Hi Paul,
I am using the "copy from SD card program" of Serial Flash but when connection SD card and Serial Flash together only SD card works.
Also, When initializing Serial first, it works and program hangs when reaches copying section of code.
Below is the code.(only copying one file).
#include <SerialFlash.h>
/*const int SDchipSelect = 4; // Audio Shield has SD card CS on pin 10
const int FlashChipSelect = 6;*/
SerialFlashFile ff;
File f;
int n1=0;
//uncomment these if using Teensy audio shield
//SPI.setSCK(14); // Audio shield has SCK on pin 14
//SPI.setMOSI(7); // Audio shield has MOSI on pin 7
// wait up to 10 seconds for Arduino Serial Monitor
unsigned long startMillis = millis();
while (!Serial && (millis() - startMillis < 10000)) ;
Serial.println("Copy all files from SD Card to SPI Flash");
SPI.setMOSI(11);
SPI.setMISO(12);
SPI.setSCK(13);
if (!SerialFlash.begin()) {
error("Unable to access SPI Flash chip");
SerialFlash.eraseAll();
if (SerialFlash.createErasable("PLAY1.WAV", 111111)) {
Serial.println("Create success");
ff = SerialFlash.open("PLAY1.WAV");
if (ff)
Serial.println("open success");
Serial.println("open UNsuccess");
Serial.println("Create UNsuccess");
SPI.setMOSI(7);
SPI.setMISO(8);
SPI.setSCK(14);
if (!SD.begin(9)) {
error("Unable to access SD card");
// SPI.setMOSI(11);
// SPI.setMISO(12);
// SPI.setSCK(13);
// if (!SerialFlash.begin()) {
// error("Unable to access SPI Flash chip");
int count = 0;
File rootdir = SD.open("/");
while (1) {
// open a file from the SD card
f = rootdir.openNextFile();
if (!f) break;
const char *filename = f.name();
Serial.print(filename);
Serial.print(" ");
unsigned long length = f.size();
Serial.println(length);
// SerialFlash.begin();
//SerialFlash.eraseAll();
// check if this file is already on the Flash chip
/*if (SerialFlash.exists(filename)) {
Serial.println(" already exists on the Flash chip");
SerialFlashFile ff = SerialFlash.open(filename);
if (ff && ff.size() == f.size()) {
Serial.println(" size is the same, comparing data...");
if (compareFiles(f, ff) == true) {
Serial.println(" files are identical
f.close();
ff.close();
continue; // advance to next file
Serial.println(" files are different");
Serial.print(" size is different, ");
Serial.print(ff.size());
Serial.println(" bytes");
// delete the copy on the Flash chip, if different
Serial.println(" delete file from Flash chip");
SerialFlash.remove(filename);
// create the file on the Flash chip and copy data
n1++;
if(n1==1)
Serial.print(" copying");
// copy data loop
unsigned long count = 0;
unsigned char dotcount = 9;
while (count < length) {
char buf[256];
unsigned int n;
n = f.read(buf, 256);
ff.write(buf, n);
count = count + n;
Serial.print(".");
if (++dotcount > 100) {
dotcount = 0;
ff.close();
if (dotcount > 0) Serial.println();
Serial.println(" error opening freshly created file!");
Serial.println(n1);
// } else {
// Serial.println(" unable to create file");
f.close();
rootdir.close();
delay(10);
Serial.println("Finished All Files");
bool compareFiles(File &file, SerialFlashFile &ffile) {
file.seek(0);
ffile.seek(0);
unsigned long count = file.size();
while (count > 0) {
char buf1[128], buf2[128];
unsigned long n = count;
if (n > 128) n = 128;
file.read(buf1, n);
ffile.read(buf2, n);
if (memcmp(buf1, buf2, n) != 0) return false; // differ
count = count - n;
return true; // all data identical
void error(const char *message) {
while (1) {
Serial.println(message);
delay(2500);
