Thank you, Frank. I will make sure to change that.
Is the ground wire correct? I am assuming that you would only use AGND when using the analog pins.
Also, if I were to add pots to this circuit (connected to the analog pins) would I use the same ground for the button and pots? If yes, which ground would I need to use.
