I've been trying to see how TDM in / outs work on Teensy 3.2 and I've stumbled upon something I don't quite understand.
tl;dr is that even if I don't connect anything to TDM output element's inputs I still see data being transmitted. Why?
Setup 1:
So not only the first frame has data: this is what I see on TX line (green). Yellow channel is the frame sync.
Setup 2:
When I attach "unused" inputs of TDM output to sine that has it's amplitude set to 0 I also see data being transmitted in those channels' frames. Here's the code:
Won't paste the scope screen capture as it looks the same as in Setup 1.
Setup 3
Finally I've tried following setup:
Now I see that TDM output produces "empty" frames that is data transmitted in all the frames but 0 (1?) is zeroes only. I'd expect that to happen in the previous two setups as well.
Setup 1:
AudioInputTDM tdm1; //xy=287,222
AudioSynthWaveformSine sine1; //xy=289,414
AudioOutputAnalog dac1; //xy=543,123
AudioOutputTDM tdm2; //xy=545,439
AudioConnection patchCord1(tdm1, 0, dac1, 0);
AudioConnection patchCord17(sine1, 0, tdm2, 0);
sine1.amplitude(0.5);
sine1.frequency(440);
AudioMemory(80);
Setup 2:
AudioSynthWaveformSine sine2;
AudioConnection patchCord2(sine2, 0, tdm2, 1);
AudioConnection patchCord3(sine2, 0, tdm2, 2);
AudioConnection patchCord4(sine2, 0, tdm2, 3);
AudioConnection patchCord5(sine2, 0, tdm2, 4);
AudioConnection patchCord6(sine2, 0, tdm2, 5);
AudioConnection patchCord7(sine2, 0, tdm2, 6);
AudioConnection patchCord8(sine2, 0, tdm2, 7);
AudioConnection patchCord9(sine2, 0, tdm2, 8);
AudioConnection patchCord10(sine2, 0, tdm2, 9);
AudioConnection patchCord11(sine2, 0, tdm2, 10);
AudioConnection patchCord12(sine2, 0, tdm2, 11);
AudioConnection patchCord13(sine2, 0, tdm2, 12);
AudioConnection patchCord14(sine2, 0, tdm2, 13);
AudioConnection patchCord15(sine2, 0, tdm2, 14);
AudioConnection patchCord16(sine2, 0, tdm2, 15);
sine2.amplitude(0);
sine2.frequency(440);
AudioMemory(80);
Setup 3
AudioConnection patchCord2(tdm1, 1, tdm2, 1);
AudioConnection patchCord3(tdm1, 2, tdm2, 2);
AudioConnection patchCord4(tdm1, 3, tdm2, 3);
AudioConnection patchCord5(tdm1, 4, tdm2, 4);
AudioConnection patchCord6(tdm1, 5, tdm2, 5);
AudioConnection patchCord7(tdm1, 6, tdm2, 6);
AudioConnection patchCord8(tdm1, 7, tdm2, 7);
AudioConnection patchCord9(tdm1, 8, tdm2, 8);
AudioConnection patchCord10(tdm1, 9, tdm2, 9);
AudioConnection patchCord11(tdm1, 10, tdm2, 10);
AudioConnection patchCord12(tdm1, 11, tdm2, 11);
AudioConnection patchCord13(tdm1, 12, tdm2, 12);
AudioConnection patchCord14(tdm1, 13, tdm2, 13);
AudioConnection patchCord15(tdm1, 14, tdm2, 14);
AudioConnection patchCord16(tdm1, 15, tdm2, 15);
AudioMemory(80);
