Arduino UNO WIFI Rev2 with DS18B20 and library OneWire
jeanmarc
I use first an Arduino UNO Rev3 with DS18B20, and all works fine with the library oneWire standard.
I try to change with an Arduino UNO WIFI Rev2, and the DS18B20 is no more detected !
I try with another Arduino (same model), and I have the same problem.
I make some mesure with my ascilloscope, and we see the problem (pink line = High level on one output to see when the functions 'begin and search are active, blue line= signal on the DS18B20 command:
with the Arduino WIFI Rev2, nothing append on the output, I have tried others output with the same result!
I try with the library OneWireNg, and with this library, it's OK
I am not good enough to find what must be changed in the standard OneWire.h to correct the problem . After searching, I think the problem is in OneWire_direct_gpio.h (perhaps only a definition to add/change to be compliant with the new architecture of this new card ?)
CardInfo :
BN : Arduino Uno Wifi Rev2
VID : 0x03eb
PID : 0x2145
The very simple test program is :
#include <OneWire.h>
int DS18S20_Pin = 7;
int x = 0;
OneWire ds(DS18S20_Pin);
byte addr[8];
void setup(void) {
delay (500);
digitalWrite (5, LOW);
pinMode (5, OUTPUT);
pinMode (4, INPUT_PULLUP); // pin 4 is connected directly to pin 5 (only for the oscilloscope - pink line)
digitalWrite (5, HIGH);
ds.begin (DS18S20_Pin);
ds.search(addr);
ds.reset_search();
Thank in advance for your help
Jean-Marc
