I have a very simple 3-wire (SCL/SDA/GND) connection from an Arduino Mega 2560 to a Teensy 3.2. I can send data from the Mega to the Teensy fine, but no matter what is sent from the Teensy to the Mega, the Mega receives 0xFF. I have verified that the connections are proper, and (with my trusty O'scope) verified that the signal voltage levels are correct. The scope photos below show the SCL line for the master-to-slave case (top) and the slave-to-master case (bottom). In both photos the vertical scale is 1V/cm and the horizontal scale is 20uSec/cm
I was initially using I2C_Anything to transfer data both ways, but also tried 'bare metal' byte processing by copying the underlying code from I2C_Anything - no change.
Master:
Slave:
Master Serial Output:
Slave Serial Output:
I'm sure it's something simple, but for the life of me I can't see it. Any help would be appreciated.
TIA,
Frank
Master:
Created: 3/14/2020 5:32:40 PM
Author: FRANKNEWXPS15\Frank
// Basic Master
// This creates a simple I2C Master device which when triggered will send/receive a text
// string to/from a Slave device. It is intended to pair with a Slave device running the
// basic_slave sketch.
// Pull pin12 input low to send.
// Pull pin11 input low to receive.
#include "I2Cdev.h" //02/19/19: this includes SBWire.h
#include <I2C_Anything.h>
#include <PrintEx.h> //allows printf-style printout syntax
StreamEx mySerial = Serial; //added 03/18/18 for printf-style printing
// Memory
#define MEM_LEN 256
char databuf[MEM_LEN];
unsigned long count;
float xmtfloat = 1.2344;
const uint8_t slaveAddr = 8; //uint8_t type reqd here for Wire.requestFrom() call
pinMode(LED_BUILTIN, OUTPUT); // LED
digitalWrite(LED_BUILTIN, LOW); // LED off
pinMode(12, INPUT_PULLUP); // Control for Send
pinMode(11, INPUT_PULLUP); // Control for Receive
// Setup for Master mode, pins 18/19, external pullups, 400kHz, 200ms default timeout
//Wire.begin(I2C_MASTER, 0x00, I2C_PINS_18_19, I2C_PULLUP_EXT, 400000);
//Wire.begin(I2C_MASTER, 0x00, I2C_PINS_18_19, I2C_PULLUP_INT, 400000);
//Wire.setDefaultTimeout(200000); // 200ms
Wire.begin();
// Data init
memset(databuf, 0, sizeof(databuf));
count = 0;
//Serial.begin(115200);
unsigned long now = millis();
int idx = 0;
//while (!Serial && (millis() - now) < 3000)
// delay(500);
// idx++;
//mySerial.printf("Serial available after %lu mSec\n", millis() - now);
//mySerial.printf("loop idx = %d\n", idx);
mySerial.printf("I2C_Master Example\n");
mySerial.printf("\nGround Pin 12 to transmit a float value to the slave\n");
mySerial.printf("\nGround Pin 11 to request a float value from the slave\n");
//mySerial.printf("\nInitial transmit float value is %2.4f\n\n",xmtfloat);
mySerial.printf("\nInitial transmit float value is %1.4f\n\n",xmtfloat);
count++;
uint8_t target = 0x66; // target Slave address
size_t idx;
// Send string to Slave
if (digitalRead(12) == LOW)
digitalWrite(LED_BUILTIN, HIGH); // LED on
// Transmit to Slave
mySerial.printf("Sending to Slave: %2.3f\n", ( xmtfloat * (float)count));
Wire.beginTransmission(target); // Slave address
I2C_writeAnything(xmtfloat * count);
Wire.endTransmission(); // Transmit to Slave
delay(100); // Delay to space out tests
// Read string from Slave
if (digitalRead(11) == LOW)
Serial.print("Reading from Slave: ");// Print message
// Read from Slave
Wire.requestFrom(target, (size_t)MEM_LEN); // Read from Slave (string len unknown, request full buffer)
//if (Wire.getError())
// Serial.print("FAIL\n");
//else
float slave_val = 0;
mySerial.printf("initial slave_val is %2.3f\n", slave_val);
//I2C_readAnything(slave_val);
byte* p = (byte*)&slave_val;
unsigned int i;
for (i = 0; i < sizeof slave_val; i++)
*p = Wire.read();
Serial.print("i = "); Serial.print(i);
Serial.print(": received "); Serial.println(*p);
p++;
mySerial.printf("Received %2.3f from Slave\n", slave_val);
Slave:
// Basic Slave
// This creates a simple I2C Slave device which will print whatever text string is sent to it.
// It will retain the text string in memory and will send it back to a Master device if
// requested. It is intended to pair with a Master device running the basic_master sketch.
03/07/20 Modified to be Teensy-specific, and to use 'I2C_Anything' for I2C communications
#include <i2c_t3.h>
#include <T3_I2C_Anything.h>
// Function prototypes
void receiveEvent(size_t count);
void requestEvent(void);
// Memory
volatile uint8_t received;
volatile float rcvfloat = 0;
// Setup
// Setup for Slave mode, address 0x66, pins 18/19, internal pullups, 400kHz
//Wire.begin(I2C_SLAVE, 0x66, I2C_PINS_18_19, I2C_PULLUP_INT, 400000);
//Wire.begin(I2C_SLAVE, 0x66, I2C_PINS_18_19, I2C_PULLUP_INT, 100000);
Wire.begin(I2C_SLAVE, 0x66, I2C_PINS_18_19, I2C_PULLUP_EXT, 100000);
// register events
Wire.onReceive(receiveEvent);
Wire.onRequest(requestEvent);
Serial.begin(1); //rate value ignored
int idx = 0;
idx++;
Serial.printf("I2C Slave Example\n");
// print received data - this is done in main loop to keep time spent in I2C ISR to minimum
if (received)
Serial.printf("Slave received: %f\n", rcvfloat);
received = 0;
// handle Rx Event (incoming I2C data)
received = count; // set received flag to count, this triggers print in main loop
I2C_readAnything(rcvfloat);
// handle Tx Event (outgoing I2C data)
Serial.printf("Sending %f to Master\n", rcvfloat);
const byte* p = (const byte*)&rcvfloat;
unsigned int i;
for (i = 0; i < sizeof rcvfloat; i++)
Wire.write(*p++);
delay(5); //experiment
//I2C_writeAnything(rcvfloat);
Opening port
Port open
I2C_Master Example
Initial transmit float value is 1.2344
Sending to Slave: 49.376
Sending to Slave: 50.610
Sending to Slave: 51.845
Sending to Slave: 53.079
Sending to Slave: 54.314
Sending to Slave: 55.548
Sending to Slave: 56.782
Sending to Slave: 58.017
Sending to Slave: 59.251
Sending to Slave: 60.486
Sending to Slave: 61.720
Sending to Slave: 62.954
Sending to Slave: 64.189
Sending to Slave: 65.423
Sending to Slave: 66.658
Reading from Slave: initial slave_val is 0.000
i = 0: received 255
i = 1: received 255
i = 2: received 255
i = 3: received 255
Received nan from Slave
i = 0: received 255
i = 1: received 255
i = 2: received 255
i = 3: received 255
i = 0: received 255
i = 1: received 255
i = 2: received 255
i = 3: received 255
Opening port
Port open
Slave received: 49.375999
Slave received: 50.610401
Slave received: 51.844803
Slave received: 53.079201
Slave received: 54.313602
Slave received: 55.548000
Slave received: 56.782402
Slave received: 58.016800
Slave received: 59.251202
Slave received: 60.485603
Slave received: 61.720001
Slave received: 62.954403
Slave received: 64.188805
Slave received: 65.423203
Slave received: 66.657600
Sending 66.657600 to Master
TIA,
Frank
