mixer1; //xy=427,145
AudioMixer4 mixer3; //xy=438,488
AudioMixer4 mixer2; //xy=439,336
AudioMixer4 mixer4; //xy=640,314
AudioOutputI2S i2s1; //xy=912,300
AudioConnection patchCord1(waveform12, envelope12);
AudioConnection patchCord2(waveform2, envelope2);
AudioConnection patchCord3(waveform11, envelope11);
AudioConnection patchCord4(waveform10, envelope10);
AudioConnection patchCord5(waveform13, envelope13);
AudioConnection patchCord6(waveform1, envelope1);
AudioConnection patchCord7(waveform8, envelope8);
AudioConnection patchCord8(waveform9, envelope9);
AudioConnection patchCord9(waveform7, envelope7);
AudioConnection patchCord10(waveform3, envelope3);
AudioConnection patchCord11(waveform4, envelope4);
AudioConnection patchCord12(waveform6, envelope6);
AudioConnection patchCord13(waveform5, envelope5);
AudioConnection patchCord14(envelope1, 0, mixer1, 0);
AudioConnection patchCord15(envelope5, 0, mixer2, 0);
AudioConnection patchCord16(envelope10, 0, mixer3, 1);
AudioConnection patchCord17(envelope6, 0, mixer2, 1);
AudioConnection patchCord18(envelope13, 0, mixer4, 3);
AudioConnection patchCord19(envelope9, 0, mixer3, 0);
AudioConnection patchCord20(envelope11, 0, mixer3, 2);
AudioConnection patchCord21(envelope3, 0, mixer1, 2);
AudioConnection patchCord22(envelope2, 0, mixer1, 1);
AudioConnection patchCord23(envelope7, 0, mixer2, 2);
AudioConnection patchCord24(envelope4, 0, mixer1, 3);
AudioConnection patchCord25(envelope12, 0, mixer3, 3);
AudioConnection patchCord26(envelope8, 0, mixer2, 3);
AudioConnection patchCord27(mixer1, 0, mixer4, 0);
AudioConnection patchCord28(mixer3, 0, mixer4, 2);
AudioConnection patchCord29(mixer2, 0, mixer4, 1);
AudioConnection patchCord30(mixer4, 0, i2s1, 0);
AudioConnection patchCord31(mixer4, 0, i2s1, 1);
AudioControlSGTL5000 sgtl5000_1; //xy=912,367
Bounce button0 = Bounce(0, 15); //(Pin number, ms debounce time)
Bounce button1 = Bounce(1, 15);
Bounce button2 = Bounce(2, 15);
Bounce button3 = Bounce(3, 15);
Bounce button4 = Bounce(4, 15);
Bounce button5 = Bounce(5, 15);
Bounce button6 = Bounce(8, 15);
Bounce button7 = Bounce(16, 15);
Bounce button8 = Bounce(17, 15);
Bounce button9 = Bounce(20, 15);
Bounce button10 = Bounce(21, 15);
Bounce button11 = Bounce(24, 15);
Bounce button12 = Bounce(25, 15);
int C2 = 65.41; // declaring the notes as values in Hz
int CShp2 = 69.30;
int D2 = 73.42;
int DShp2 = 77.78;
int E2 = 82.41;
int F2 = 87.31;
int FShp2 = 92.50;
int G2 = 98.00;
int GShp2 = 103.83;
int Aa2 = 110.00;
int AShp2 = 116.54;
int B2 = 123.47;
int C3 = 130.82;
AudioMemory(64);
sgtl5000_1.enable();
sgtl5000_1.volume(0.5); // master volume level
pinMode(0, INPUT_PULLUP);
pinMode(1, INPUT_PULLUP);
pinMode(2, INPUT_PULLUP);
pinMode(3, INPUT_PULLUP);
pinMode(4, INPUT_PULLUP);
pinMode(5, INPUT_PULLUP);
pinMode(8, INPUT_PULLUP);
pinMode(16, INPUT_PULLUP);
pinMode(17, INPUT_PULLUP);
pinMode(20, INPUT_PULLUP);
pinMode(21, INPUT_PULLUP);
pinMode(24, INPUT_PULLUP);
pinMode(25, INPUT_PULLUP);
waveform1.begin(0.2, 0, WAVEFORM_SAWTOOTH);
waveform2.begin(0.2, 440, WAVEFORM_SAWTOOTH);
waveform3.begin(0.2, 440, WAVEFORM_SAWTOOTH);
waveform4.begin(0.2, 440, WAVEFORM_SAWTOOTH);
waveform5.begin(0.2, 440, WAVEFORM_SAWTOOTH);
waveform6.begin(0.2, 440, WAVEFORM_SAWTOOTH);
waveform7.begin(0.2, 440, WAVEFORM_SAWTOOTH);
waveform8.begin(0.2, 440, WAVEFORM_SAWTOOTH);
waveform9.begin(0.2, 440, WAVEFORM_SAWTOOTH);
waveform10.begin(0.2, 440, WAVEFORM_SAWTOOTH);
waveform11.begin(0.2, 440, WAVEFORM_SAWTOOTH);
waveform12.begin(0.2, 440, WAVEFORM_SAWTOOTH);
waveform13.begin(0.2, 440, WAVEFORM_SAWTOOTH);
mixer1.gain(1, 0.2);
mixer1.gain(2, 0.2);
mixer1.gain(3, 0.2);
mixer1.gain(4, 0.2);
mixer2.gain(1, 0.2);
mixer2.gain(2, 0.2);
mixer2.gain(3, 0.2);
mixer2.gain(4, 0.2);
mixer3.gain(1, 0.2);
mixer3.gain(2, 0.2);
mixer3.gain(3, 0.2);
mixer3.gain(4, 0.2);
mixer4.gain(1, 0.2);
mixer4.gain(2, 0.2);
mixer4.gain(3, 0.2);
mixer4.gain(4, 0.2);
envelope1.attack(10);
envelope1.decay(350);
envelope1.sustain(0.8);
envelope1.release(500);
envelope2.attack(10);
envelope2.decay(350);
envelope2.sustain(0.8);
envelope2.release(500);
envelope3.attack(10);
envelope3.decay(350);
envelope3.sustain(0.8);
envelope3.release(500);
envelope4.attack(10);
envelope4.decay(350);
envelope4.sustain(0.8);
envelope4.release(500);
envelope5.attack(10);
envelope5.decay(350);
envelope5.sustain(0.8);
envelope5.release(500);
envelope6.attack(10);
envelope6.decay(350);
envelope6.sustain(0.8);
envelope6.release(500);
envelope7.attack(10);
envelope7.decay(350);
envelope7.sustain(0.8);
envelope7.release(500);
envelope8.attack(10);
envelope8.decay(350);
envelope8.sustain(0.8);
envelope8.release(500);
envelope9.attack(10);
envelope9.decay(350);
envelope9.sustain(0.8);
envelope9.release(500);
envelope10.attack(10);
envelope10.decay(350);
envelope10.sustain(0.8);
envelope10.release(500);
envelope11.attack(10);
envelope11.decay(350);
envelope11.sustain(0.8);
envelope11.release(500);
envelope12.attack(10);
envelope12.decay(350);
envelope12.sustain(0.8);
envelope12.release(500);
envelope13.attack(10);
envelope13.decay(350);
envelope13.sustain(0.8);
envelope13.release(500);
button0.update();
button1.update();
button2.update();
button3.update();
button4.update();
button5.update();
button6.update();
button7.update();
button8.update();
button9.update();
// key press for notes
if (button0.fallingEdge()) {
envelope1.noteOn();
waveform1.frequency(C2);
if (button0.risingEdge()) {
envelope1.noteOff();
if (button1.fallingEdge()) {
envelope2.noteOn();
waveform2.frequency(CShp2);
if (button1.risingEdge()) {
envelope2.noteOff();
if (button2.fallingEdge()) {
envelope3.noteOn();
waveform3.frequency(D2);
if (button2.risingEdge()) {
envelope3.noteOff();
if (button3.fallingEdge()) {
envelope4.noteOn();
waveform4.frequency(DShp2);
if (button3.risingEdge()) {
envelope4.noteOff();
if (button4.fallingEdge()) {
envelope5.noteOn();
waveform5.frequency(E2);
if (button4.risingEdge()) {
envelope5.noteOff();
if (button5.fallingEdge()) {
envelope6.noteOn();
waveform6.frequency(F2);
if (button5.risingEdge()) {
envelope6.noteOff();
if (button6.fallingEdge()) {
envelope7.noteOn();
waveform7.frequency(FShp2);
if (button6.risingEdge()) {
envelope7.noteOff();
if (button7.fallingEdge()) {
envelope8.noteOn();
waveform8.frequency(G2);
if (button7.risingEdge()) {
envelope8.noteOff();
if (button8.fallingEdge()) {
envelope9.noteOn();
waveform9.frequency(GShp2);
if (button8.risingEdge()) {
envelope9.noteOff();
if (button9.fallingEdge()) {
envelope10.noteOn();
waveform10.frequency(Aa2);
if (button9.risingEdge()) {
envelope10.noteOff();
if (button10.fallingEdge()) {
envelope11.noteOn();
waveform11.frequency(AShp2);
if (button10.risingEdge()) {
envelope11.noteOff();
if (button11.fallingEdge()) {
envelope12.noteOn();
waveform12.frequency(B2);
if (button11.risingEdge()) {
envelope12.noteOff();
if (button12.fallingEdge()) {
envelope13.noteOn();
waveform13.frequency(C3);
if (button12.risingEdge()) {
envelope13.noteOff();
