I know what I have are two great products, the Teensy 3.1 and the Teensy 2++.
However, I am still sitting on the outside of the walls of the awesome 24/7 rave that is microcontroller nirvana.
Today I would like to put audio input and output on either the 3.1 or the 2++, Analog to digital, and then digital to analog, without even any additional processing.
I know there is a shield, but I do not have that. I have almost nothing since I don't know what I need and can't really afford to buy every possible component that the electronics elves tell me they need. This is why I am making this thread. I want to plug in one of these microcontrollers and digitally pass an analog signal through one of them or both, however crudely.
I need to know if I will need op amps, preamps, special grounding, voltage tolerances (what's the hottest signal that can go to the teensy?)
does the 2++ and 3.1 equal one another in the ADC/DAC department?
Basically, to sum up in the simplest way possible: can I do this today, with either or both of these two microcontrollers?
