Hi there, im trying to follow a sketch but the sketch says include sound.h, now i cant find that library anywhere only Audio.h but when i use that i get all kinds of errors
were using a itsybitsy m4 express board
#include <english.h>
#include <Sound.h>
#include <TTS.h>
#include <Adafruit_LSM9DS1.h>
#include <Adafruit_Sensor.h>
// i2c, initialize the sensor breakout board
Adafruit_LSM9DS1 lsm = Adafruit_LSM9DS1();
#define LSM9DS1_SCK 21
#define LSM9DS1_MISO 12
#define LSM9DS1_MOSI 20
#define LSM9DS1_XGCS 6
#define LSM9DS1_MCS 5
void setupSensor()
// Set the magnetometer sensitivity
lsm.setupMag(lsm.LSM9DS1_MAGGAIN_4GAUSS);
// Dictionary of the 1000 most common English words.
char *words[] = {"the", "of", "to", "and", "a", "in", "is", "it", "you", "that", "he", "was", "for", "on", "are", "with", "as", "I", "his", "they", "be", "at", "one", "have", "this", "from", "or", "had", "by", "hot", "word", "but", "what", "some", "we", "can", "out", "instant", "market", "degree", "populate", "chick", "dear", "enemy", "reply", "drink", "occur", "support", "speech", "nature", "range", "steam", "motion", "path", "liquid", "log", "meant", "quotient", "teeth", "shell", "neck"};
// Media pins
#define PWM A0
#define buttonPin 13
//TTS text2speech(PWM); // default is digital pin 10
int buttonState = 0;
float lastMag = 0;
float lastTemp = 0;
pinMode(buttonPin, INPUT);
// Try to initialise and warn if we couldn't detect the chip
if (!lsm.begin())
Serial.println("Oops ... unable to initialize the LSM9DS1. Check your wiring!");
while (1);
setupSensor();
buttonState = digitalRead(buttonPin);
// Check if the switch has been thrown. If so, start measuring and speaking.
if (buttonState == HIGH) {
lsm.read(); /* ask it to read in the data */
/* Get a new sensor event */
sensors_event_t a, m, g, temp;
lsm.getEvent(&a, &m, &g, &temp);
// Get the latest magnetometer and temperature reading
float newMag = sqrt(sq(m.magnetic.x) + sq(m.magnetic.y) + sq(m.magnetic.z));
float newTemp = temp.temperature;
// If this isn't our first reading...
if (lastMag != 0) {
// Calculate the change in magnetic field/temperature
float deltaMag = abs(newMag - lastMag);
float deltaTemp = abs(newTemp - lastTemp);
// Get the biggest change of the two
float index = max(deltaMag, deltaTemp);
// Convert to an index of our dictionary array
float wordindfloat = index * 1000.0;
int wordindint = round(wordindfloat);
// Speak the change on teh speaker
text2speech.setPitch(6);
text2speech.sayText(words[wordindint]);
Serial.println(words[wordindint]);
// Store the readings for the next loop
lastMag = newMag;
lastTemp = newTemp;
// Store our readings as a baseline
else {
lastMag = newMag;
lastTemp = newTemp;
