Hi everyone,
I would like to use a Voice Recognition module from Elechouse with a Teensy 3.2 board :
http://www.elechouse.com/elechouse/index.php?main_page=product_info&cPath=&products_id=2254
Here is the Github VoiceRecognitionV3 library source :
https://github.com/elechouse/VoiceRecognitionV3
I tested this example with an Arduino Uno :
https://github.com/elechouse/VoiceRecognitionV3/blob/master/examples/vr_sample_check_baud_rate/vr_sample_check_baud_rate.ino
Everything is fine.
But when I test with a teensy, the compilation was ok but I have this message (no connection):
Elechouse Voice Recognition V3 Module
Check Baud Rate sample
Check baud rate failed.
Please check the connection, and reset arduino
I checked pins, it's ok ... so I think there is a problem with library compatibility.
So I want to adapt this library for Teensy.
How can I start ?
Thanks a lot for your help !
Mike
Everything is fine.
How can I start ?
Mike
