Results 1 to 3 of 3
Thread: __bss_end and __brkval on Teensy 3.0?
    Member dlchambers's Avatar
    Elkins, NH
    47
    I picked up this LCD from adafruit:
    https://www.adafruit.com/products/438
    and downloaded their Arduino lib, and opened their st7565lcd example.
    It compiles & works perfectly on a Teensy 2.0.
    But when I compile for Teensy 3.0 I get these errors:
    sps_lcd.cpp.o: In function `freeRam()':
    C:\Program Files\Arduino\arduino-1.0.3/sps_lcd.ino:120: undefined reference to `__brkval'
    C:\Program Files\Arduino\arduino-1.0.3/sps_lcd.ino:120: undefined reference to `__bss_end'
    Any ideas as to the equivalents for these symbols (extern int) on Teensy 3.0?
    Update: When I comment out the offending lines, the sketch compiles & loads, but doesn't run. I need to do some debugging!
    21,829
    Please try using Arduino 1.0.4 and Teensyduino 1.13.
    I recently added these, specifically to support that library on Teensy 3.0. Only 1.13 has them. If you're running an older version of Teensyduino, you'll get that error.
    21,829
    Here's the page regarding that library.
    http://www.pjrc.com/teensy/td_libs_ST7565.html
    You can see a photo of that LCD working with a Teensy 3.0 (yes, I actually did hook it up and test it). But ST7565 does require the latest 1.13 version....
Tags for this Thread
