Hi I'm currently using a teensy 3.1 Octows2811 and wiz820 running the very much the same as listed in Pauls example and it works great with Madrix software however I have a problem trying to get 2 systems to work in madrix only one works at anyone time. I've given each one a different Mac and IP Address and both unit seem to respond to the artnet data but only one works. If I change the mac address to the one that works and keep a different ip address both unit do the same thing.
I'm not sure if it's a madrix issue or my code any ideas?
This example will receive multiple universes via Artnet and control a strip of ws2811 leds via
Paul Stoffregen's excellent OctoWS2811 library:
https://www.pjrc.com/teensy/td_libs_OctoWS2811.html
This example may be copied under the terms of the MIT license, see the LICENSE file for details
#include <Artnet.h>
#include <Ethernet.h>
#include <EthernetUdp.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <OctoWS2811.h>
// OctoWS2811 settings
const int ledsPerStrip = 576; // 1150 change for your setup
const byte numStrips= 2; // change for your setup
DMAMEM int displayMemory[ledsPerStrip*6];
int drawingMemory[ledsPerStrip*6];
const int config = WS2811_RGB | WS2811_800kHz;
OctoWS2811 leds(ledsPerStrip, displayMemory, drawingMemory, config);
// Artnet settings
Artnet artnet;
const int startUniverse = 0; // CHANGE FOR YOUR SETUP most software this is 1, some software send out artnet first universe as zero.
const int numberOfChannels = ledsPerStrip * numStrips * 3; // Total number of channels you want to receive (1 led = 3 channels)
byte channelBuffer[numberOfChannels]; // Combined universes into a single array
// Check if we got all universes
const int maxUniverses = numberOfChannels / 512 + ((numberOfChannels % 512) ? 1 : 0);
bool universesReceived[maxUniverses];
bool sendFrame = 1;
// Change ip and mac address for your setup
byte ip[] = {192, 168, 1, 10};
byte mac[] = {0x04, 0xE9, 0xE5, 0x00, 0x69, 0xEC};
// If using software SPI (the default case):
#define OLED_MOSI 9
#define OLED_CLK 10
#define OLED_DC 11
#define OLED_CS 12
#define OLED_RESET 13
Adafruit_SSD1306 display(OLED_MOSI, OLED_CLK, OLED_DC, OLED_RESET, OLED_CS);
/* Uncomment this block to use hardware SPI
#define OLED_DC 6
#define OLED_CS 7
#define OLED_RESET 8
Adafruit_SSD1306 display(OLED_DC, OLED_RESET, OLED_CS);
display.begin(SSD1306_SWITCHCAPVCC);
display.clearDisplay();
display.setTextSize(1);
display.setTextColor(WHITE);
display.setCursor(0,0);
display.println("192.168.01.10");
display.setTextColor(BLACK, WHITE); // 'inverted' text
display.println("Neopixel");
// display.setTextSize(2);
// display.setTextColor(WHITE);
// display.print("0x"); display.println(0xDEADBEEF, HEX);
display.display();
delay(2000);
//Serial.begin(115200);
artnet.begin(mac, ip);
leds.begin();
initTest();
// this will be called for each packet received
artnet.setArtDmxCallback(onDmxFrame);
// we call the read function inside the loop
artnet.read();
void onDmxFrame(uint16_t universe, uint16_t length, uint8_t sequence, uint8_t* data)
sendFrame = 1;
// Store which universe has got in
if (universe < maxUniverses)
universesReceived[universe] = 1;
for (int i = 0 ; i < maxUniverses ; i++)
if (universesReceived
== 0)
//Serial.println("Broke");
sendFrame = 0;
// read universe and put into the right part of the display buffer
for (int i = 0 ; i < length ; i++)
int bufferIndex = i + ((universe - startUniverse) * length);
if (bufferIndex < numberOfChannels) // to verify
channelBuffer[bufferIndex] = byte(data);
// send to leds
for (int i = 0; i < ledsPerStrip * numStrips; i++)
leds.setPixel(i, channelBuffer[(i) * 3], channelBuffer[(i * 3) + 1], channelBuffer[(i * 3) + 2]);
if (sendFrame)
leds.show();
// Reset universeReceived to 0
memset(universesReceived, 0, maxUniverses);
void initTest()
for (int i = 0 ; i < ledsPerStrip * numStrips ; i++)
leds.setPixel(i, 127, 0, 0);
leds.show();
leds.setPixel(i, 0, 127, 0);
leds.show();
leds.setPixel(i, 0, 0, 127);
leds.show();
leds.setPixel(i, 0, 0, 0);
leds.show();
void testscrolltext(void) {
display.setCursor(10,0);
display.println("Vexica");
display.setCursor(10,20);
display.println("Artnet");
display.setCursor(20,40);
display.println("1020");
display.display();
display.startscrollright(0x00, 0x0F);
delay(2000);
display.stopscroll();
display.startscrollleft(0x00, 0x0F);
delay(2000);
display.startscrolldiagright(0x00, 0x07);
delay(2000);
display.startscrolldiagleft(0x00, 0x07);
delay(2000);
