Davidelvig
I'm been using SD functions on my Teensy 3.2-based board for a couple of years without known issues...
Until this last week.
Turns out I have a library dependency to the SparkFun SD library.
I removed that.
I tried to find the Teensy SD library within PlatformIO's library search and could not find a clear choice.
I downloaded the code from
https://github.com/PaulStoffregen/SD
It all seems to work, and the bug I was seeing is gone.
It's the first library I've had to manually install when using PlatformIO.
My platformIO.ini file looks like the snip below.
Should I be able to find a Teensy SD library within PlatformIO?
(or not need it explicitly due to inclusion of some more general Teensy library)
Thanks!
I removed that.
Thanks!
[env:teensy31]
platform = teensy
board = teensy31
framework = arduino
build_flags = -D USB_MIDI_SERIAL -D TEENSY_PLATFORM
lib_deps =
sstaub/TeensyID@^1.3.1
sparkfun/SparkFun 9DoF IMU Breakout - ICM 20948 - Arduino Library@^1.1.2
adafruit/Adafruit GFX Library@^1.10.4
adafruit/Adafruit ST7735 and ST7789 Library@^1.6.0
adafruit/Adafruit BusIO@^1.7.1
robtillaart/RunningMedian@^0.3.7
ivanseidel/LinkedList@0.0.0-alpha+sha.dac3874d28
arduino-libraries/Madgwick@^1.2.0
lib_extra_dirs =
../dbLibraries
