I'm trying to write data to the serial port at 1Khz and then I'm plotting it with SerialPlot: https://hackaday.io/project/5334-serialplot-realtime-plotting-software/discussion-88924
On a normal arduino it is smooth + works well, but on all of my teensies there is some sort of a buffering / delay effect where it appears to be writing the data to the serial port in chunks. Here is my code and an example of the code running on an arduino uno vs a teensy.
Here is the code:
Here is what happens when I run the code on an Uno (nice and smooth):
https://gifyu.com/image/WYFw
Here is what happens when I run the code on a Teensy (not smooth):
https://gifyu.com/image/WYCy
Here is the code:
Serial.begin(256000);
uint16_t a, b, c;
a = random(0, 500);
b = random(1000, 1500);
c = random(2000, 2500);
// Frame start byte
Serial.write(0xAB);
// a
Serial.write(a & 0xff);
Serial.write((a >> 8) & 0xff);
// b
Serial.write(b & 0xff);
Serial.write((b >> 8) & 0xff);
// c
Serial.write(c & 0xff);
Serial.write((c >> 8) & 0xff);
delay(1);
