johnwatterson
Whenever it is convenient for you. I will certain keep working on the details myself as I said - big learning curve here using all the new components hardware and software. Thanks again for your assistance.
#include <OctoWS2811.h>
//----------set the three below------//
const int ledsPerStrip = 72;
#define imageHeight 48
#define imageWidth 72
DMAMEM int displayMemory[ledsPerStrip*6];
int drawingMemory[ledsPerStrip*6];
const int config = WS2811_GRB | WS2811_800kHz;
OctoWS2811 leds(ledsPerStrip, displayMemory, drawingMemory, config);
#define RED 0xFF0000
const int chipSelect = BUILTIN_SDCARD;
//buffer to hold pixel data. remains size of pixel number//
const int ARRAY_SIZE = imageHeight*imageWidth;
const int byteBuffSize = ARRAY_SIZE*3;
byte pixelBUFFER[byteBuffSize];
byte ArrayB[ARRAY_SIZE];
byte ArrayR[ARRAY_SIZE];
byte ArrayG[ARRAY_SIZE];
void setup(void) {
leds.begin();
leds.show();
// if you dont get all leds lighting then going off, check your wiring
Serial.println("init");
Serial.print("Initializing SD card…");
if (!SD.begin(chipSelect)) {
Serial.println("initialization failed!");
while(1);
Serial.println("SD OK!");
bmpDraw("test.bmp");
//do a colour wipe to set all leds to red
for (int i=0; i < leds.numPixels(); i++) {
leds.setPixel(i, RED);
leds.show();
delay(5);
int32_t readNbytesInt(File *p_file, int position, byte nBytes)
if (nBytes > 4)
return 0;
p_file->seek(position);
int32_t weight = 1;
int32_t result = 0;
for (; nBytes; nBytes--)
result += weight * p_file->read();
weight <<= 8;
return result;
void bmpDraw( char* fileName)
// Open file
File bmpImage = SD.open(fileName, FILE_READ);
int32_t dataStartingOffset = readNbytesInt(&bmpImage, 0x0A, 4);
// Change their types to int32_t (4byte)
int32_t width = readNbytesInt(&bmpImage, 0x12, 4); //0x12 - dec18
int32_t height = readNbytesInt(&bmpImage, 0x16, 4); //0x16 - dec22
int32_t ImgSize = readNbytesInt(&bmpImage, 0x22,4); //-dec34
Serial.println(width);
Serial.println(height);
Serial.println(ImgSize);
int16_t pixelsize = readNbytesInt(&bmpImage, 0x1C, 2);
if (pixelsize != 24)
Serial.println("Image is not 24 bpp");
while (1);
bmpImage.seek(dataStartingOffset);//skip bitmap header
byte R, G, B;
for(int i=0;i<ARRAY_SIZE;i++){
ArrayB[i] = bmpImage.read();
ArrayG[i] = bmpImage.read();
ArrayR[i] = bmpImage.read();
bmpImage.close();
Serial.println("done writing to Buffer");
int ledCount =0;
for(int i=0; i<width*height;i++){
leds.setPixel(ledCount,Color(ArrayB[i],ArrayG[i],ArrayR[i]));
ledCount = ledCount+1;
leds.show();
//------- HELPER FUNCTION------//
// Create a 24 bit color value from R,G,B ////these strips are BGR, but you might need to change this
unsigned int Color(byte g, byte r, byte b)
//Take the lowest 8 bits of each value and append them end to end
return( ((unsigned int)g & 0x1F )<<16 | ((unsigned int)r & 0x1F)<<8 | (unsigned int)b & 0x1F);
//end of helper function
What is the best way to show you the images? On my phone now - maybe transfer to email and upload from there?
uint32_t ledCount =0;
uint32_t ledLocation = 0;
for (int y = 0; y<imageHeight; y++){ //for each row
for(int x = 0; x<imageWidth; x++){ //go through each coloumn
//use the & bitwise method to see if an odd or even row, we start rows at zero, so if row is odd, we go backwards
if( y & 0x01) {
ledLocation = (y*imageWidth) + ((imageWidth -1) -x);
// Even rows go forwards
ledLocation = (y * imageWidth) + x;
//set the pixel at ledLocation with the next colour in the colour array
leds.setPixel(ledLocation,Color(ArrayR[ledCount],ArrayG[ledCount],ArrayB[ledCount]));
//move on the colour array location by one.
leds.show();
int ledCount =0;
leds.setPixel(ledCount,Color(ArrayR[i],ArrayG[i],ArrayB[i]));
leds.show();
