David Tcheng
New member
After exhaustive research, I can't for the life of me find out how to access the mic inputs from Teensy. The Sparkfun ML Carrier board has 2 mics, but I can not find any documentation of how to access them. Using the Artemis processor on the same board, I could processing data from one of the mics.
Do the mics on the Sparkfun ML board work at all with Teensy? If so, how can you access them? I've tried many times using both Arduino and PlatformIO example with no luck. Has anyone been able to use the Sparkfun ML Carrier board to access mic input? Help!!!
